> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Friday, March 10, 2000 6:16 AM
> To: motm@onelist.com
> Subject: Re: [motm] Pulse Divider
> It appears that going IN to drum machines, a +5V level is OK. Coming OUT,
> they use like +12V.
> Paul S.
> From: <elhardt@...>
> To: <motm@onelist.com>
> Sent: Friday, March 10, 2000 12:51 AM
> > From: elhardt@...
> > synth1@... writes:
> > >>This is the *plan*. However, I need thouse of you with Roland
> drum stuff
> > (303/808/505/606/blah blah)
> > to look in the manuals and see if Roland states what they
> expect CLOCK IN
> to
> > be. If is a higher voltage, I'll have to buffer things differently.<<
> > I didn't see anybody answer this, and none of my Roland manuals (TR-808,
> > MC-4) seem to specify what the DIN input sync socket takes. For
> > Gate/Trigger/MPX OUTPUTS though, Roland seems to be going with 12 to 15
> > volts. However for the external sync 1/8" connector and Gate inputs on
> the
> > Roland MC-4 sequencer, they specify a threshold of 2.5 volts to trigger.
> > Don't know if this helps.
> > -Elhardt
> GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 0.0%
> Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
> http://click.egroups.com/1/937/2/_/529958/_/952694032/
