Index last updated: 2026-04-28 23:40 UTC
Suddenly out of tune -but still problems after changing PC-1 and R93
2008-08-15 by hjulskov
My PolySix suddenly got out of tune, so I changed PC-1 to a VTL5C3 and
R93 to a 1K2 resistor. However the PolySix still sounds terrible.
Any suggestions for what to look for ?
I have a multimeter if there is anything you suggest me to check.
Thanks in advance,
Peter
Re: Suddenly out of tune -but still problems after changing PC-1 and R93
2008-08-16 by Andrew Jury
Hi Peter,
So we'll assume the changing those two components made no difference
and you are still left with the original problem? Can you confirm that
all of the voices appear as off key as one another? (i.e, put the P6
into unison mode, turn the cutoff to 10 and press C3 over and over and
compare each voice, etc. They all sound just as bad as one another?)
if so, check section 8 of the service manual and make sure all of the
voltages are within spec. Make sure the supplies to IC17/18/19 are
accurate. Also, make sure that demultiplexer IC31 is doing its job. 5V
should appear alternately on pins 13, 14, 15, 12, 1 and 5 when C8
pressed. Have a look around this part of the circuitry on the KLM-366
board and see if the voltages look correct.
Report back your findings and we'll have another head scratch if all
looks well.
Cheers,
Andy
> Thanks in advance,
> Peter
2008-08-17 by hjulskov
Thanks a lot Andy! :-)
All voices sounds equally bad.
Here are my readings (after at least 10 min. warm-up):
TP-J7 = 14.94V OK
TP-R18 = -14.93V OK
TP-J2 = 4.97V OK
TP-J1 = -4.96V OK
IC31 (first pin (lower left) = 0)
1: -8.05V constant (no change if C8 or other key is pressed)
5:  -8.05v constant (no change if C8 or other key is pressed)
12: -8.05v constant (no change if C8 or other key is pressed)
13: -8.05v constant (no change if C8 or other key is pressed)
14: -8.05v constant (no change if C8 or other key is pressed)
15: -8.05v constant (no change if C8 or other key is pressed)
16 (upper left pin): 4.96v constant
IC17 (upper left pin)
4.96V constant
IC18 (upper left pin)
14.91V Constant
IC19 (upper left pin)
14.91V constant
Looks like the IC31 is bad?
Cheers
Peter
> looks well.
2008-08-18 by Andrew Jury
Hi Peter,
I am afraid we can't make that assumption until the logic that controls
IC31 has been tested. This device is basically a switch. You apply a
binary pattern to lines A, B, C and INH and this determines which one
of the outputs is connected to the input. The input is marked X the
outputs marked X0, X1, X2, etc. It is the outputs which we just tested
and which don't seem to move. Tell me, do the voice LEDs (D10) come on
in order in Unison mode? Everytime you press a key an alternate voice
LED should light up. I suspect not?
Can you lay your hands on a logic probe at all?
Cheers,
Andy
2008-08-20 by hjulskov
Thanks Andy,
The LEDS (D10) does light in order in polymode (which I think was what
you meant?) -in unison they all light simultaniously.
In Polymode all voices sounds equally (bad).
I'm not sure about your last question (Can you lay your hands on a
logic probe at all?)?
Cheers,
Peter
> Hi Peter,
> Cheers,
> Andy
Re: [PolySix] Re: Suddenly out of tune -but still problems after changing PC-1 and R93
2008-08-20 by Chromatest J. Pantsmaker
A logic probe is an electronic testing tool.
On Wed, Aug 20, 2008 at 11:44 AM, hjulskov <hjulskov@yahoo.com> wrote:
> Thanks Andy,
> Cheers,
> Peter
>> Hi Peter,
>> Cheers,
>> Andy
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links
.sig
-Chromatest J. Pantsmaker
http://www.chromatest.net
2008-08-20 by Andrew Jury
Peter,
The logic probe measures whether logic states in TTL or CMOS
circuitry are a binary 1 or 0. Remember we talked about how the
binary pattern on lines A, B, C, INH set which outputs on IC31 are
selected? This tool would tell us how they are set and whether they
were switching on a the right time.
However, from the description how the six LEDs are lighting up (yes,
one after the other in POLY mode - I am an idiot!) it sounds like
IC31 is working correctly and keyboard assigner is sending the right
binary pattern to the switch.
I expect the input on pin 3 is the problem. What I will do is take
some reading from my working Polysix and let you know how the
circuitry should function. I'll post this after the weekend, if you
can wait.
Also, I'll take you are playing with the settings in manual mode and
not from the patch banks? When the SRAM (memory) failed on my P6 the
patch banks just contained random bit patterns which produced sound
which could be very much be described as 'out of tune'! Just a
thought...
Cheers,
Andy
> Thanks Andy,
what
> Cheers,
> Peter
> --- In PolySix@yahoogroups.com, "Andrew Jury" <andy@> wrote:
> > Hi Peter,
controls
apply a
one
tested
come on
voice
> > Cheers,
> > Andy
2008-08-21 by Andrew Jury
Hi Peter,
Your P6 problem is really starting to bug me! Could you take a
voltage measurement from IC17 between pins 5, 6, and 7 and ground? It
will be interesting to see what is going into the mux.
Cheers,
Andy
> Peter,
(yes,
right
> can wait.
and
> thought...
