Re: [motm] Cables
2000-11-09 by weld@buffalo.com
Probally the coolest looking cables ive seen are the new Samson armoured cables. These are encased in stainless steel sheeth. At 60$ a piece for 25 ft there not cheap, but they look very retro and they are virually indestructable. I wouldnt use these on the modular , but on bass or some kbds they looks awesome! Jim
2000-11-09 by zapsn0n
while we're on the subject..... i've made many cables including my MOTM ones and i'm a bit concerned. i just listened to one of the longer cables i made, going from elec gtr to amp, and it sounded like there was a LP filter on the guitar: so much highs and presence was just not there, compared to a spectraflex that we compared it with. i'm using canare starquad and neutrik ends. i guess my results are from poor soldering ? advice? mark
2000-11-12 by J. Larry Hendry
Mark. Guitar pickups are VERY high impedance, and when they get loaded too much the result is the same as the LP filter effect you speak of. I assume that you were doing a direct cable to cable comparison connected to the guitar amp. I am not familiar with the starquad cable you are talking about. Why is it called starquad? Does it have more than one wire inside the shield? One of the problems with cable can be inter-element capacitance. What might work OK for the synth, could be a problem with guitar. I would suggest that it is not your soldering, but maybe this cable (even if it is good quality) is not suitable for guitar use. To test this, you could run the guitar through a preamp or effect unit so the cable is between the effect and amp and not actually connected to the guitar. See if this makes any difference., Larry
----- Original Message ----- From: zapsn0n <n0nspaz@...> while we're on the subject..... i've made many cables including my MOTM ones and i'm a bit concerned. i just listened to one of the longer cables i made, going from elec gtr to amp, and it sounded like there was a LP filter on the guitar: so much highs and presence was just not there, compared to a spectraflex that we compared it with. i'm using canare starquad and neutrik ends. i guess my results are from poor soldering ? advice? mark
2000-11-12 by ivancu@aol.com
In a message dated 11/11/00 7:58:34 PM, jlarryh@... writes: << I am not familiar with the starquad cable you are talking about. Why is it called starquad? >> This is an excellent mic cable made by Canare specifically for balanced audio connection. It utilizes four inner conductors that are woven around each other and used in pairs. This configuration provides optimal noise cancellation when used with differential inputs. I can't imagine it providing any problems when used as a guitar cable, although ANY extremely long cable will provide high-frequency rolloff when used with high-impedance instruments pickups. Shouldn't sound any different than another cable of the same length. Ivan
2000-11-12 by zapsn0n
thanks larry & ivan, tonight i A/B/C'd mine again with a Monster cable (with gold connectors) and a spectraflex of similar length and there is a serious difference. the monster was very clear and musical and the 'average' of the three, the spectraflex was high-endy and lacking in lows as well, and mine (the canare/neutrik) was the 'warmest' (read: slight drop off in the highs), defnitely less high-end presence. it blows my mind.....though i know that similar phenomena happens with speaker cable... equipment: Bogner guitar amp, Fender strat, living room -mark At 12:48 AM 11/12/00 -0500, you wrote:
>In a message dated 11/11/00 7:58:34 PM, jlarryh@... writes: > ><< I am not familiar with the starquad cable you are talking about. Why is it >called starquad? >> > >This is an excellent mic cable made by Canare specifically for balanced audio >connection. It utilizes four inner conductors that are woven around each >other and used in pairs. This configuration provides optimal noise >cancellation when used with differential inputs. I can't imagine it >providing any problems when used as a guitar cable, although ANY extremely >long cable will provide high-frequency rolloff when used with high-impedance >instruments pickups. Shouldn't sound any different than another cable of the >same length. > >Ivan > > >
In a message dated 11/11/00 11:32:16 PM, n0nspaz@... writes: << tonight i A/B/C'd mine again >> There is no doubt that cable capacitance has differing effects on the sound in a high-impedance situation such as a guitar. If you had a low-impedance output, from something like an active onboard preamp or active pickups (like EMG) you would probably notice a much smaller difference in cable effects. Ivan
2001-06-27 by jpotter@it.rjf.com
Sent this out to AH as well but email is doing funny things today so I'm posting here as well.... Does anyone know what these cables are? http://ronwestb12.com/ap2001/pages/Dscf0428.htm They're on the MOTM at Audio Playground. Kind of cool because of the color coding. On a somewhat related topic - why are the Wacky Kovacky cables so great? Any better than picking up switchcraft connectors, decent wire, and putting them together yourself?
