More Saving Bugs
2002-12-19 by David DeciBel
What's going on with the saving? I'm in song mode trying to simply change a preset back to the way it was when i first did it on track 8B - It won't stick - no matter what I do. Eventually I'll find some dumb way to do it like by entering some nonsense song data, but whats up? 1.4 pls? ez
2002-12-19 by drK
On 12/19/02 12:50 AM, "David DeciBel" <spec@...> wrote: > What's going on with the saving? I'm in song mode trying to simply change a > preset back to the way it was when i first did it on track 8B - It won't > stick - no matter what I do. Eventually I'll find some dumb way to do it > like by entering some nonsense song data, but whats up? 1.4 pls? > > ez I'm not understanding the problem. What do you mean "change a preset back to the way it was"? Are your trying to do this by a patch change command or QuickEdit? Something else? drk www.delora.com/music www.mp3.com/zdrk drk.iuma.com
No. If I go into my song, and set up a preset on channel 8B with a certain sound, from phat drums to some keys, it works fine. I save the song, and then re load the song hit stop 3x and it goes back to the phat drums.... ----- Original Message ----- From: "drK" <drk@...> To: <xl7@yahoogroups.com> Sent: Thursday, December 19, 2002 5:47 AM Subject: Re: [xl7] More Saving Bugs > On 12/19/02 12:50 AM, "David DeciBel" <spec@...> wrote: > > > What's going on with the saving? I'm in song mode trying to simply change a > > preset back to the way it was when i first did it on track 8B - It won't > > stick - no matter what I do. Eventually I'll find some dumb way to do it > > like by entering some nonsense song data, but whats up? 1.4 pls? > > > > ez > > I'm not understanding the problem. What do you mean "change a preset back > to the way it was"? Are your trying to do this by a patch change command or
> QuickEdit? Something else? > > > > drk > > www.delora.com/music > www.mp3.com/zdrk > drk.iuma.com > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
2002-12-19 by erik_magrini@Baxter.com
You need to save that in the Pattern, not the Song. Just press Pattern
while in song mode, select the new Preset, then save the Pattern. When
you go back into Song mode it should work. Or are you referring to the
actual song track itself?
12/19/02 11:03 AM
Please respond to xl7
cc: Subject: Re: [xl7] More Saving Bugs No. If I go into my song, and set up a preset on channel 8B with a certain sound, from phat drums to some keys, it works fine. I save the song, and then re load the song hit stop 3x and it goes back to the phat drums.... ----- Original Message ----- From: "drK" <drk@...> To: <xl7@yahoogroups.com> Sent: Thursday, December 19, 2002 5:47 AM Subject: Re: [xl7] More Saving Bugs > On 12/19/02 12:50 AM, "David DeciBel" <spec@...> wrote: > > > What's going on with the saving? I'm in song mode trying to simply change a > > preset back to the way it was when i first did it on track 8B - It won't > > stick - no matter what I do. Eventually I'll find some dumb way to do it > > like by entering some nonsense song data, but whats up? 1.4 pls? > > > > ez > > I'm not understanding the problem. What do you mean "change a preset back > to the way it was"? Are your trying to do this by a patch change command or > QuickEdit? Something else? > > > > drk > > www.delora.com/music > www.mp3.com/zdrk > drk.iuma.com > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
Song Track. I noticed this also happens when I'm in pattern mode trying to change the SENDs and sometimes even presets. ----- Original Message ----- From: <erik_magrini@...> To: <xl7@yahoogroups.com> Sent: Thursday, December 19, 2002 11:33 AM Subject: Re: [xl7] More Saving Bugs > You need to save that in the Pattern, not the Song. Just press Pattern > while in song mode, select the new Preset, then save the Pattern. When > you go back into Song mode it should work. Or are you referring to the > actual song track itself? > > rEalm > > > > > > "David DeciBel" <spec@...