> Cheers,
> Andy
> --- In PolySix@yahoogroups.com, "hjulskov" <hjulskov@> wrote:
> > Thanks Andy,
> what
> > Cheers,
> > Peter
> > > Hi Peter,
> controls
> apply a
which
> one
> the
> tested
> come on
> voice
> > > Cheers,
> > > Andy
2008-08-21 by hjulskov
Here are my measurements:
5: -9.90v
6: -9.92v
7: -8.55v
Also I discovred an interresting thing -voice 3 + 5 are slightly
distorted -sounds like mg (running at a high frequency) is applied,
but frequency does not change when changing MG, PWM or effect
frequency. Also when probing pin 6 on IC17 all voices are distorted in
a similar way.
/Peter
> Hi Peter,
2008-08-22 by Andrew Jury
Peter,
The act of you placing your DVM probes in-circuit is changing the
eletrical characteristics of it. Hence, the changes in the sound. Did
you I hear you right? Did you just say that the MG, PWM and effect
frequency controls aren't working either?! If so I would be looking
for disconnected tracks on the KLM-367 as a priority!
I'll get you some comparisons after the weekend.
Have a good one,
Andy
If you'd rather take this topic offline rather than bothering all
these good people with this lengthy topic then please be my guest. We
can post the answer when we have it!
> 5: -9.90v
> 6: -9.92v
> 7: -8.55v
in
> a similar way.
> /Peter
> > Hi Peter,
ground? It
2008-08-23 by hjulskov
Hi Andy
Sorry to confuse you -all controlls works as they should. I just
wanted to clearify that the distortion on two of the voices wasn't
caused by either MG, PWM or effect.
I'll try to swich the SSM's around to see if that changes which voices
are distorted.
And as an additional information -I ofcause changed the battery to a
lithium within 24 hours after I bought it. And luckily the old battery
had not leaked yet :-)
Have a nice weekend too :-)
Peter
2008-08-24 by Andrew Jury
Hi Peter,
Lucky you! My processor board was totally frazzled by flying nickel
cadmium powder! Just wanted to check I understood you OK with regards
to the controls. I have had a quick inspection of my Polysix and have
to tell you that I concur with your dc voltage readings around IC31.
we have an extra days holiday here in the UK tomorrow and I will have
a bit more of a poke around inside. I'll let you know...
Cheers,
Andy
> Hi Andy
voices
> are distorted.
battery
> Peter
Did
effect
looking
2008-08-26 by hjulskov
Thanks Andy!
I really appreciate your help with my beloved Polysix.
Last night I tried to switch the VCO's (SSM 2056) but no change in
which voice was distorted.
Just a summary:
* All voices are equally out of tune
* 2 voices have a "distorted" effect. I will record and post a
sample... -however the frequency of the distortion changes during the
initial self-tuning procedure.
* All controlls/keys works perfectly
* My tests are performed in manual mode with cutoff=10 and resonance=0
Cheers,
Peter
> Cheers,
> Andy
> > Hi Andy
> voices
> > are distorted.
> battery
> > Peter
> Did
> effect
> looking
2008-08-26 by steven pistrich
Im no tech-pro, but i was having an unusual 'out-of-tune-voice' problem with my Chroma Polaris that 'experts' on the polaris users group said was caused by bad capacitors in the sample and hold circuits. i dont know if it has anything to do with your polysix problem, but it sounds slightly similar.  the polaris would not play through a scale without sounding like the intervals were wrong. and its self tuning procedure did nothing to fix it.
----- Original Message ----
To: PolySix@yahoogroups.com
Sent: Tuesday, August 26, 2008 3:32:24 AM
Subject: [PolySix] Re: Suddenly out of tune -but still problems after changing PC-1 and R93
Thanks Andy!
Just a summary:
* 2 voices have a "distorted" effect.. I will record and post a
Cheers,
Peter
> Cheers,
> Andy
> --- In PolySix@yahoogroups .com, "hjulskov" <hjulskov@> wrote:
> > Hi Andy
> voices
> > are distorted.
> battery
> > Peter
> Did
> effect
> looking
2008-09-03 by hjulskov
I'm no expert either, but it sounds possible that the caps needs
replacement -if no other suggestions comes up -that would be my first
attempt to fix it.
Btw. I have uploaded a sample to the files section; First testing the
six voices (you can hear distortion to voice 3 and 5) finally playing
"just can't get enough" :-)
/Peter
2008-09-04 by Andrew Jury
Peter,
If only the P6 had a sample and hold circuit! Good point about
capacitors, especially electrolytic types, which could have well
dried up after 25+ years service. But do test them first before
binning them. I had what I though was a suspect capacitor in circuit
(0.33uF). It still measured 0.339uF after all that time!
However, I listened to the sample and the croaky voices sounded just
like mine before I replaced the VCF chips. I only has a single voice
out. Try swaping the IC32 between voices (SSM2044) and see what
happens.
Did you get the 'private' message I sent you?
Cheers,
Andy
first
> attempt to fix it.
playing
> /Peter
2008-09-05 by hjulskov
Hi Andy,
I'll try swapping the SSM2044's -after the weekeend (I'm away this
weekend).
I didn't get the PM -try sending it again.
Have a nice weekend!
Peter
> happens.
