Making Water
Making Water
2001-05-15 by Roy Harter
Hello Everyone,
Does anyone know how to make a dribbling/ dropping water sound effect
patch with their MOTM?  If you have any ideas please let me know. I
know I have all the modules I need to do it. I just want to know if
there is a more efficient way of linking the modules.  I think I am
using more modules in the patch than I actually need. The wetter the
better. Any help will be appreciated.  Thanks.
Sincerely,
ROY HARTER
royh@...
RE: [motm] Making Water
2001-05-15 by Tkacs, Ken
If it were me, I'd begin with a percussive amplitude envelope, very sharp
attack, fast decay, zero sustain.
I'd probably start with a Sine from a VCO, being swept with another EG,
starting low and quickly rising to supersonic just as the amplitude envelope
goes quiet.
With an LFO also modulating the VCO just a little bit, you could make it so
that every drop was just a little different in pitch.
Maybe a very short, subtle white noise chiff at the start would help, too.
Noise should probably be highpass filtered. Experimentation would be needed,
but that's how I'd start.
Sent:	Tuesday, 15 May, 2001 2:12 PM
To:	motm@yahoogroups.com
Subject:	[motm] Making Water
Hello Everyone,
Sincerely,
ROY HARTER
royh@...
Re: Making Water
2001-05-15 by Mike Marsh
I would only add that a touch of reverb could enhance the patch
wonderfully...
sharp
EG,
envelope
> goes quiet.
make it so
help, too.
be needed,
>  -----Original Message-----
> From: 	Roy Harter [mailto:royh@s...]
> To:	motm@y...
> Hello Everyone,
effect
> Sincerely,
> ROY HARTER
> royh@s...
