More External Issues!1
2002-04-24 by adamhertzano
thanx For all your replies!! Still I Found that when i send notes from my mp-7 to the ms2000R Synth on the begining of a pattern , the notes are been sent and sequences on the ms200 start playing properly on some occasions,.. on other ocasions the note wouldnt play at all! when swithing patterns on the mp7 some patterns dont receive the note which was recorded on an external output channel and so the corresponding patterns dont receive the note on command on time or would start on the MS2000r /with A Small LAg which is very uncool... All patterns change properly! all routings are set Correctly ! Channels that containg external info are set to Ext(Only!) and are lit in the channel mute area! Can Anyone help me on this 1? I am considering buying and XL-7 for external gear pourposes only and im very satisfied with my MP7 and the Fresh OS updates which are so important. Ive checked out clock iassue possibilities on the ms2000r's behalf since some patterns start on time. ? Adam
