you can reinitialize - by entering the diagnostics menu as mentioned
by malik - power off ... press and hold the cursor arrow buttons then
power on to startup - There are two Reinitializecommands. The first
(#16) will erase all the Patterns and Songs. The second *(#17) is the
common User Reinitialize command. Selecting #17 - "INIT DATA EXCEPT
SEQ" will overwrite the RAM Presets (sounds) with factory preset
data, but will leave the Pattern and Song data untouched - so you can
erase first and before going to 18 (reboot) go to 17 ... and then do
18 reboot ... hope that helps here is a link to check out
http://dmzweb3.europe.creative.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?
St=448,E=0000000000050468658,K=4792,Sxi=0,Case=obj
(456),VARSET=centric:560,Kb=creative_emu
--- In xl7@yahoogroups.com, stot ham <astot73@y...> wrote:
> Hi
> How do you restore to factory install?
