Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8
2010-04-17 by frendn8
Aloha! I was wondering if anyone would be so gracious as to give me a step by step on how to get my PX-7 set up to record multiple tracks in Logic Pro 8. I want to know how to... 1) Get each track on the PX-7 to play a separate track in logic, 2) Get the PX-7 to tell logic to start the recording, 3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically)... It may sound like a noob question, but I was just hoping for a quick step by step from an experienced user. Aloha, -Nate
2010-04-21 by Aaron Eppolito
1) You need to tell Logic to "Auto demix by channel if multitrack recording" (weirdest name for "respect MIDI channels"). There's a tutorial here: http://www.logicprohelp.com/viewtopic.php?t=32201 2) Slave Logic to MIDI Clock (the clock button in the transport? I think) and tell the XL-7 to transmit MIDI clock. 3) Not sure what you mean, but there's a "transmit arps" feature on the XL-7. Note that for all of this, all of your tracks on the XL-7 will need to be set to "Both" (or ext if you don't want the internal synth) as a destination, otherwise, they'll only go to the internal synth. That said, the MUCH more accurate and reliable way to transfer tracks is via E-loader. You'll probably have to run parallels or something though. -Aaron ----- Original Message ---- From: frendn8 <frendn8@...> To: xl7@yahoogroups.com Sent: Fri, April 16, 2010 5:03:51 PM Subject: [xl7] Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8 Aloha! I was wondering if anyone would be so gracious as to give me a step by step on how to get my PX-7 set up to record multiple tracks in Logic Pro 8. I want to know how to... 1) Get each track on the PX-7 to play a separate track in logic, 2) Get the PX-7 to tell logic to start the recording, 3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically)... It may sound like a noob question, but I was just hoping for a quick step by step from an experienced user. Aloha, -Nate ------------------------------------ Yahoo! Groups Links
Resending (since my later messages showed up, but not this one - thanks yahoo.) 1) You need to tell Logic to "Auto demix by channel if multitrack recording" (weirdest name for "respect MIDI channels"). There's a tutorial here: http://www.logicprohelp.com/viewtopic.php?t=32201 2) Slave Logic to MIDI Clock (the clock button in the transport? I think) and tell the XL-7 to transmit MIDI clock. 3) Not sure what you mean, but there's a "transmit arps" feature on the XL-7. Note that for all of this, all of your tracks on the XL-7 will need to be set to "Both" (or ext if you don't want the internal synth) as a destination, otherwise, they'll only go to the internal synth. That said, the MUCH more accurate and reliable way to transfer tracks is via E-loader. You'll probably have to run parallels or something though. -Aaron ----- Original Message ---- From: frendn8 <frendn8@...> To: xl7@yahoogroups.com Sent: Fri, April 16, 2010 5:03:51 PM Subject: [xl7] Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8 Aloha! I was wondering if anyone would be so gracious as to give me a step by step on how to get my PX-7 set up to record multiple tracks in Logic Pro 8. I want to know how to... 1) Get each track on the PX-7 to play a separate track in logic, 2) Get the PX-7 to tell logic to start the recording, 3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically)... It may sound like a noob question, but I was just hoping for a quick step by step from an experienced user. Aloha, -Nate ------------------------------------ Yahoo! Groups Links
2010-04-21 by Nathaniel
