keyboard transmitting midi out
2005-08-13 by malik
2005-08-13 by malik
hi i knew that i had this worked out before but i just came from a long break from music to learn some c++(for music) and now i dont know how to make the presets transmit midi. i looked through the manual but didnt find anything. i guess i could just turn the preset menu volume down but is there another way?
2005-08-13 by malik
--- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote: > hi i knew that i had this worked out before but i just came from a > long break from music to learn some c++(for music) > and now i dont know how to make the presets transmit midi. i looked > through the manual but didnt find anything. i guess i could just turn > the preset menu volume down but is there another way? im sorry to try to be more clear i want the preset to transmit midi while turning the keyboard transmit midi option of so that only certain channels will allow me to transmit.
2005-08-14 by steve_the_composer
I hope this helps: ======================================= PRESET = the set of parameters that tell the synth engine how to construct sound. One sub-set of preset parameters is called ARP [arpeggiator]. A different preset parameter is RIFF. Are you trying to send the midi data from (1) the arp, (2) the riff or (3) both to an external device [sound module]? At the same time are you wanting the synth engine of your E-Mu to produce no sound? =============== OR ==================== Do you want the sequencer to transmit midi data to an external device? =============== OR ==================== Or do you want to do something different? (And if so, what is it you are trying to do?) ======================================= --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote: > > hi i knew that i had this worked out before but i just came from a > > long break from music to learn some c++(for music) > > and now i dont know how to make the presets transmit midi. i looked > > through the manual but didnt find anything. i guess i could just > turn > > the preset menu volume down but is there another way? > > im sorry > to try to be more clear i want the preset to transmit midi while > turning the keyboard transmit midi option of so that only certain > channels will allow me to transmit.
2005-08-14 by greg bosc
--- malik
to do so you have to go in pattern menu or global menu
(i don't have the machine with me here)
then scroll to 01 transmit to channel 1A and select
external so midi message is transmitted only to
external device 1A for midi channel A or to anny 32
midi channels .by default is set to both means
internal and external ......
<malik_martin@...> a \ufffdcrit :
just came from a
midi. i looked
i could just
turn
way?
im sorry
midi while
only certain
YAHOO! GROUPS LINKS
Visit your group "xl7" on the web.
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
T\ufffdl\ufffdchargez cette version sur http://fr.messenger.yahoo.com2005-08-15 by malik
> Do you want the sequencer to transmit midi data to an external device? > > =============== OR ==================== > > Or do you want to do something different? (And if so, what is it you > are trying to do?) > > ======================================= both of these actualy. what i used to do before was have the mp-7 send midi to an external device via pattern sequences and also have some channels to play internaly. my problem at the moment is i want to be able to control some things from the mp-7 but i want to be ablee to switch the mp7 to tracks where the pads will only transmit internaly. the dialouge bob was talking about "should" be my answer. cause as far as i can remember thats what i used to use with no problems. but maybe my ideas for a setup have gotten more complex im not sure...
2005-08-15 by malik
did i say bob? i meant greg! im sorry!! :) --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote: > > > > Do you want the sequencer to transmit midi data to an external > device? > > > > =============== OR ==================== > > > > Or do you want to do something different? (And if so, what is it you > > are trying to do?) > > > > ======================================= > > > both of these actualy. what i used to do before was have the mp-7 send > midi to an external device via pattern sequences and also have some > channels to play internaly. my problem at the moment is i want to be > able to control some things from the mp-7 but i want to be ablee to > switch the mp7 to tracks where the pads will only transmit internaly. > the dialouge bob was talking about "should" be my answer. cause as far > as i can remember thats what i used to use with no problems. but maybe > my ideas for a setup have gotten more complex im not sure...
