-Thanks Gonz, any idea where I might be able to find a World
Expedition ROM? -- In xl7@yahoogroups.com, Hendrex Zappa
<guruinu2@y...> wrote:
> Thanks Gonz! Any idea where I could get a World Expedition ROM?
> gonzinigonz <gonzini@f...> wrote:Hi
> Yes you can pull the ones you dont want out and leave the Beat
Garden
> rom in there.
> Dont think the any of the roms will acutally say what they are on
> them so it could be a bit hit or miss if you leave the correct one
in
> there.. (not sure what code numbers would be on there either..)
> The unit seems to change the order of them in respect to how it
see's
> them, so they dont appear in slot order.. (0, 1, 2, 3)
> Theres 8 screaws underneath the unit, so flip the unit over and
place
> on something soft to protect the front panel knobs.
> Take the formentioned screaws out, then you will be able to open
> 2 halfs like a book. Carefull as there are ribbon cables between
> them.. it will only open out 1 way because of these.
> You will see the roms in one of the corners on the PCB, they look
> like simm modules and there are 4 slots.
> Unplug the unit from the mains..
> Make sure you earth yourself to discharge any static that you may
> have picked up of a carpet etc. The roms and the command station
> could be damaged by static, its the same as changing anything in
your
> PC.
> They unclip the same as simm memory modules, fitted is the same in
> reverse.
> Check to see that all the ribbon cables are pushed home as well
> before re-assembly.
> Make sure you tighten the screaws back down when you put the unit
> back together.. you may well get an anoying hum if you dont!
> Good luck!
> Gonz
> --- In xl7@yahoogroups.com, "guruinu2" <guruinu2@y...> wrote:
> > Greetings, I just (about an hour ago) bought an MP-7 on E-Bay
with
> > installed Roms X-Lead, Sounds Of ZR, Beat Garden and Siedlaczek
> > Orchestra (not installed). The only ROM I am interested in
keeping
> is
> > Beat Garden. Can I take out all the other ROMS including the MP-7
> Mo
> > Phat to Make room for the other ROMS that I want (Protazoa, World
> > Expedition, Beat Garden and Protean or do I need to keep the MP-
7
> > ROM that makes it what it is installed? I am guitarist with very
> > little synth experience as I am sure you can tell. Thanks in
> > advance,SCB
> Yahoo! Groups SponsorADVERTISEMENT
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/xl7/
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> ALL-NEW Yahoo! Messenger - all new features - even more fun!
