program changes + external gear trick
2008-05-12 by cantalopejuice
i found this here (http://www.livepa.org/board/viewtopic.php?t=2946),
and figured i'd share it with y'all since it's made my life easier:
A trick I used to use is initially record the track to an internal
instrument. This would establish a program change at time event 0.0
("tick zero") which sends the program change right before the first
beat of the sequence. If you go to the last set of params in the
pattern edit menu, you can set the destination of the current track to
'EXT'.
Important - Until you change the track to 'ext' you can't see the
program change message event at tick zero.
If you don't use this method the program change will repeat each time
and yes - it'll make it hard to audition different presets on your
external synth. Tick 0 is only played back one time when you switch
the sequence no matter how many times it loops. This is another
(somewhat hidden) feature that should steer a lot of LivePA artists to
the Command Stations.
So the way I usually work with external devices on the CS (I've been
doing this a lot lately) is to record a little phrase into the CS and
then set the track to 'ext'. Now I can audition different presets
while my little midi phrase plays back. Once I decide on the preset, I
edit the program change number in tick 0. But with this flexibility I
can still change presets on the external synth if I suddenly want a
different sound during a performance. Just be wary of switching back
and forth between sequences.
Re: [xl7] program changes + external gear trick
2008-05-12 by Aaron Eppolito
Actually, any events at tick 0 or at tick 1 will only play the first time through the loop.  We did it just for you folks with external gear!  Tick 0 is generally hidden because there's a few messages there that in general, you don't want to mess with.  The only reason you can ever see them is if you switched to external and they were still there.  This allows you to delete them without adding them.
For your purposes, you could just put stuff at tick 1 to save you the hassle of setting it to internal, recording something, saving, then switching to external.
Hidden?  Yeah, probably!  I think it's in the manual somewhere...
-Aaron
PS. Good tip!
----- Original Message ----
Sent: Sunday, May 11, 2008 5:10:23 PM
Subject: [xl7] program changes + external gear trick
'EXT'.
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
2008-05-13 by jibarosoul@aol.com
is this how you audition presets on external midi synths? Ive used a  command
station for over 7 years and could never figure this out. my asr-x pro does
this flawlessly. is there a way to simply scroll thru the prog change
parameters and change external presets? currently i have to manually scroll on my motif
rack or xv5080 and match the the lsb, msb and preset and usually the preset#
is off by one. ???
**************Wondering what's for Dinner Tonight? Get new twists on family
favorites at AOL Food.
(http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001)
2008-05-13 by Aaron Eppolito
There's not a particularly good way to audition sounds on another synth.  I suppose you could hang out in the event edit screen with the dial on a program change event at tick 1, change it, hit play and then stop 3 times quickly.
I just tried it.  It's actually kinda quick - turn then play, stop, stop, stop.  Don't have to wait; it's more like a play and stop "triple-click".
Probably not as quick as dialing the synth itself, but it'd have the advantage of saving the correct program change into the track.
-Aaron
PS. the off by one thing is because Roland thinks that people can't understand the concept of "patch 0" so they add one to the incoming MIDI messages (0-127 maps to 1-128).
Sent: Monday, May 12, 2008 5:32:50 PM
Subject: Re: [xl7] program changes + external gear trick
is off by one. ???
oh well, kind of a bummer but none the less im still very loyal. thanks for
the answer to that annoying one preset off thing. i guess yamaha is the same
cause it happens on my motif rack es. any way to correct this? V3 Aaron? well
pay!!
