Pads stopped transmiting midi
2002-11-21 by jesse_medway
Hi, Today I was using my MP-7 when I noticed the pads would not transmit midi with the channel assignments I made My midi keyboard controller was able to transmit to the correct channel but the pads wouldn't unless I went to the midi options and turned transmit pads "on" I checked everything 3-4 times and ended up turning off the unit and back on again and now everyything is fine. Any idea on what might have happened. Is this some sort of bug? Jesse