2001-06-27 by Paul Schreiber
> Does anyone know what these cables are? > > http://ronwestb12.com/ap2001/pages/Dscf0428.htm Look like the TEAC ones at Guitar Center. > > They're on the MOTM at Audio Playground. Kind of cool because of the > color coding. > > On a somewhat related topic - why are the Wacky Kovacky cables so > great? Any better than picking up switchcraft connectors, decent > wire, and putting them together yourself? I use Wacky. Note that his website is down, because he moved and has not yet set it back up. I have his phone # somewhere. Personally, I don't have time to sit and make cables :) Paul S.
2001-06-27 by George Kisslak
I make my own cables with switchcraft connectors and high quality shielded wire. I use color-coded shrink-wrap tubing at the ends. They work great and look cool, but it's not much fun. I build three cables after completing a module - to sort of spread out the pain. Alas, since I bought a large quantity of connectors and wire, I guess I'll be doing this routine for a while. After that, it's "Wacky" all the way. George
----- Original Message ----- From: <jpotter@...> To: <motm@yahoogroups.com> Sent: Wednesday, June 27, 2001 1:39 PM Subject: [motm] Cables Sent this out to AH as well but email is doing funny things today so I'm posting here as well.... Does anyone know what these cables are? http://ronwestb12.com/ap2001/pages/Dscf0428.htm They're on the MOTM at Audio Playground. Kind of cool because of the color coding. On a somewhat related topic - why are the Wacky Kovacky cables so great? Any better than picking up switchcraft connectors, decent wire, and putting them together yourself? Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Well, I'm definitely not looking for more work than necessary. Just thought it would be much cheaper and a simple matter (ie. less than 5 minutes/cable). Out of curiosity - does the shrink-wrap require a heat gun or will a regular old hair dryer work? Paul, if you find that phone number for Wacky I'd be interested... Anyone know approx. price for a single 3" Wacky cord w/ 1/4" connectors? I realize the price probably goes down as qty. ordered increases - just looking for a baseline. Thanks, John --- In motm@y..., "George Kisslak" <groovyshaman@s...> wrote: > I make my own cables with switchcraft connectors and high quality shielded > wire. I use color-coded shrink-wrap tubing at the ends. They work great > and look cool, but it's not much fun. I build three cables after completing > a module - to sort of spread out the pain. Alas, since I bought a large > quantity of connectors and wire, I guess I'll be doing this routine for a
> while. After that, it's "Wacky" all the way. > > George
2001-06-27 by John Potter
Yep, If Paul comes up w/ the number, I'll try to get in touch and send the info onto you and the group. John
-----Original Message----- From: George Kisslak [mailto:groovyshaman@...] Sent: Wednesday, June 27, 2001 2:47 PM To: John Potter Subject: Re: [motm] Re: Cables It doesn't take much time to make a cable - it's just not as fun as building DIY circuits and modules. There are different qualities for various types of shrink tubing. I use a Steinel heat gun, since the shrink temp for the colored stuff is too high for a hair dryer to work. I figure I'm saving roughly 50% over the cost of pre-made cables. If you get prices for Wacky's cables, could you forward them on to me? Thanks! George ----- Original Message ----- From: <jpotter@...> To: <motm@yahoogroups.com> Sent: Wednesday, June 27, 2001 2:26 PM Subject: [motm] Re: Cables Well, I'm definitely not looking for more work than necessary. Just thought it would be much cheaper and a simple matter (ie. less than 5 minutes/cable). Out of curiosity - does the shrink-wrap require a heat gun or will a regular old hair dryer work? Paul, if you find that phone number for Wacky I'd be interested... Anyone know approx. price for a single 3" Wacky cord w/ 1/4" connectors? I realize the price probably goes down as qty. ordered increases - just looking for a baseline. Thanks, John --- In motm@y..., "George Kisslak" <groovyshaman@s...