Re: [exs] Free Spectrasonics library if you can figure this out first!
2001-12-06 by PersingEP@aol.com
Hi EXS/Logic environment geniuses out there! I have been trying to figure out a solution to a serious shortcoming in Logic with using Audio instruments for over a year. It's time for desperate measures! I will give the first person to solve this problem a Spectrasonics CD-ROM library of their choosing (that's a value of up to $500 if you want Symphony of Voices!). BTW, all of our stuff converts great to the EXS. Here's a page list of the juicy options awaiting the winner: http://www.spectrasonics.net/products.html OK..here's the brain twister: I want to layer two audio instruments in real-time from MIDI input. I also want to use a split keyboard from MIDI input to have one audio instrument on the left and another on the right (in real-time). Sounds simple...right? Wrong....try it and you'll see the problem. Logic only allows you to activate one in real-time. The environment should fix this, but no cabling tricks I've tried work. However, I know that the environment is incredibly powerful, and that there MUST be a solution in there somewhere! This stuff is really easy to do with MIDI instruments, but with virtual instruments...OY!! I have a keyboard that can send two MIDI channels at once, with zone ranges, all the Emagic interfaces and all of the functions of Logic Platinum at my disposal. See if you can figure this out, and the first to do it will win the library of their choosing. (BTW, don't tell me about making zones in the EXS...that's not an option here.) Good luck and may the best man (or non-man) win! Thanks, Eric Persing Creative Director Spectrasonics
