Fw: [motm] Making Water
2001-05-15 by sikorsky
apologies to Roy for getting this twice, i fell for the old return to sender trick... ----- Original Message ----- From: sikorsky <vulture.squadron@...> To: Roy Harter <royh@...> Sent: Tuesday, May 15, 2001 7:58 PM Subject: Re: [motm] Making Water > hello all, > > i just came up with this one, granted it sounds like lonely insects rahter > than yer actual wet stuff, but with some fine tuning it just could work... > ...and with the reference material at hand here in the sunny north of > england... > > connections: > LFO pulse out to two EG gate inputs > EG1 + out to VCO FM1 input > EG2 + out to VCA CV input > VCO sine out to VCA in > VCA out to big reverb tank > > settings: > 320 LFO > rate = 5 > shape = 1 > > 800 EG 1 "plop" > a = 2.5 > d = 10 > s = 10 > r = 6 > > 800 EG 2 "drop" > a = 1 > d = 0 > s = 10 > r = 0 > > 300 VCO > coarse = 6.5 > fine = 6 > fm1 = 8 exp/dc > > 110 VCA > cv mod =10 > gain = bias > > that should do it, altering the vco tuning will force you to re-adjust the > "plop" settings to get rid of the unwanted tone, try adding a little S&H to
> the v/oct input of the LFO, nice... > > cheers > paul b >