> wrote: > I make my own cables with switchcraft connectors and high quality shielded > wire. I use color-coded shrink-wrap tubing at the ends. They work great > and look cool, but it's not much fun. I build three cables after completing > a module - to sort of spread out the pain. Alas, since I bought a large > quantity of connectors and wire, I guess I'll be doing this routine for a > while. After that, it's "Wacky" all the way. > > George Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2001-06-28 by Microtonal
They look like Hosa patch bay cables. They come in packs of 8 and lengths of 1', 1.5' and 3'. A hair dryer will not work. Get a heat gun, you'll appreciate it. Makes kit building easier too. John Loffink microtonal@... ----- Original Message -----
From: <jpotter@...> To: <motm@yahoogroups.com> Sent: Wednesday, June 27, 2001 1:26 PM Subject: [motm] Re: Cables > Well, I'm definitely not looking for more work than necessary. Just > thought it would be much cheaper and a simple matter (ie. less than 5 > minutes/cable). > > Out of curiosity - does the shrink-wrap require a heat gun or will a > regular old hair dryer work? > > Paul, if you find that phone number for Wacky I'd be interested... > > Anyone know approx. price for a single 3" Wacky cord w/ 1/4" > connectors? I realize the price probably goes down as qty. ordered > increases - just looking for a baseline. > > Thanks, > > John > > --- In motm@y..., "George Kisslak" <groovyshaman@s...> wrote: > > I make my own cables with switchcraft connectors and high quality > shielded > > wire. I use color-coded shrink-wrap tubing at the ends. They work > great > > and look cool, but it's not much fun. I build three cables after > completing > > a module - to sort of spread out the pain. Alas, since I bought a > large > > quantity of connectors and wire, I guess I'll be doing this routine > for a > > while. After that, it's "Wacky" all the way. > > > > George > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
2001-06-28 by ivancu@aol.com
In a message dated 6/27/01 11:06:03 AM, jpotter@... writes: << They're on the MOTM at Audio Playground. Kind of cool because of the color coding. >> Looks like Hosa or similar cables to me. Certainly inexpensive, but I've gotten frustrated having failures with molded cables. << On a somewhat related topic - why are the Wacky Kovacky cables so great? Any better than picking up switchcraft connectors, decent wire, and putting them together yourself? >> He's REALLY inexpensive. Typically less than I can buy the parts, much less not having to find the time to solder away. Ivan
Wacky Kovacy 847-366-0292
2005-05-12 by Alexandros Papadopoulos
Hello I am a new MOTM user/musician from Greece. I can't find cables in the colors and measurements I need , anybody knows a store in Europe I can get some? Thanks
2005-05-12 by Wood
Order some from Larry Hendry. He is in the States but he will get you whatever you want.
----- Original Message ----- From: "Alexandros Papadopoulos" <Alexmoog@...> To: <motm@yahoogroups.com> Sent: Thursday, May 12, 2005 6:31 AM Subject: [motm] Cables > Hello > I am a new MOTM user/musician from Greece. > I can't find cables in the colors and measurements I need , anybody > knows a store in Europe I can get some? > > Thanks > > > > > > Yahoo! Groups Links > > > > > > > > > > -- > No virus found in this incoming message. > Checked by AVG Anti-Virus. > Version: 7.0.308 / Virus Database: 266.11.8 - Release Date: 5/10/2005 > > -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.308 / Virus Database: 266.11.8 - Release Date: 5/10/2005