> > 12/19/02 11:03 AM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: Re: [xl7] More Saving Bugs > > > No. If I go into my song, and set up a preset on channel 8B with a > certain > sound, from phat drums to some keys, it works fine. I save the song, and > then re load the song hit stop 3x and it goes back to the phat drums.... > > > ----- Original Message ----- > From: "drK" <drk@...> > To: <xl7@yahoogroups.com> > Sent: Thursday, December 19, 2002 5:47 AM > Subject: Re: [xl7] More Saving Bugs > > > > On 12/19/02 12:50 AM, "David DeciBel" <spec@...> wrote: > > > > > What's going on with the saving? I'm in song mode trying to simply > change a > > > preset back to the way it was when i first did it on track 8B - It > won't > > > stick - no matter what I do. Eventually I'll find some dumb way to do > it > > > like by entering some nonsense song data, but whats up? 1.4 pls? > > > > > > ez > > > > I'm not understanding the problem. What do you mean "change a preset > back > > to the way it was"? Are your trying to do this by a patch change > command > or > > QuickEdit? Something else? > > > > > > > > drk > > > > www.delora.com/music > > www.mp3.com/zdrk > > drk.iuma.com > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> > > > > > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > > > > [Non-text portions of this message have been removed] > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
2002-12-20 by erik_magrini@Baxter.com
I don't really use the Song Track, so I don't know off the top of my head.
Did you accidentally record a PC message in the track? Use Event List
Editor to take a look, perhaps you can just change it to your new Preset
from with in there. Strange that you have issues in Pattern mode with
Sends and Presets though, never seen that myself.
12/19/02 01:46 PM
cc: Subject: Re: [xl7] More Saving Bugs Song Track. I noticed this also happens when I'm in pattern mode trying to change the SENDs and sometimes even presets. ----- Original Message ----- From: <erik_magrini@...> To: <xl7@yahoogroups.com> Sent: Thursday, December 19, 2002 11:33 AM Subject: Re: [xl7] More Saving Bugs > You need to save that in the Pattern, not the Song. Just press Pattern > while in song mode, select the new Preset, then save the Pattern. When > you go back into Song mode it should work. Or are you referring to the > actual song track itself? > > rEalm > > > > > > "David DeciBel" <spec@...> > 12/19/02 11:03 AM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: Re: [xl7] More Saving Bugs > > > No. If I go into my song, and set up a preset on channel 8B with a > certain > sound, from phat drums to some keys, it works fine. I save the song, and > then re load the song hit stop 3x and it goes back to the phat drums.... > > > ----- Original Message ----- > From: "drK" <drk@...> > To: <xl7@yahoogroups.com> > Sent: Thursday, December 19, 2002 5:47 AM > Subject: Re: [xl7] More Saving Bugs > > > > On 12/19/02 12:50 AM, "David DeciBel" <spec@...> wrote: > > > > > What's going on with the saving? I'm in song mode trying to simply > change a > > > preset back to the way it was when i first did it on track 8B - It > won't > > > stick - no matter what I do. Eventually I'll find some dumb way to do > it > > > like by entering some nonsense song data, but whats up? 1.4 pls? > > > > > > ez > > > > I'm not understanding the problem. What do you mean "change a preset > back > > to the way it was"? Are your trying to do this by a patch change > command > or > > QuickEdit? Something else? > > > > > > > > drk > > > > www.delora.com/music > > www.mp3.com/zdrk > > drk.iuma.com > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > > > > [Non-text portions of this message have been removed] > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
2002-12-20 by Clay <bass17yl@yahoo.com>
