On 1/4/05 1:23 PM, "grantrichter2001" <grichter@asapnet.net> wrote:
> Thank to the National Deficit, your new $300 is only worth an old
> $200...
> Not really kidding, unfortunately.
> --- In wiardgroup@yahoogroups.com, "the finger"
> <pedro.monkeyfinger@h...> wrote:
>>> $312 via Paypal
that's really a shame, and just as Doepfer was gettiing pricey due to the
weak amkerikan $ I was hoping we had an advantage! I really liked the sub
$200 mark.The Boogie sounds/looks great but at over $200 I can't justify
another filter. I still kinda think the 1200 should still be a scaled down
version of the 300.
-pH
John Simonton of PAIA originated an inexpensive 19" rack
mounting system he dubbed the Frac-Rac. This is based on a
5.25" panel height with width multiples of 1.5", 3" and 4.5"
John Blacet went on to develop an very elegant power supply
distribution system, and a bunch of great modules, including two
modules developed along with Wiard: The Mini-Wave module
and the VCO.
The single improvement I could make to the Frac-Rac system, is
to make it so the modules could mount vertically in a Frac-Rac,
or lay down in a shallow desktop enclosure. This could sit in
front of another modular, and provide controllers and advanced
voltage sources.
This would be a modular equivalent of the "Dual Joystick Manual
Controller" that was discontinued.
The faceplates will look like miniature Moog 900 modules (which
is what the 300 series prototype looked like) and to the extent
practical, be capable of being fitted with 3.5mm, banana or 1/4"
connectors. A depth of 1.5" will allow Switchcraft 1/4" jacks for
support of MOTM systems.
John Blacet uses a 0.062" panel thickness because the printed
circuit board is used to stabilize the faceplate against bending.
(and a damn fine piece of engineering it is too). In order to fit a
1.5" depth, the PCB will need to mount horizontally, parallel with
the faceplate. Because of this, the faceplate thickness will be
increased to 0.100" for adequate rigidity.
Useful modules would be:
A nice Joystick (Model 1209B, now shipping)
A fun random voltage/noise source (Noize Ring Model 1210)
A module to control an entire patch with one Joystick
(Joystick Axis Generator Model 1211)
A Universal level and impedance matching module which will let
any type modular talk easily to any other type modular (Active
Multiple)
A CV/Audio mixer module with some cool twist (prototyped, but
needs more fun value)
All modules should be under $200.
So that is the general plan at this point. Produce a set of
Frac-Rac or tabletop modules in Moog 900 color scheme, that
support any connector type and are usable with anyones
modular synthesizer, new or old.
Note that while I would like to support the Buchla 100 and 200
series, they are so ungodly expensive that Wiard can not afford
the liability of connecting to them. So, no Buchla support unless
you sign a 7 page legal document (in blood), promising not to
sue me no matter what happens.
