Weird behavior!
Weird behavior!
2002-11-21 by erik_magrini@Baxter.com
Spent more time on the XL-7 last night, and started to see some weirdness
happening that had me worried.  I would be in grid record mode working on
some beats, and if I used the data wheel to scale the velocity up or down
for the one note the cursor was under, you could see the little bars
representing ALL of my notes going up or down at the same time and by the
same amount!  Here's the weird thing though, if I cursored over to one of
these other notes, the display would still say that the note velocity was
what I had recorded initially, even though the graphic representation of
it was changing.  This happened quite a few times, but not every time.
Strange!  And things like Pattern changes and scrolling through the menus
were taking longer to do or acting jumpy too.  Power cycling the unit
didn't help either.  Just when I was getting really worried, the
"Compacting User Data" message appearred.  After a few minutes of letting
the Xl-7 doing it's thing, all was fine.  the Pattern changes were speedy
again, scrolling through the Edit menus was smoother, and no more grid
edit weirdness.  Which leads me to think that the XX-7's seem to behave
better after the Compacting.
Is there anyway to initiate the Compacting procedure whenever you want?
One of the power up options maybe?  We used to do System Resets on the
mc505 for the exact same reason, so being able to manually trigger a
compacting before playing live for instance would be great if it makes the
XX-7 behave better :)  Anyone?
Re: [xl7] Weird behavior!
2002-11-21 by David DeciBel
I"ve had some strange grid mode problems as well.  Especially while
switching between tempo edit, and beat edit (1/8th 1/16th etc)...  I'm not
quite sure what's up
Also, My data wheel is kinda fucked.  It goes up sometimes when i go down
with it.  Contact spray?
To: <xl7@yahoogroups.com>
Sent: Thursday, November 21, 2002 7:34 AM
Subject: [xl7] Weird behavior!
> rEalm
Seen that too, the Grid display will freeze on the current measure longer
than it's supposed to right?
"David DeciBel" <spec@...>
11/21/02 10:19 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Weird behavior!
weirdness
on
down
of
was
menus
letting
speedy
> rEalm
2002-11-21 by Nick Rothwell
Bad idea. Compaction should be semantically transparent, except for
the time it takes. if compaction is changing the way the XL-7 behaves,
then the software is broken and the bug needs to be fixed.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
I agree, it should be transparent (though ceasing to function for 3+
minutes is hardly transparent).  But if it is making things run smoother,
then I'd at least like to know if there's an option to 'force it' to do
this prior to critical shows or something.  That way, I can rest assured
that it's not going to do the same thing on stage or whatever.
I've seen lots of strange stuff that I usally passoff.  This is what I talk
about when I mention that the -7 is still a little buggy.  It's nothing that
really destroys my creative process or ruins my music, really, but it's damn
annoying...
Sent: Thursday, November 21, 2002 10:25 AM
> rEalm
> 11/21/02 10:19 AM
>         cc:
> From: <erik_magrini@...>
> weirdness
> on
> down
> the
> of
> was
> menus
> letting
> speedy
> the
> > rEalm
2002-11-22 by Nick Rothwell
Agreed, and there's a whole body of work on incremental
garbage-collection technology specially designed for systems where
realtime response is important (like, say, musical instruments). The
SuperCollider synthesis package does incremental GC, for example.