I've noticed that if I change my Sends, then save without first hitting Record, Stop (to cause the Save button to blink), it doesn't save my changes. This may be what David's problem is. I've found that most Save problems can be fixed by hitting Record followed by Stop before saving. I guess the machine needs the Save light to be blinking before it acually saves anything? Clay --- In xl7@yahoogroups.com, erik_magrini@B... wrote: > I don't really use the Song Track, so I don't know off the top of my head. > Did you accidentally record a PC message in the track? Use Event List > Editor to take a look, perhaps you can just change it to your new Preset > from with in there. Strange that you have issues in Pattern mode with > Sends and Presets though, never seen that myself. > > rEalm > > > > > > "David DeciBel" <spec@s...> > 12/19/02 01:46 PM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: Re: [xl7] More Saving Bugs > > > Song Track. I noticed this also happens when I'm in pattern mode trying > to > change the SENDs and sometimes even presets. > > ----- Original Message ----- > From: <erik_magrini@B...> > To: <xl7@yahoogroups.com> > Sent: Thursday, December 19, 2002 11:33 AM > Subject: Re: [xl7] More Saving Bugs > > > > You need to save that in the Pattern, not the Song. Just press Pattern > > while in song mode, select the new Preset, then save the Pattern. When > > you go back into Song mode it should work. Or are you referring to the > > actual song track itself? > > > > rEalm > > > > > > > > > > > > "David DeciBel" <spec@s...> > > 12/19/02 11:03 AM > > Please respond to xl7 > > > > > > To: xl7@yahoogroups.com > > cc: > > Subject: Re: [xl7] More Saving Bugs > > > > > > No. If I go into my song, and set up a preset on channel 8B with a > > certain > > sound, from phat drums to some keys, it works fine. I save the song, > and > > then re load the song hit stop 3x and it goes back to the phat drums.... > > > > > > ----- Original Message ----- > > From: "drK" <drk@d...> > > To: <xl7@yahoogroups.com> > > Sent: Thursday, December 19, 2002 5:47 AM > > Subject: Re: [xl7] More Saving Bugs > > > > > > > On 12/19/02 12:50 AM, "David DeciBel" <spec@s...> wrote: > > > > > > > What's going on with the saving? I'm in song mode trying to simply > > change a > > > > preset back to the way it was when i first did it on track 8B - It > > won't > > > > stick - no matter what I do. Eventually I'll find some dumb way to > do > > it > > > > like by entering some nonsense song data, but whats up? 1.4 pls? > > > > > > > > ez > > > > > > I'm not understanding the problem. What do you mean "change a preset > > back > > > to the way it was"? Are your trying to do this by a patch change > > command > > or > > > QuickEdit? Something else? > > > > > > > > > > > > drk > > > > > > www.delora.com/music > > > www.mp3.com/zdrk > > > drk.iuma.com > > > > > > > > > > > > To unsubscribe from this group, send an email to: > > > xl7-unsubscribe@yahoogroups.com > > > > > > > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-01-02 by Aaron Eppolito
First off, make sure that you've set the song to use "song preset changes" instead of pattern preset changes (song edit menu). Otherwise, it ignores patch changes in the song track. By the way, this goes for all the different items in that screen. Once you've done that, you'll need to set up the presets for all 16 tracks and save. The easiest way to do this is probably to leave "pattern preset changes" enabled, start playing the song, stop, switch "song preset changes" on and save. You may have to put a dummy event on each channel you want saved in the song track to get it to save for that channel, I can't remember. -Aaron --- erik_magrini@... wrote: > You need to save that in the Pattern, not the Song. > > "David DeciBel" <spec@...> > Subject: Re: [xl7] More Saving Bugs > > > No. If I go into my song, and set up a preset on channel 8B with a > certain sound, from phat drums to some keys, it works fine. I save > the song, and then re load the song hit stop 3x and it goes back to > the phat drums.... > > > ----- Original Message ----- > > On 12/19/02 12:50 AM, "David DeciBel" <spec@...> > wrote: > > > > > What's going on with the saving? I'm in song mode trying to > simply change a preset back to the way it was when i first did it on > track 8B - It won't stick - no matter what I do. __________________________________________________ Do you Yahoo!? Yahoo! Mail Plus - Powerful. Affordable. Sign up now. http://mailplus.yahoo.com
