effects
2010-04-22 by Atom Smasher
someone, please correct me if i'm wrong... i'm not sure if i really
understand this, or if there's a better way to do it...
in multi-mode, the XL7 can either have effect settings based on one of 63
multi-setups, *or* based on the preset used on a particular channel (or
some combination of those, but in either case the effects are determined
by either the global setting or a preset assigned to particular channel).
so... if i want to assign an effect to a pattern, i need to program the
effect into a certain preset and use that preset on the special channel
where effects are recognized.
for what i'm trying to do, it seems useful to make presets that are
"empty" of sounds, but contain effects settings, then make sure that those
presets are loaded in "tick 0" with a PC (program change) message.
the only way to do this is to record one or more notes in the "empty"
preset, then use the note editor to delete the notes.
of course i ~could~ just leave a note there... but i'd rather not. or, i
might do this on a channel that's driving an external synth, but that
synth is ignoring PC messages.
if i want to change what preset is loaded (if i want a different effect
loaded with the pattern), i would have to assign the track/channel to
"ext"; then use the event editor to edit the program change at tick 0;
then go back to the track/channel assign and set it back to "int" or
"both".
do i have that right? is there an easier way to insert a PC message at
tick 0? or, is there another way to have each pattern select effects?
even then, how do i "check" that the correct preset is being loaded,
without having to change track/channel assignments?
thanks...
...atom
________________________
http://atom.smasher.org/
"Simply stated, there is no doubt that Saddam Hussein now
has weapons of mass destruction."
-- Dick Cheney, 26 August 2002