2005-08-15 by malik
coulda swore i just replied to this but the messagge didnt show up. what i said was this is the dialouge im looking for but for some reason i cant find it in the midi, controllers, preset, and global menus. maybe there's something i have enabled that doesnt permit me to access these options?? --- In xl7@yahoogroups.com, greg bosc <letsgrowhi@y...> wrote: > > --- malik > > to do so you have to go in pattern menu or global menu > (i don't have the machine with me here) > then scroll to 01 transmit to channel 1A and select > external so midi message is transmitted only to > external device 1A for midi channel A or to anny 32 > midi channels .by default is set to both means > internal and external ...... > > <malik_martin@h...> a écrit : > > > --------------------------------- > --- In xl7@yahoogroups.com, "malik" > <malik_martin@h...> wrote: > > hi i knew that i had this worked out before but i > just came from a > > long break from music to learn some c++(for music) > > and now i dont know how to make the presets transmit > midi. i looked > > through the manual but didnt find anything. i guess > i could just > turn > > the preset menu volume down but is there another > way? > > im sorry > to try to be more clear i want the preset to transmit > midi while > turning the keyboard transmit midi option of so that > only certain > channels will allow me to transmit. > > > > > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "xl7" on the web. > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! > Terms of Service. > > > --------------------------------- > > > > > > > > > > _____________________________________________________________________ ______ > Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger > Téléchargez cette version sur http://fr.messenger.yahoo.com
2005-08-15 by steve_the_composer
Since I have the P2500 Command Module [no pads] I'm not sure I can help with the issue of routing the pads, but perhaps this post will help on the issue of sequencer track assignments: http://launch.groups.yahoo.com/group/xl7/message/15914 See also the discussion under the subject "Sequencing Hell." With the pads, my guess (Can someone else confirm this?) is you want to have Rechannelize On so they will send midi data to where you want (either external gear or the internal synth engine) based on your CHANNEL assignment. (Note: I believe you are talking about CHANNEL functionality, not TRACK functionality.) Hope this helps. --Steve --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote: > what i used to do before was have the mp-7 send > midi to an external device via pattern sequences and also have some > channels to play internaly. my problem at the moment is i want to be > able to control some things from the mp-7 but i want to be ablee to > switch the mp7 to tracks where the pads will only transmit internaly.
2005-08-16 by malik
lol somethings wrong with me thanks!!! --- malik so check in pattern menu scroll till the end of the menu <malik_martin@...> a écrit : > --- In xl7@yahoogroups.com, greg bosc > <letsgrowhi@y...> wrote: > > > yeah greg thats the exact dialouge im looking for > but i dont see > it!!!! > > i guess i dont know where to find it anymore but i > have been looking > through the preset. midi , controllers, and global > menus for days!! > there must be something i have set that doesnt allow > me to access > it. i'll have to have another look in the manual > thanks guys!!! > > > --- malik > > > > to do so you have to go in pattern menu or global > menu > > (i don't have the machine with me here) > > then scroll to 01 transmit to channel 1A and > select > > external so midi message is transmitted only to > > external device 1A for midi channel A or to anny > 32 > > midi channels .by default is set to both means > > internal and external ...... > > > > <malik_martin@h...> a écrit : > > > > > > --------------------------------- > > --- In xl7@yahoogroups.com, "malik" > > <malik_martin@h...> wrote: > > > hi i knew that i had this worked out before but > i > > just came from a > > > long break from music to learn some c++(for > music) > > > and now i dont know how to make the presets > transmit > > midi. i looked > > > through the manual but didnt find anything. i > guess > > i could just > > turn > > > the preset menu volume down but is there another > > way? > > > > im sorry > > to try to be more clear i want the preset to > transmit > > midi while > > turning the keyboard transmit midi option of so > that > > only certain > > channels will allow me to transmit. > > > > > > > > > > > > --------------------------------- > > YAHOO! GROUPS LINKS > > > > > > Visit your group "xl7" on the web. > > > > To unsubscribe from this group, send an email > to: > > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the > Yahoo! > > Terms of Service. > > > > > > --------------------------------- > > > > > > > > > > > > > > > > > > > > > _____________________________________________________________________ > ______ > > Appel audio GRATUIT partout dans le monde avec le > nouveau Yahoo! > Messenger > > Téléchargez cette version sur > http://fr.messenger.yahoo.com > > > _____________________________________________________________________ ______ Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger Téléchargez cette version sur http://fr.messenger.yahoo.com | | | | | Inbox Get the latest updates from MSN MSN Home | My MSN | Hotmail | Search | Shopping | Money | People & Chat Feedback | Help © 2005 Microsoft TERMS OF USE Advertise TRUSTe Approved Privacy Statement Anti-Spam Policy
2005-08-16 by malik
i think i founf the answer steve thanks will let you know what i find. gotta make my new live setup --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...> wrote: > Since I have the P2500 Command Module [no pads] I'm not sure I can > help with the issue of routing the pads, but perhaps this post will > help on the issue of sequencer track assignments: > > http://launch.groups.yahoo.com/group/xl7/message/15914 > > See also the discussion under the subject "Sequencing Hell." > > With the pads, my guess (Can someone else confirm this?) is you want > to have Rechannelize On so they will send midi data to where you want > (either external gear or the internal synth engine) based on your > CHANNEL assignment. (Note: I believe you are talking about CHANNEL > functionality, not TRACK functionality.) > > Hope this helps. > > --Steve > > > > > > > > > --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote: > > what i used to do before was have the mp-7 send > > midi to an external device via pattern sequences and also have some > > channels to play internaly. my problem at the moment is i want to be > > able to control some things from the mp-7 but i want to be ablee to > > switch the mp7 to tracks where the pads will only transmit > internaly.
