Some advanced user tips...
2002-11-16 by Simone Coen
Hi again guys, after having started the "EXS scanning for instruments thread" I am about to start a new one... Though I am a deep user of Logic, up to now I used EXS mainly as a sample player and have done only some basic editing in the Edit Window... hence I got a couple of questions. 1) don't you think the new Multiple Outs possibility is a bit tricky in the EXS? You have to open the edit window chanche the outs, save the instrument with another name... etc etc... it would be better to save the changes with the song, like it happens with every instrument or plugin in logic (and if you want have the chance to save a permanent Instrument)... 2) is there a way to apply a change to a lot of zones or groups like the one used in the inspector? Explain: if I open an instrument and want to change all the "kick" zones (without a group) to out, say, 3, can I select all the sensible zones and with a modifier (shoft or whatsoever) impart the command just once instead of selecting zone by zone and applying the change. Same is true for assigning zones to a groups, change out vol or whatever.... Is it possible to have relative and absolute changes? I'm looking in the manual right now but can't find anithing about it... Thanks, and keep on playing! Simone Coen
