Using Your XX-7 With Modules??????HELP PLEASE!!!
2006-04-21 by xxduece4xx
how do you make it so when you are using an external module you can save your sequence on the xx-7 and it will automatically switch to the correct module patches next time you load your sequence again?? i heard it had to do with bank numbers or something? how do you change those or whatever??
2006-04-21 by Bob S.
Save the Multi-setup, go to Global and Name & Save....You can save a number of different patch to channel assignments Bob Corona/Riverside, CA
----- Original Message ----- From: xxduece4xx To: xl7@yahoogroups.com Sent: Thursday, April 20, 2006 10:19 PM Subject: [xl7] Using Your XX-7 With Modules??????HELP PLEASE!!! how do you make it so when you are using an external module you can save your sequence on the xx-7 and it will automatically switch to the correct module patches next time you load your sequence again?? i heard it had to do with bank numbers or something? how do you change those or whatever?? Yahoo! Groups Links [Non-text portions of this message have been removed]
2006-04-21 by Alien
I never had a need to do this so never explored the area. But, if I'm
understanding you correctly Bob, that would mean that it would become
impossible to do things such as have the patches saved on a pattern by
pattern basis or to have the patch changes occur when X-Mix is used.
Am I understanding you correctly here?
Al
> Bob
> From: xxduece4xx
the > correct module patches next time you load your sequence again?? i > heard it had to do with bank numbers or something? how do you change > those or whatever?? > > > > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] >
2006-04-21 by Aaron Eppolito
Switch your tracks that target the external gear to be "external" in the 2nd to last pattern edit screen. Then, in the event editor (the next screen to the left, i.e. 3rd to end) insert a program change event. You will have MSB, LSB and ProgCh which, if you're using an E-mu external synth, you can discern by pressing Audition on the external box. For E-mu stuff, the MSB is the ROM ID, LSB is the bank number (0-3 - the last digin in the "113^2" display), and Prog is the 0-127 number. -Aaron --- xxduece4xx <lild_soldier11@...> wrote: > how do you make it so when you are using an external module you can > save your sequence on the xx-7 and it will automatically switch to > the > correct module patches next time you load your sequence again?? i > heard it had to do with bank numbers or something? how do you change > those or whatever?? > > > > > > > Yahoo! Groups Links > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2006-04-22 by David Fernandez
i still cant seem to figure it out... how do i change the patches on my roland xv5050 from my command station via midi so i can save those bank numbers and stuff.. when i tried the event change thing it didnt change anything
Sent: Thursday, April 20, 2006 11:07 PM
Subject: Re: [xl7] Using Your XX-7 With Modules??????HELP PLEASE!!!
Bob
those or whatever??
Yahoo! Groups Links
YAHOO! GROUPS LINKS
a.. Visit your group "xl7" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[Non-text portions of this message have been removed]2006-04-22 by Alien
Is your XV configured to receive Program Changes? -Al --- In xl7@yahoogroups.com, "David Fernandez" <lild_soldier11@...> wrote: > > i still cant seem to figure it out... how do i change the patches on my roland xv5050 from my command station via midi so i can save those bank numbers and stuff.. when i tried the event change thing it didnt change anything > ----- Original Message ----- > From: Bob S. > To: xl7@yahoogroups.com > Sent: Thursday, April 20, 2006 11:07 PM > Subject: Re: [xl7] Using Your XX-7 With Modules??????HELP PLEASE!!! > > > Save the Multi-setup, go to Global and Name & Save....You can save a number of different patch to channel assignments > > Bob > Corona/Riverside, CA > > ----- Original Message ----- > From: xxduece4xx > To: xl7@yahoogroups.com > Sent: Thursday, April 20, 2006 10:19 PM > Subject: [xl7] Using Your XX-7 With Modules??????HELP PLEASE!!! > > > how do you make it so when you are using an external module you can > save your sequence on the xx-7 and it will automatically switch to the > correct module patches next time you load your sequence again?? i > heard it had to do with bank numbers or something? how do you change > those or whatever?? > > > > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "xl7" on the web. > > b.. To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- -----------
2006-04-25 by David Fernandez
yea
Sent: Saturday, April 22, 2006 11:50 AM
Subject: [xl7] Re: Using Your XX-7 With Modules??????HELP PLEASE!!!
-Al
> From: Bob S.
PLEASE!!!
> Bob
> From: xxduece4xx
you can
switch to the
again?? i
change
> those or whatever??
> YAHOO! GROUPS LINKS
of Service.
YAHOO! GROUPS LINKS
