SOMETHING WENT WRONG WITH MY OS UPDATE!
2003-09-03 by ceonubeat
I WAS TRY 2 UPGRADE MY MP-7 WITH 2.0V AND IT GOT STUCK IN THE OS
MODE,I TRYIED CUTTING IT OFF BUT IT STILL IN OS MODE CAN ANY1 HELP?
RE: [xl7] SOMETHING WENT WRONG WITH MY OS UPDATE!
2003-09-03 by Oscar Finch
Have you checked the doc on the Emu site?
Command Stations with OS1.3 or lower need an extra file.
Apparently the newer OS's are in a binary compressed format the original units below 1.73 (from memory recollection could be wrong on the number) will not upload correctly without the first data file stream fed into the unit.
I luckily got mine with OS2.0 preloaded ;) - save some hassles I'd well imagine.
The addendum only for the OS2.0 update featues are in PDF download files (22 page doc) on the same page of the Emu site.
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
2003-09-03 by calvin alley
SO CAN THE PRBLEM BE FIXED OR I HAVE TO SEND IT 2 TECH SUPPORT
Yahoo! Groups SponsorADVERTISEMENT
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
2003-09-03 by erik_magrini@Baxter.com
Go to the files section of this site:
http://groups.yahoo.com/group/xl7/files/Command%20Station%20Data/
And download these two files:
commandprep10.zip
OS 2.0 and Addendum.zip
Once you get those, unzip them and install the commandprep10 file first,
then the OS 2.0 file.
