Help: Pads are not being rechannelized
2002-11-22 by jesse_medway
Hi, I had this problem the other night and turning off and on again solved it. Tonight I have the same problwm and the old "fix" doesnt work. Basically when I have my track set to EXT and set to a channel the pads dont transmit to that channel. My midi controller does fine. The only way I can get the pads to transmit if I set the channel to MutliA or MultiB Only way to get it to work now is to turn transmit pads on. Any ideas? Thanks Jesse