Aaron, you are awesome! I'm going to try this out first thing in the morning... Well, later this morning ;) Aloha, -Nate Brevis esse laboro, obscuris fio. www.myspace.com/pulkrabek http://pulkrabek.tumblr.com/ On Apr 20, 2010, at 11:03 PM, Aaron Eppolito <synthesis77@...> wrote: Resending (since my later messages showed up, but not this one - thanks yahoo.) 1) You need to tell Logic to "Auto demix by channel if multitrack recording" (weirdest name for "respect MIDI channels"). There's a tutorial here: http://www.logicprohelp.com/viewtopic.php?t=32201 2) Slave Logic to MIDI Clock (the clock button in the transport? I think) and tell the XL-7 to transmit MIDI clock. 3) Not sure what you mean, but there's a "transmit arps" feature on the XL-7. Note that for all of this, all of your tracks on the XL-7 will need to be set to "Both" (or ext if you don't want the internal synth) as a destination, otherwise, they'll only go to the internal synth. That said, the MUCH more accurate and reliable way to transfer tracks is via E-loader. You'll probably have to run parallels or something though. -Aaron ----- Original Message ---- From: frendn8 <frendn8@...> To: xl7@yahoogroups.com Sent: Fri, April 16, 2010 5:03:51 PM Subject: [xl7] Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8 Aloha! I was wondering if anyone would be so gracious as to give me a step by step on how to get my PX-7 set up to record multiple tracks in Logic Pro 8. I want to know how to... 1) Get each track on the PX-7 to play a separate track in logic, 2) Get the PX-7 to tell logic to start the recording, 3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically)... It may sound like a noob question, but I was just hoping for a quick step by step from an experienced user. Aloha, -Nate ------------------------------------ Yahoo! Groups Links
2010-04-21 by Ivans AOL Mail
Would it be a similar process for pro-tools 8? Just started using Transfuser and its amazing. The PX-7 is an excellent controller for tranfuser (match made in heaven). I just need to figure out how to control the protools transport and make a detailed template for transfuser. From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of Aaron Eppolito Sent: Wednesday, April 21, 2010 3:51 AM To: xl7@yahoogroups.com Subject: Re: [xl7] Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8 1) You need to tell Logic to "Auto demix by channel if multitrack recording" (weirdest name for "respect MIDI channels"). There's a tutorial here: http://www.logicprohelp.com/viewtopic.php?t=32201 2) Slave Logic to MIDI Clock (the clock button in the transport? I think) and tell the XL-7 to transmit MIDI clock. 3) Not sure what you mean, but there's a "transmit arps" feature on the XL-7. Note that for all of this, all of your tracks on the XL-7 will need to be set to "Both" (or ext if you don't want the internal synth) as a destination, otherwise, they'll only go to the internal synth. That said, the MUCH more accurate and reliable way to transfer tracks is via E-loader. You'll probably have to run parallels or something though. -Aaron ----- Original Message ---- From: frendn8 <frendn8@... <mailto:frendn8%40yahoo.com> > To: xl7@yahoogroups.com <mailto:xl7%40yahoogroups.com> Sent: Fri, April 16, 2010 5:03:51 PM Subject: [xl7] Using PX-7 as a MULTI TRACK sequencer in Logic Pro 8 Aloha! I was wondering if anyone would be so gracious as to give me a step by step on how to get my PX-7 set up to record multiple tracks in Logic Pro 8. I want to know how to... 1) Get each track on the PX-7 to play a separate track in logic, 2) Get the PX-7 to tell logic to start the recording, 3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically)... It may sound like a noob question, but I was just hoping for a quick step by step from an experienced user. Aloha, -Nate ------------------------------------ Yahoo! Groups Links
2010-04-22 by Nate David
EVERYTHING WORKED!!! ...Except for the midi clock sync :(
I don't know what is up with Logic Pro 8
On the forums it says people can't get Logic to run as a slave to any of their gear. One guy said his friend does it with and MPC, but gives no details.
Went to the MPC site to see what to do and it isnt working.
Thank you for the info.
IM ALMOST THERE!!!
-Nate
Date: Wednesday, April 21, 2010, 12:51 AM
http://www.logicpro help.com/ viewtopic. php?t=32201
-Aaron
To: xl7@yahoogroups. com
Aloha!
3) Get the arps to trigger all the notes in the designated series (if that doesn't happen automatically) ...
Aloha,
-Nate
Yahoo! Groups Links2010-04-22 by Nate David
http://www.logicprohelp.com/viewtopic.php?t=22957
-Aaron
Aloha!
Aloha,
-Nate
Yahoo! Groups Links
