Greetings all: Advice Request...
2002-11-20 by tjlake2001
I do extensive arranging and some pc-based recording to share
arrangements and new pieces with my groups. Many of the "groove"
boxes I 've test driven seem more DJ oriented. I'm hoping this is a
little different. I have 3 questions that need answered before I pick
this up and become a contributing member to this forum!
1. My chord voicings often carry alternate bass notes and jazz
groupings. Can I use the XL-7 to actually write, arrange, and perform
songs along with a midi controller? Ease of use in that regard? My
chord voicings often carry alternate bass notes and jazz groupings.
2. Any best practices ideas out there for sequencing entire songs or
sets? Is the onboard card in the XL-7 enough for standard pop-rock?
3. Hypothetical situation: New progression gets thrown out at
rehearsal, we want to jam on it and explore harmonies, etc... Can I
use this box on the fly to give us a foundation?
Any other thoughts you can offer? Thank you for your time, I'm
looking forward to more discussion with you all.
Re: [xl7] Greetings all: Advice Request...
2002-11-20 by erik_magrini@Baxter.com
1. My chord voicings often carry alternate bass notes and jazz groupings.
Can I use the XL-7 to actually write, arrange, and perform songs along
with a midi controller? Ease of use in that regard? My chord voicings
>>>Yes, as long as you don't mind building up your songs as groups of
patterns.  Songs are made by chaining together patterns with a maximum
length of 32 measures.  There is a 16 channel song track that is up to 998
measures long, but editing it isn't as easy as editing pattern tracks.  If
you use a comptuer with seperate sequencing software, this may be a moot
point. <<<
2. Any best practices ideas out there for sequencing entire songs or sets?
>>>For your first point, see my above answer.  Will the XL rom suiot rock
and pop?  Hmm, hard to say.  Yeah, a lot of the basic elements are there,
bu this card is definitely geared towards the dance side of things.
However, if you get the P2000 rom, that will will help make up for any
holes in the sound choices. <<
3. Hypothetical situation: New progression gets thrown out at rehearsal,
we want to jam on it and explore harmonies, etc... Can I use this box on
>>>As in, can you rearrang a pre-recorded progression to reflect the new
change?  Yeah, you can probably do taht if it's not too complex.  A new OS
is due out early next year, and that will address a lot of the sequencer
editing shortcomings (if you view them as such). <<<
Any other thoughts you can offer? Thank you for your time, I'm looking
>>>Well, I think it's important to realize that this box IS geared towards
the dance/electronic side of things, but that doesn't mean it can't be
used for other things as well.  How it actually works for you is hard to
say given your above criteria. Feel free to hit us back if you've got
otehr questions or need clarification.<<<
2002-11-20 by drK
The sequencer works OK as a straight ahead sequencer.  A  couple of points
though.  First if your using patterns the maximum length is 32 measures.
Now these can be funny "big" time signatures so the length (number of total
beats or time) is not an issue, but keeping things straight may be.
Alternatively the Song mode has a single long (but multichannel) track
without length restrictions.
Also editing is not its strongest suite.  Cut and paste-style is good, as is
getting down in the details MIDI-command-by-MIDI-command.  Not much in
between.
So if you play well and don't mind doing edits in bar-size (or event size)
chunks you should be fine.
Oh, it works fine form an external controller.
if you want "pop" voicings then you should budget for a "PROTEUS POP
COLLECTION ROM", which is what is shipped inside the Proteus 2500.  It is
more varied instrument-wise.  The XL7 and MP7 are more for dance-style
voicings. YMMV
If your fast and accurate at playing!  It will be about the same amount of
work as you would need to record the parts to tape if you where working on a
section at a time.  if the idea is to play over say a 16 bar or 32 bar
progression and all you wanted was a basic rhythm and say simple chordal
foundation to explore from sure.   if your looking though to have it help
explore chord revoicings, well the only sequencer I've seen that does
something like that is the Yamaha QY700.  Very fast at changing or creating
chord progressions on the fly.
I think this is better suited to your needs, if I understand them from your
brief description, then say a Roland groovebox, and certainly a Korg
Electribes-series.  I am though having some trouble seeing the XX7 as a
"best" sequencer for more or less standard song writing.  Not saying it
won't work well, just not the first direction I would look.  Besides
workstation products I would probably spend some time looking at something
in the Yamaha QY family, especial the now somewhat old QY700.  Maybe even an
RM1x or RS7000, though they are definitely aimed more toward the dance
market.  But they are strong sequencer products first and foremost.
The XX7 is a blend of sequencer, sound engine, and
creation/performance-oriented control surface.  It is the combination that
makes it special  And for many current styles of music the sequencer is good
to great.
Anyway you should check out the download manual as it is a good easy ready,
especially if you check out how the sequencer works.  That, some time with
it in a store and of course a bunch of questions here and you should be good
to go.
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
2002-11-20 by Jonathan El-Bizri
I'm not sure what how you voice your harmonies has to do with sequencing.
You can record any midi you want into the sequencer.
You'll probably want to pick up the p2k ROM as well, or you might want to
check ou the MP-7 and see which sound set makes the most sense to you.
Foundation? Meaning? You could record a loop of you playing the progression,
if that's what you mean. Until the next OS, there will be no way to erase
what you recorded on the fly, however. (and even then, it will be two
simultaneous button presses, unless a cc command is going to be provided)
These units are still 'dj' oriented. They aren't real performance tools in
their own right - apart from doing filter sweeps etc, they mainly focusing
on
playback rather than live manipulation of tracks. However, they do their job
and in conjunction with other gear, you can do a lot with them.
bIz
2002-11-21 by Ravi Ivan Sharma
Or a QY-70/100
  Sent: Wednesday, November 20, 2002 3:09 PM
  Subject: Re: [xl7] Greetings all: Advice Request...
