Problem: Weird wheel!
2002-04-23 by nifflas
I have problems with the data wheel. I sent back my last XL-7 because
the data wheel was buggy. When I turned it sometimes it did strange
things. When trying to change pattern or anything, it would
suddenly "jump" to a completley different value (And I know I didn't
turn the wheel that fast).
I got a new XL-7 and had no problem with it. The data wheel was
acting nice 'n smooth, no unexpected "jumps". Until now. A while ago
I noticed the data wheel on the new XL-7 started to act a little bit
weird. And now it's quite bad again, like the last XL-7.
Must be quite low quality components or something? This never
happends to my other synthesizers.
I just want to know how the data wheel is for the others of you?
//Nifflas
Re: [xl7] Problem: Weird wheel!
2002-04-23 by erik_magrini@Baxter.com
Bizarre, never had any problems here, and I jam on my gear pretty hard
sometimes too.  Maybe go to a local music store and see if they're floor
unit is experiencing the same problems?  It might be something that
happens over time or with abuse (not saying you do), and floor models are
great for this (which is why I never buy floor models!).
Re: Problem: Weird wheel!
2002-04-23 by emufreak1
Nifflas,
It's called the encoder.  The same thing happened on my P2K if the
wheel was turned too quickly.  Here is my reply to a user on the P2K
group with what I do to avoid sending it away....
> Subject: [p2k] Re: Problems with TurnWheel???
> Unfortunately there is nothing you can do aside from sending it
away
> to a service center. There is a device called an encoder which is
> soldered in to the front panel(you can see it if you pull the knob
> off), the is what's going bad. I have the same problem but I find
> that if I apply pressure to the knob(inward)while turning it(I
> usually put my thumb near the top-center and rotate either
clockwise
> or counter clockwise depending on which value I need), it will
scroll
> normally but if I try to spin quickly without pressure, that's when
> it jumps.
> Hope this helps.
> Later,
> M2
> http://groups.yahoo.com/group/orbit3/
because
didn't
ago
bit
> //Nifflas
Thank you for this information!
I'll try and see what happends.
//Nifflas
--- In xl7@y..., "emufreak1" <mmcquay@m...> wrote:
> Nifflas,
P2K
> away
knob
> clockwise
> scroll
when
> > it jumps.
> > Hope this helps.
> > Later,
> > M2
> because
strange
> didn't
> ago
> bit
> > //Nifflas
I'm extremly careful with my music equipment. Just a poor student and
can't afford much... so I don't want anything broken.
//Nifflas
hard
floor
models are
> rEalm
Same here.  My XL-1 is fine and I have not had the issue with that
one.
Later,
M2
and
> //Nifflas
> hard
they're
> floor
that
> models are
> > rEalm
RE: [xl7] Problem: Weird wheel!
2002-04-23 by Andre Lewis
On a totally different piece of music gear (My Yamaha A5000) the rotary encoded
knobs go haywire after a while too.  Oxidation of the component over time.
Either that or your live set involves swinging it about by the data wheel .. ;)
Andre
Sent: Tuesday, April 23, 2002 3:38 AM
Subject: [xl7] Problem: Weird wheel!
//Nifflas
2002-04-25 by heyrag@netzero.net
I also am experiencing data wheel wierdness on my MP7, very not smooth anymore, sometimes move several clicks before a value change...did not used to be like this!
