trigger Battery in Sonar using the pads on my XL7 - how?
Re: trigger Battery in Sonar using the pads on my XL7 - how?
2005-04-23 by steve_the_composer
Not sure I can help, but I am curious:
What version of Sonar do you have? (I have Sonar 3.)
Are you talking about using Sonar's Control Surfaces?
What are you to do?
--Steve
--- In xl7@yahoogroups.com, "dwoodaman" <dwoodaman@y...> wrote:
> If anyone could give me some assistance on this I would be most
> appreicative.
> thanks
2005-04-24 by dwoodaman
I am using Sonar 4.1 - I didn't even think about the control surfaces,
doh! But I have never used them anyway.
What I want to do is use the trigger pads to trigger the cells in
Battery. I figure if I can do this right, I should be even able to
switch octives, so I could "play" battery just like I play the pads to
write beats on the XLs internal sounds.
Does that make sense?
thx
> What are you to do?
> --Steve
> > appreicative.
> > thanks
