(no subject)
(no subject)
2005-08-12 by greg bosc
I .just getting my XL-7 ,i don't manage syncronise it
with cubase ....
even if we choose the tempo manually a little decay
between the two sequencer make it very harassing ....
this is if i try xl-7 as a slave ......
then xl-7 as a master even worse nothing get to sound
and xl-7 remain stucked .
if anybody could help me found a link or a location
were we can learn from using xl-7 with some softs.
thanks
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
T\ufffdl\ufffdchargez cette version sur http://fr.messenger.yahoo.com
Re:
2005-08-13 by zerolatencyproductions
I think the problem is happening because the Merge Midi In to Out is
not set properly.  What happens is the MIDI coming from the
sequencer or XL-7 gets caught in a MIDI loop.  The information being
received gets copied and sent backout, which is recieved, copied,
and sent backout again.  That causes the effect of delay or in most
cases MIDI crash, in which the midi signal is to large and the
system freezes or becomes stuck.  Press the MIDI button on your XL-
7, scroll till the screen reads MERGE MIDI IN TO OUT and make sure
the midi output going from your XL-7, back to the sequencer is
turned OFF.  Hope this helps.  Brandon.
> with cubase ....
> thanks
______
Messenger
> Téléchargez cette version sur http://fr.messenger.yahoo.com
RE: [xl7] Re:
2005-08-14 by greg bosc
--- zerolatencyproductions
<zerolatencyproductions@...> a \ufffdcrit :
thanks for your help but this not help^.
if i had to choose i would like the xl7 to be the
master of the system .and the midi merge option not
change anything to it .even the rechanelize is set to
off.
Midi In to Out is
from the
information being
recieved, copied,
delay or in most
and the
button on your XL-
and make sure
sequencer is
it
> with cubase ....
sound
> thanks
______
nouveau Yahoo!
Messenger
  YAHOO! GROUPS LINKS
    Visit your group "xl7" on the web.
    Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Re:
2005-08-15 by malik
i've never had my merge midi enabled and i still get crashes. so far
only hen using fl studio.
--- In xl7@yahoogroups.com, "zerolatencyproductions"
is
being
most
> > with cubase ....
> > thanks
> ______
> Messenger
(no subject)
2005-08-15 by malik
> thanks
i will try to use some midi plugins and see what happens for me.
re no subject
2005-08-16 by malik
http://www.tobybear.de/p_mcc.html
try this i will soon
> > thanks
re no subject
2005-08-16 by malik
hmm i dunno how to make this accept midi inputs will search again
> > thanks
