Re: How can i setup my XL-7 to control REASON 1.01
2002-05-10 by tommy_trance
Did you try to "Transmit MIDI A/B out" option?  And also
try "transmit knob and keyboard output midi"  Reason is
always the slave in any situation.  In Reason...you have to
go to Edit> Preferences> Page pull-down window> MIDI> select your
MIDI Port (for example In-A USB MidiSport 2x2)> Midi Channel.
Now select Page: Advanced MIDI> Choose your MIDI bus and enable
Remote Control with the desired MIDI In device and enable Midi
Clock Sync.  In Reason...there is a MIDI and an ENABLE button
in teh MIDI SyNc Focus section of the transport and highlight
them.
--- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote:
> How can i setup my XL-7 to control REASON 1.01. i want to play
drums
> and samples with my XL Great 7 Pads. what do i need to do any help
> and from anyone will be great.
> ThanK YoU
2002-05-10 by nbaryosef100
How can i setup my XL-7 to control REASON 1.01. i want to play drums
ThanK YoU
2002-05-10 by emufreak1
Tommy_Trance already responded to your original post is message 2861,
here it is.......
RTA
Date:  Fri May 10, 2002  2:39 am
Subject:  Re: How can i setup my XL-7 to control REASON 1.01
them.
drums
> ThanK YoU
drums
> ThanK YoU
If you only see 5 messages when you log on, use this link:
http://groups.yahoo.com/group/xl7/messages
Many messages were posted between the time of your original post and
the repost of your massage.  The "message" prompt is right below
the "home" prompt in which you can view the last 50 messages on 1
page.
2861,
> here it is.......
> RTA
> From:  "tommy_trance" <tommy_trance@y...>
> them.
> drums
help
> > ThanK YoU
> drums
help
> > ThanK YoU
