USB port issue
2002-04-24 by Meszaros, Christopher
Hi I have an MP-7 that i recently had to return because the USB port came unseated and lost inside the machine. Just thought ide comment on the "Very few" statement below. It seems that the USB port is faulty for more then a "very few" people. -cmz
> > Message: 15 > Date: Tue, 23 Apr 2002 15:11:16 -0700 > From: Scott Ruda <scottr@...> > Subject: Re: Re: usb for what ? > > > On Sunday, April 21, 2002, at 09:40 AM, mikexl7 wrote: > > > yes I had not looked at the usb port on my box till i pluged in my > > usb cable. It seemed not to be mounted properly in the inside of > > the box. I very carefully pressed the conecter down. > [...] > > --- In xl7@y..., "hysham2000" <isham@f...> wrote: > >> > >> but now I've got an hardware problem with this port : > it's broken > >> and moves somewhere in the box...I saw the first time I > plugged my usb > >> it was fragile and make a real attention to go softly without > >> succes... I have to send this machine back... > >> Does someone has the same experience ? > > I checked with our Mechanical Engineer on this, and he says > that there > were issues with the connector sometimes not getting seated > properly in > the cutout in the housing. There should be no electrical issues here, > purely mechanical. As Mike said, you should be able to simply > wiggle the > jack a bit and it should snap into place (I believe you would > wiggle it > gently up and down as opposed to right to left). > > I can understand Isham's concern and desire to have a perfect machine > out of the box. But if you are willing to just wiggle the connector a > bit and get it to snap into place all should be fine from > then on, and > it will save you the down time of sending the unit to get it > repaired. > But absolutely only do whatever you are comfortable with. > > We have instituted measures in Manufacturing to see that this doesn't > happen any more. I'm assuming that very few people will see > this kind of > problem. For those that have, we are of course very sorry for any > inconvenience this may have caused. > > Scott > > > > ______________________________________________________________ > __________ > ______________________________________________________________ > __________ > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > >
