Hook up wire
Hook up wire
2003-10-06 by Roger Rossen
Hello all,
Does anyone have readily avail.: some mouser or allied cat.#'s for
hook-up wire?  I don't know why but I seem to have a mental problem
with this particular hardware item and often end up getting the wrong
wire or something completely different than what I thought.
I'm pretty sure we're talking 22awg - eh?  Just like the stuff Paul
uses in the kits!
This would be greatly appreciated - The page Dave (Hotrod) put
together on common MOTM parts is VERY helpful!  I would think it
helpful to all to keep this list growing.  (maybe it is somewhere and
I just haven't found it !?!?!?) If there is a 'central data core' let
me know so I can contribute.
Ordering parts can be so fun - NOT !!!
Rog -
just spent way too much on parts this past weekend-which equates
to: "no x-mas this year for the family....chuckles"
Hook up wire
Thanks Paul!
Geez - there's nothing like having the CEO standing by and awaiting
your inquires or questions and responding within microseconds...Thats
customer service which TRANSCENDS the whole concept of cust. service!
Rog
Re: [motm] Hook up wire
2003-10-06 by Paul Schreiber
I use Belden #9921, which is 22ga, UL1007 listed. About $13 for a 100ft spool. This is "the good
stuff". I get mine from Allied or Newark.
A cool little bench setup is Belden #8824, which is 8 different colors of wire in a little
dispensor, about $65.
I know folks like to dig wire out of dumpsters of salvage telephone wire found on the side of the
road. Not me.
Re: Hook up wire
2003-10-06 by osthelder
> road. Not me.
> Paul S.
Me neither- I get mine from buildings that are going to be
demolished.  That way you know it's dry and clean.  Belden 22awg by
any other source is still Belden 22awg.  Most of the time, if you
have your own safety shoes, glasses and hardhat, the other
construction workers won't even notice you...
Chub-laboring in obscurity
2003-10-06 by Scott Juskiw
I don't have part numbers for the 22 gauge wire, but I've got Mouser
part numbers for the 18 gauge power supply wire:
1        602-3055-100-01       1        11.370    11.37
          18AWG UL1007 WHT
          Alpha Wire Hook-Up Wire
1        602-3055-100-02       1        11.370    11.37
          18AWG UL1007 BLK
1        602-3055-100-03       1        11.370    11.37
          18AWG UL1007 RED
This wire looks identical to the official MOTM stuff, it probably is
the same stuff.
While we're on this topic, I also picked up a couple of tools for
fixing wires into MTA connectors (Mouser part numbers):
1        571-598041            1        22.000    22.00
          156 T HANDL MAINT TL
          AMP MTA .156' Connectors
1        571-598031            1        20.200    20.20
          100 T HANDL MAINT TL
          AMP MTA .100' Connectors
These aren't the fancy ones with a trigger; these are the T-shaped
ones that still require a vice to hold the connector and a bit of
grunting to get the wire in place. I've found these tools to be much
more reliable than the old pliers method, especially when building 20
power cables. The results are consistent and perfect each time.
These aren't "must have" tools. But if you're taking in your empties,
you might want to consider buying yourself a treat with all that
dough. That's how I celebrated my birthday !
At 2:32 PM +0000 2003/10/06, Roger Rossen wrote:
>Hello all,
>uses in the kits!
[motm] Re: Hook up wire
>>  road. Not me.
>>  Paul S.
Me too. I picked up a 50 foot trunk line of 22 gauge twisted pairs
from a university building I was working in. I've been picking away
at it for 10 years.
2003-10-06 by Richard Brewster
I found wire at Unicorn Electronics in Johnson City, NY, last summer during
a trip.  I bought seven 100-foot spools of different colors in #22 gauge
stranded at $4.83 each.
<http://www.unicornelex.com/newunicorn/search.php?cat=&searchstring=Hookup+wire&Go=Go>http://www.unicornelex.com/newunicorn/search.php?cat=&searchstring=Hookup+wire&Go=Go
You can find other synth DIY parts there too.
-Richard Brewster
At 02:32 PM 10/6/03 +0000, Roger Rossen wrote:
>Hello all,
>uses in the kits!
>Rog -
My first DIY synth (circa 1980) was built with #24 gauge wire salvaged from
the dustbin of an avionics factory I had worked at.  It was Teflon
insulated.  They threw away a lot of clippings that were perfectly good,
just too short.  I miss that Telfon insulation which is impervious to a 700
degree soldering iron.
-Richard Brewster
>road. Not me.
>Paul S.
2003-10-06 by J. Larry Hendry
These look similar to the ones I got from All Electronics. However, I see All Electronics is out of all but 2 colors. I plan to pick up the orange and violet colors from here that I don't have. Thanks for the tip Richard.
Sent: Monday, October 06, 2003 6:46 PM
Subject: Re: [motm] Hook up wire
I found wire at Unicorn Electronics in Johnson City, NY, last summer during a trip. I bought seven 100-foot spools of different colors in #22 gauge stranded at $4.83 each.
-Richard Brewster
Hello all,
uses in the kits!
Rog -
Re: Hook up wire
2003-10-07 by ivancu@aol.com
> From: "Roger Rossen" <mididood@...>
> Subject: Hook-up wire
> FYI - I ordered the #8824 kit from Allied - it states
> however that it is 20 awg!
Ok, here it goes.  Paul states that MOTM uses Belden 9921, which is 22 awg wire.
Belden 8824 is a kit of eight 25-ft. spools of 20 awg wire (8523)
Belden 9531 is a kit of five 100-ft. spools of 22 awg wire (8524) that is very similar to Belden 9921.
Ivan
2003-10-08 by elhardt@att.net
For those situations where you only need a small amount of hookup wire, Ace
Hardware has many different guages and colors of hookup wire on spools that
can be bought by the foot.  That's what I do if I just need a couple of feet
to wire up a power supply or whatever.
-Elhardt
