alternative to MidiOx
2005-07-31 by danieljtb
Hi all   need to hava a simple to use software program to backup my
user presets to...have midiox, but not knowing anything about midi.....
any good programs easier to use than midiox   any free sequencers
thanks Dan
Re: alternative to MidiOx
2005-07-31 by zerolatencyproductions
Hello Dan,
E-Loader is super easy to use for organizing and backing up your
patterns and songs.  It is also great for transfering all the midi
info instantly to a computer based sequencer.  Unfortunatly, E-
Loader doesn't allow you to save your preset banks, which is what
you want to do.  I have Cakewalk HS and using that I'm able to
download System Exclusive Data enabling me to create backups for my
user presets.  Sounds difficult, but its not.  I hadn't heard of
MIDIOX until I read your post, so I thought I would check it out.
To tell you the truth it was just as easy to create the user preset
backups on MIDIOX as Cakewalk.   You shouldn't have much trouble if
you follow these directions step by step.  Once you know how to do
it, its fast and easy.  Here's how.
Make sure the MIDI cables are connected properly.
Then in MIDIOX go to the "Options" menu and select "MIDI Devices"
In "MIDI Devices" make sure the correct MIDI inputs and outputs are
selected.
Next go back into the "Options" menu and make sure the "Pass Sysex"
has a check mark next to it.
You should only have to set-up that stuff once; not everytime you
want to do something using MIDIOX.  Plus, those are the same things
you would have to do in all other sequencing programs.  I had to do
all that in Cakewalk, too.  Now on to dumping the presets into
MIDIOX for saving.
Go to the "View" menu and select "SysEx"
A window called "SysEx View and Scratchpad" appears.
Go to its "SysEx" menu and select "Receive Manual Dump"
A window called "SysEx Receive" pops-up and it should say (waiting
for completion) 0 bytes received.  Now MIDIOX is ready, all you have
to do is tell the Command Station (XL-7, ect.) to send the
information.  This is how you do it.
Go into the MIDI menu by pressing the MIDI button on your Command
Station.
Using the scroll wheel, scroll till the menu reads "Send MIDI SysEx
Data" and press the cursor key to move the cusor down.
Here you can use the scroll wheel to select different types of SysEx
Data to be sent.  Scroll till you see "Bank X User Presets" (X
standing for the bank of presets you want to send) You will also
notice that you can send one specific user preset at a time if you
scroll just a little bit further.
Once you've decided which preset or bank of presets you want to send
press the Home/Enter button which should be blinking.
Instanly the download will begin and you should notice the "SysEx
Receive" window in MIDIOX, that previosly said (waiting for
completion) 0 bytes received, is now receiving bytes.  The process
could take a couple of minutes depending on what you decided to
send/receive.  When the Command Station stops sending information,
you may have to press done in MIDIOX eventhough it still says
(waiting for completion).
Once MIDIOX has finished receiving all the data, Go to the "Display
Window" menu and select "Save As".  Then name the file whatever you
want.
Now if you want to reload the saved presets from MIDIOX onto your
Command Station, here is what you do.
Get to the "SysEx View and Scratchpad" window like you did previosly
by going to the "View" menu and selecting "SysEx".
Then in the "SysEx View and Scratchpad" window, go to the "File"
menu and select "Send SysEx File".  A list of files will pop-up
among them should be the file you saved your presets as.  Make sure
you are selecting the correct file, cause it will instantly start
the transfer of information to your Command Station.  Your Command
Station doesn't have to be in any specific mode to allow this to
happen.  You could have just turned it on or be in any of the menus
or screens.  There is one thing you should be carefull of.  The
transfer will replace/erase any preset which is in that spot being
downloaded.  Meaning if you have new kickass presets in say 001-012
of bank 0, and you download a previously saved version of bank 0
from MIDIOX or other software, it will erase your kickass presets
and replace them with the older ones.  So it might be a good idea to
make a back-up of whatever new presets you got before downloading
previous versions.
I know it sounds like alot, but it only takes a couple of seconds
once you've actually done it before.  It would be cool if E-MU came
out with an updated version of E-Loader that allows us to save the
presets.  Anyways, I don't know if there is any easier ways of doing
it.
Also, I happened to find a decent free sequencer program.  I haven't
used it myself, but its spec's are great for a free sequencer and
there are no restrictions.  Its not really made for audio recording,
but its got the capability of one-one minute audio track.  So if
your interested here is the link.
http://www.anvilstudio.com/upgraden.htm
Goodluck Bro!
midi.....
> thanks Dan
2005-07-31 by gonzinigonz
Hi
dumpster.zip in the files / apps section of this group.
Ive used it for years. you can edit its ini file to automate dumping
and requesting sysex for any midi device.
you wont find anything more basic and useful.
cheers
gonz
midi.....
> thanks Dan
Re: [xl7] Re: alternative to MidiOx
2005-07-31 by ByronIV
Check out Seq303 in terms of sequencers, if what you're looking for is
something to write sequences on to send TO the XL7....I use it quite
often for such, I don't even import the midi into the XL7, I just play
it right in from Seq303.
It's strictly an analog style sequencer though, not sure if you were
referring to a multi-track program or something.
ByronIV
For your electronik listening pleasures
http://www.limbikfreq.com
Mindset Studio Music and Media
http://www.mindsetstudio.com
