Re: [motm] A VCLFO Lives
2000-03-07 by Paul Schreiber
> I finally built it... And as always it worked the 1st time powered up!
Is there every any doubt??!?
> Now about the mods & all the wasted pael space..... I had plans to include
> a VC Divider (A Serge board) but I decided to drop that plan. I did
> include some switches to normalize the Pulse out to an ADSR and a switch
> to send pulse out to the future VC Divider & Pulse Divider (Again the
> Serge PCB's).
Note that there is a MOTM VC Pulse Divider lurking in the wings...heee heee
hee......
and it blows the sorry Serge out of the water. Will be shipping in late
April.
RE: [motm] A VCLFO Lives
2000-03-07 by Brousseau, Paul E (Paul)
Firstly, 'grats on the mods working.  'Nuff said.  ;)
Secondly, pardon my ignorance, but what's a APRC, BLOG, and / or CMX / AMX?
--PBr, thanks!!
> -----Original Message-----
> From:	Dave Fulton [SMTP:dfulton@...]
> Sent:	Monday, March 06, 2000 10:33 PM
> To:	motm@onelist.com
> Subject:	[motm] A VCLFO Lives
> I have a 3 U MOTM Blank and plan on mounting the dividers, a APRC, a BLOG
> , and Audio mixer (all serge). when I do this I will have 2 Analog Shift
> registers left over (again Serge). Anyone want to trade? I also may have a
> couple of CMX's (Control voltage versions of the AMX with an adjustable DC
> offset.) These are real PCB's. Do not ask how I got them or Rex Probe will
> be forced to kill you! Really, I am just condensing this stuff into a
> smaller footprint and these will be left over.
2000-03-07 by Tkacs, Ken
I think I can help with that. An APRC is an "Anti-Proton Rail Cannon," a
Blog is a large semi-sentient hunchbacked reptile from the planet Ksarscis,
CMX is the CorelTrace file format, and AMX makes bicycles.
Hope this helps.
(Frankly I was going to dig out my dusty Serge catalog and look these up
myself.)
From: 	Brousseau, Paul E (Paul) [mailto:PaulBr@...]
Sent:	Tuesday, 07 March, 2000 1:34 PM
To:	'motm@onelist.com'
Subject:	RE: [motm] A VCLFO Lives
2000-03-07 by Ben Vehorn
APRC= Active Processor
BLOG= Boolean Logic
CMX= CV Mixer
AMX= Audio Mixer
"Tkacs, Ken" wrote:
> From: "Tkacs, Ken" <ken.tkacs@...>
> a
> Ksarscis,
> Hope this helps.
> up
> myself.)
> AMX?
2000-03-09 by jwbarlow@aol.com
In a message dated 3/7/2000 6:52:56 AM, synth1@... writes:
>heee
>hee......
Well, I'm sure there is at least one guy on this list who'll really like this
module. I seem to remember about a year ago some loudmouth would post lengthy
diatribes regarding VC Division, claiming to use several of these to control
sequencers (resets, up/down, random, etc.) and synching up several different
voices amongst other uses.
I wonder who that was?
JB
2000-03-09 by Brousseau, Paul E (Paul)
Er... my heightened levels of expirience once again shine through... what
exactly does a pulse divider do?  I can't quite figure out if its intended
to work on CV or gate / triggers, although Paul S. said it could be used on
audio.
(Incidently, if the levels put out by the CMOS are 0V - +5V, can't you send
that to an op-amp that goes 0V to +10V, then bias the results by -5 V?  Hm,
and I thought that typical MOTM audio levels were +-10V?)
--PBr, scratching his head, as per usual...
> From:	jwbarlow@... [SMTP:jwbarlow@...]
> Sent:	Wednesday, March 08, 2000 7:51 PM
> Subject:	Re: [motm] A VCLFO Lives
> this
> lengthy
> control
> different
2000-03-09 by Dave Bradley
A couple of pulse divider uses:
1. When sequencing rhythmic stuff, one typically uses a LFO as a clock for
the timed pulses. Feed the clock into a pulse divider, and set it to divide
by 3, 4, 6, 9, etc. to get other pulses which can be used to gate other
things in precise rhythm.
2. Run audio into a pulse divider and get not just suboctaves, but any
musical interval.
Dave
> From: "Brousseau, Paul E (Paul)" <PaulBr@...>
> be used on
> audio.
2000-03-09 by J. Larry Hendry
> From: Brousseau, Paul E (Paul) <PaulBr@...>
> can't you send that to an op-amp that goes 0V to +10V, then
I was about to ask the same question myself.
> Hm, and I thought that typical MOTM audio
> levels were +-10V?)
10 volt peak to peak.
Larry (often scratches other parts) Hendry
2000-03-11 by jwbarlow@aol.com
In a message dated 3/9/2000 12:05:23 PM, daveb@... writes:
>for
And get several of these outputs simultaneously, and they can be used to
create complex rhythmic patterns (like those cute little humans often do) if
you switch between them.
>musical interval.
This second part isn't true with integer division, and non-integer division
(I won't say real, but you know what I mean) would be very difficult to do --
I have no idea what the MOTM will do.
John (no phone, no lights, no internet) Barlow
OK -- I'm lying about no lights.
