hard pan
hard pan
2010-04-22 by Atom Smasher
i've got 3x stereo outputs on the XL7, and onboard effects that are
nothing to brag about. so i'd like to make the most of the 6 outputs and
use external effects. i'd like to be able to use this as something like 4
mono outputs + 1 stereo pair... or even 6 mono outputs.
checking with headphones, it seems that a hard pan in the preset still
leaves quite a bit of signal on the side i'm trying to mute. is that only
an issue with headphones? is there a way around that? or am i stuck with 3
stereo outputs because i can't *really* do a hard pan all the way to
either side?
         ...atom
  ________________________
  http://atom.smasher.org/
 	"What luck for rulers, that men do not think."
 		-- Adolf Hitler
Re: [xl7] hard pan
2010-04-22 by Bob S.
If you are panning at the preset/voice level, did you pan all the layers of the voice you want to isolate?  Did you check to make sure there is no post combining of the signal or effect after the pan?  Are any of the modulation patch cords moving the pan back over (like midi note)?
I'm sure there are more things I am missing here.....
Bob
El Segundo, CA
Sent: Apr 21, 2010 11:39 PM
Subject: [xl7] hard pan
either side?
         ...atom
 		-- Adolf Hitler
Re: [xl7] hard pan
i'm starting from a default patch that i created with no effects,
patch-cords all set to "off", and only one layer.
i also tried setting the channel pan (in addition to the preset pan) to
one side... it didn't help, but if i set them to opposite sides they
cancel each other out and i get center-pan.
         ...atom
 	"Unix is simple. It just takes a
 	 genius to understand its simplicity."
 		-- Dennis Ritchie
Re: [xl7] hard pan
i'm still in the shallow end of this pool... i just set the FX to global,
set all of the sends to 0%, and now it's working as desired.
thanks for giving me a short list of things to double check. now i need to
figure out how to have one channel set the FX for a pattern... i think
that's how it's supposed to work...
         ...atom
 	"Be who you are and say what you feel, because those who
 	 mind don't matter and those who matter don't mind."
 		-- Theodor Seuss Geisel, 1904-1991
 		better known as Dr. Seuss
