Preset users
Preset users
2004-07-05 by Whoïo
Hi!!
I would like to know if someone has already created an "empty bank user"
sysex files??? I would like to replace all the users presets with a blank preset,
and I don't want to do copy/paste with 3x127 presets... THX
Enhmy
Re: [xl7] Preset users
2004-07-06 by erik_magrini@Baxter.com
Yes, there is a blank Preset Bank in the files section of this group that
you can use for this.  Load this into the XL-7, and then use the Copy Bank
command from the Save menu to copy it to your other User Banks.
"Whoïo" <enhmy@...>
07/05/2004 03:09 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Preset users
Hi!!
preset,
Enhmy
Yahoo! Groups Links
material from any computer.
For Translation:
Re: Preset users
2004-07-06 by gonzinigonz
Hi, so you can over write the original emu patch banks, is that
correct?
Also is it possible to completey edit the drum kits in there, ie
start from scratch and create your own with what ever samples are
present on the roms you have installed?
Still waiting on my XL-7 to turn up...
Regards
Gonz
group that
Copy Bank
> rEalm
> "Whoïo" <enhmy@y...>
> 07/05/2004 03:09 PM
>         cc:
> Hi!!
user"
blank
> preset,
> Enhmy
entity
legally
than
privilege
other
by
> For Translation:
Re: [xl7] Re: Preset users
Hi, so you can over write the original emu patch banks, is that correct?
>>>Yes and no.  The Factory Preset Banks that come with each ROM cannot be
overwritten, but they are also copied to the User Banks when you buy a new
Command Station.  It's the Presets that have been copied to the User banks
that can be overwritten. <<<
Also is it possible to completey edit the drum kits in there, ie start
from scratch and create your own with what ever samples are present on the
>>>Not directly no, you're stuck with whatever is assigned in each Preset
to some extent.  Each Preset (including Drum Presets) are made up of 4
layers.  You can mix and match layers (the Protean Drum ROM is excellent
for this BTW), and transpose each layer too, in addition to being able to
layer up to 3 Presets at once.  This basically gives you 12 layers to use
in making up your own kits.  If you're just waiting for your XL-7 to
arrive, mioght not hurt to DL the manual and start reading so you can be
up to speed when it arrives :) MIght want to get the FAQ and Tips and
Tricks docs too from the files section of this group. <<<
use of, or taking of any action in reliance upon, this information by
For Translation:
Re: Preset users
2004-07-07 by gonzinigonz
Ok thanks for that, think it will make more sense when i can see it
in front of me..
Ive flicked through the PDF of the manual to see what it can do..
Find it a bit hard to read it off the screen, better with a real
manual for me. Maybe l'll have another go with it.
Cheers for your responce, i think ive had a look at the tips and
tricks and FAQ's..
Regards
Gonz
correct?
cannot be
buy a new
User banks
start
on the
Preset
of 4
excellent
able to
to use
to
can be
and
> rEalm
entity
legally
than
privilege
other
by
> For Translation:
Re: Preset users
2004-07-07 by Whoïo
Thank you rEalm,
I am going to try this tonight..
If it's work, I will venerate you :)
Cheers
Enhmy
> Yes, there is a blank Preset Bank in the files section of this group that=
> you can use for this.  Load this into the XL-7, and then use the Copy Ban=
k
> rEalm
> 07/05/2004 03:09 PM
>         cc:
> Hi!!
> I would like to know if someone has already created an "empty bank user" =
> sysex files??? I would like to replace all the users presets with a blank=
> preset,
> Enhmy
> For Translation:
