Toner Reactive Film
Toner Reactive Film
2004-12-05 by Kim Lux
I am about to make some printed circuit boards using a laser printer,
the Pulsar transfer film and an H200 laminator.  Do I need to use toner
reactive film or will the toner itself resist the etchant ?
Kim Lux (Mr.)  Diesel Research Inc
[Homebrew_PCBs] component legend.
2004-12-06 by Stefan Trethan
toner transfer for compoent legend doesn't work well on single-sided
boards.
The surface is too shiny.
Until now i only used it on areas where i etched copper away (two sided
stock),
which leaves a ideal surface.
I tried roughening the surface, it worked somewhat, but not as good as on
a etched-away area.
Just a warning for those who want to try, better first try on double-sided
stock.
Also i want to thank the guy who suggested using thick drawing paper to
feed two-sided transfers.
It works like a charm. Sorry i'm too lazy now to look for your name and i
forgot it, but thank you.
I align the two printed paper pieces against the light, then insert them
in the folded drawing paper
and hold the three together at the folded edge with one hand. (leave a
broad border on your printouts).
the i simply insert the PCB and feed that folded edge first - works very
well.
ST
[Homebrew_PCBs] bubbler system
2004-12-07 by Stefan Trethan
Hi everyone.
I decided i do need some sort of agitation for my etcher.
i tried moving the board, it works well but tends to shake to board loose
of the
holder.
The etching takes too long, and it is very uneven because the spent
etchant sinks down.
So i went to a aquarium shop for a air pump.
got one for 10eur, took it apart and found the pumping part is made
entirely of rubber
and plastic (only one M3 screw needs relacement with nylon or a protective
silicone coat).
This means for me i can scoop up the air from under the cover of the etch
tank, releasing no corrosive
mist into the room, or at least much less.
I got a bubble-stone with it, but it is just a small (2cm) ceramic ball,
no good for even
distribution of bubbles.
They don't have other bubbling stones, i believe i remember reading about
"fritted glass" or something
here?
What about making holes in a hose? would that cause too-big bubbles, and
too few?
Another thing is, do you think those air pups can pump liquids?
alternatively to pumping air i might
just pump the etchant around. I will test that with water. Other pumps
(centrifugal for aquarium filters)
have a magnet exposed to the liquid, and a metal shaft (expensive ones
have a ceramic shaft, or so they
say). Would the magnet be attacked by etchant? it is a hard "black" type,
not a neodymium magnet.
Maybe the magnet could be painted or something...
While we are at pumps, i learned something interesting: for CO2 feed
systems the aquarium guys use
reactors. that is a cylinder where the water is pumped downwards, while
the co2 gas rises against the current.
they place obstacles into this cylinder too.
If it is adjusted correct almost no CO2 reaches the top, all is solved in
the water. this might be an effective setup for air-regenerating CuCl.
thanks for any hints about that bubbler stuff (but suppliers in the US are
not of much use).
ST
Re: [Homebrew_PCBs] bubbler system
2004-12-07 by Les Newell
Hi Stefan,
You can make holes in a plastic tube but they need to be very small. I
used a small pin that I heated up with a candle flame. If you use the
pin cold the hole tends to seal up as soon as you remove the pin. You
don't need many holes. If I remember correctly my system worked best
with about 5 holes in a 180mm length of pipe. I am working from memory
here because my tank now has the holes built in.
You need a pump with a reasonable flow rate if you go this route
otherwise you may find that air only comes out of one half of the tube.
No they won't. They rely on sprung magnet that is alternately attacted
to and repelled from an AC electromagnet. The weight of the magnet and
spring are designed so they resonate at mains frequency. Any quantity of
liquid in the pump will damp out any movement and it will stop working.
I found this out when I had some etchant syphon back into the pump
overnight.
Les
Stefan Trethan wrote:
> Hi everyone.
> of the
> holder.
> etchant sinks down.
> entirely of rubber
> silicone coat).
> no good for even
> here?
> too few?
> not of much use).
> ST
> Be sure to visit the group home and check for new Bookmarks and files:
RE: [Homebrew_PCBs] bubbler system
2004-12-07 by Leon Heller
>From: "Stefan Trethan" <stefan_trethan@...>
>Reply-To: Homebrew_PCBs@yahoogroups.com
>Subject: [Homebrew_PCBs] bubbler system
>Date: Tue, 07 Dec 2004 16:09:06 +0100
>Hi everyone.
>of the
>holder.
>etchant sinks down.
>entirely of rubber
>silicone coat).
>no good for even
>here?
I've got a rectangular stone, about 10 cm long. Haven't tried it with an air
pump, though. I find that contnuous manual agitation of the etchant
container worrks very well, and only takes 10 minutes or so.
Leon
On Tue, 07 Dec 2004 16:11:50 +0000, Les Newell <lesnewell@...>
wrote:
> Hi Stefan,
Ok, i'll experiment with poking holes in a hose then.
I thought maybe it is best to make the hose a U-shape, so i can feed both
sides.
I can get a second pump if required, the one i have says 110 l/h.
Well, i'll try for hole-size, and how many holes the pump will supply at
the given depth.
ST
On Tue, 07 Dec 2004 17:01:00 +0000, Leon Heller <leon_heller@...>
> air
> Leon
My container is unsuited for moving it. also it takes longer with my CuCl
if i don't add high
amounts of H2O2 and i don't want to stay put until it is done.
I have hooked a geared motor to the pcb holder via a rubber band several
times, which worked
very well for agitating, but tends to shake the PCB loose.
Another thought was to use some sort of plastic paddle to create waves or
a current in the
tank....
ST
Re: bubbler system
2004-12-07 by Radra
Think & Tinker has some suggestions regarding bubblers at
http://www.thinktink.com/stack/volumes/voliii/equipment/bubltank/bublt
ank.htm .
Lyman
<stefan_trethan@g...> wrote:
Hi everyone.
loose of the holder. The etching takes too long, and it is very
uneven because the spent etchant sinks down.
So i went to a aquarium shop for a air pump. got one for 10eur, took
it apart and found the pumping part is made entirely of rubber
protective silicone coat). This means for me i can scoop up the air
from under the cover of the etch tank, releasing no corrosive
ball, no good for even distribution of bubbles. They don't have other
bubbling stones, i believe i remember reading about "fritted glass"
or something here? What about making holes in a hose? would that
cause too-big bubbles, and too few?
alternatively to pumping air i might just pump the etchant around. I
will test that with water. Other pumps (centrifugal for aquarium
filters)have a magnet exposed to the liquid, and a metal shaft
(expensive ones have a ceramic shaft, or so they say). Would the
not a neodymium magnet. Maybe the magnet could be painted or
something...
systems the aquarium guys use reactors. that is a cylinder where the
water is pumped downwards, while the co2 gas rises against the
current. they place obstacles into this cylinder too. If it is
US are not of much use).
ST
Re: [Homebrew_PCBs] Re: bubbler system
> ank.htm .
> Lyman
thanks.
and here is was wondering how i could produce very small holes, for very
small bubbles.
It seems larger is OK, though small would be better for regeneration.
I will try the hose-and-hot-needle approach and see how many holes that
pump can drive.
ST
Re: component legend.
2004-12-07 by mycroft2152
I've had the same problem toner transferring component legends on
single sided boards. My solution was to first give the legend side a
light coat of Krylon spray paint and letting it dry completely. then
doing the toner transfer. Gives great contrast (white) or creates an
interesting look (red).
Myc
> Hi,
sided
> boards.
Re: [Homebrew_PCBs] Re: component legend.
On Tue, 07 Dec 2004 23:39:34 -0000, mycroft2152 <mycroft2152@...>
> Myc
thanks, will try. is krylon paint something special? what is it, acrylic?
I grabbed some 1000grit and 600grit paper at the tools shop today, will
try that too
to roughen the surface.
ST
Re: bubbler system
2004-12-08 by Phil
I found a heated pin produces pretty large holes and, thus, pretty
large bubbles.  I used a #69 drill bit to get much smaller holes but
would prefer even smaller.
Also, be careful of the material you use.  CuCl attacks a lot of
different plastics.  I've had the best luck with HDPE.
> On Tue, 07 Dec 2004 16:11:50 +0000, Les Newell <lesnewell@f...>
> wrote:
> > Hi Stefan,
> > here becaIuse my tank now has the holes built in.
tube.
both
> sides.
supply at
> the given depth.
> ST
Re: bubbler system
2004-12-08 by James Newton
for very
> small bubbles.
regeneration.
My dad showed me how to put very small holes in a cigar by passing
the thing back and forth many times between the arc of a large, high
voltage spark gap. ...it was clamped to the end of a long plastic
rod of course, not held by hand.
Anyway, the arc punches so many holes that you can't draw air
through the end of the cigar and it becomes impossible to light, but
the holes are so small that you can't see them with the naked eye.
We had an uncle who used to light up these really smelly things
after T-Day dinner... It still smelled, but it was worth it to watch
him huff and puff.
It might not work on plastic tubing if the plastic gets warm enough
to close the holes or if the insulative ability of the hose is
enough to deflect the arc around the hose rather than through, but I
thought it might be worth mentioning.
2004-12-08 by Ben H. Lanmon
acrylic?
Krylon is a spray paint brand here in the US.  It is a Lacquer.
Very Good Spray Paint, Dries Fast.  Like it alot better than the
Rust-Oleum Brand that Home Depot and Lowes sells now days after Rust-
Oleum came in and made Home Depot and Lowes a deal to just carry
their product.  Wal-Mart still carry the Krylon Brand.
But that most likely does not do you much good since you are not in
the U.S.
Ben
Re: bubbler system
I use a 5 Gallon Aquarium installed three rows of 1/2" CPVC pipe
across the bottom and feed it from both ends with a small air
compressor.  Don't recall the size holes I drilled into the pipe,
maybe 1mm.  The small Aquarium pump that I had used with a smaller
tank did not work nor did a larger Aquariium pump work very well
with the 5 gallon tank, even tried 2 pumps together.  Had this small
portable compressor and tried it and it worked great, just a little
noisy.  Put a value in the line to control the amount of bubbles.
I use Ferric Chloride in my tank.  With fresh Ferric Chloride it
will etch upto (4) 8" x 12" single sided boards in about 5 mins.
(longer times the more the Ferric Chloride has been used) with it
heated, use (2) Aquarium heaters to heat it, ran the temp. controls
up all the way bypassing the normal stop, never measured the
Temperature.
Ben
2004-12-08 by Stefan Trethan
On Wed, 08 Dec 2004 02:46:16 -0000, Ben H. Lanmon <bhleavi@...>
> the U.S.
> Ben
Right.
What would be interesting for me is if it is "water based" (in reality
ammonia based) or
solvent, and wich kind of paint it is then.
(differnt laquers will have differene heat behavoir, but i might just try
around)
ST
hi
bubbler is working fine already.
Aginst better knoweledge i decided to try cutting corners and did not test
the bubbler with water.
I just took a plastic hose, made 5 holes with a hot needle, put a isolated
copper wire (seal the ends)
in the hose. Also selaled one end of the hose. the wire inside allows for
shaping and holds it down and in place.
The bubbles are maybe 6mm dia. and all holes work equally well.
The bubbles create a mad circular current, up in the center and down the
sides. Also along with the
big bubbles there are thousands of tiny bubbles, which you only see after
stopping the pump, when
they rise slowly to the surface.
The mixing is of course homogenous, i am sure 1/10 of the bubbles or less
would already ensure complete
mixing.
when the bubbles rise they spread, so that at the top of the tank they
already cover the whole area,
but on the bottom they do etch streaks where they rise. i think about
adding two more holes
to create a more even etch. Also it could be that some obstruction above
the air holes might
help to spread the bubbles over the entire length, i was thinking about a
roll of plastic fly screen,
what do you think?
i had to modify the pump to get a suction input, but it wasn't much of a
problem.
the closed circuit seems to work from what i can tell, but long-term
rusting will show the truth..
So, at the end of the day it seems bubbling is really a good method to mix
the etchant.
Thanks for the suggestion of a hot needle to punch the holes.
ST
Re: Toner Reactive Film
2004-12-08 by rustyturley
printer,
toner
> Thanks
The toner Reactive file merely puts a harder surface in the top of
the toner image.  It does not fill in holes in the toner nor does it
fill any "jaggies" in trace lines or pads.
Its main purpose is to provide a harder, more impervious cover for
the toner.  This is important if you are using Pulsar's
recommended "direct rub" method of FeCl etching (which I use).
The "direct rub" method relies on use of a soft sponge or brush to
wipe the etchant across the board.  Small amounts of etchant are used
at room temp and wiped across the board.  This speeds the etching
process by constantly resupplying fresh FeCl to the copper surface
while removing the copper-saturated etchant. Without the TRF
overcoat, some of the toner will be rubbed off, exposing copper that
you do not want removed.
If you are not using the "direct rub" method but are using an etching
tank, I do not believe that the TRF is needed, but may enhance
quality of the board.
I also use the aluminum colored TRF to do the legend side of the
board.  I have no problems getting a good component legend with the
toner transfer and finishing it with the aluminum TRF.  I do
encounter some minor problems when transferring a legend when a
legend item is too close to a track or pad on a double-side board.
The difference in the height of the copper and the board will cause a
small skip in the toner due to this surface irregularity.
The TRF coated legend is surprisingly scratch resistant.  I transfer
the legend prior to drilling.  The legend side is face down on my
drill press and after all of the positioning, sliding and drilling,
the legend appears unaffected.
I use these techniques to make single/double sided boards from 3"x5"
to 9"x6".  I do all thru-hole boards, so I make no representations
regarding the efficacy of these techniques for SMD work.
Hope this helps.
Rusty Turley
Re: [Homebrew_PCBs] Re: Toner Reactive Film
2004-12-08 by Kim Lux
Thanks for the excellent answer.  I never even thought of making a
component mask.  That is a great idea.
> Hope this helps.
> Regards,
> Rusty Turley
2004-12-08 by Les Newell
Hi Stefan,
I am glad it worked for you. I would have thought a fly screen would
tend to collect the bubbles rather than breaking them up. I haven't
actually tried this so I could be completely wrong of course...
I have noticed my tank also etches slightly unevenly. To get around this
I usually turn the board over half way through.
Les
>hi
>mixing.
>the air holes might
>what do you think?
>problem.
>the etchant.
>ST
>Yahoo! Groups Links
On Wed, 08 Dec 2004 22:27:58 +0000, Les Newell <lesnewell@...>
wrote:
> Hi Stefan,
> Les
Yes, i have the same fear with the fly screen.
In the meanwhile i made two more holes, making it more even.
but 7 holes is the max. number the pump will do, more and some holes will
stop bubbling.
It is fine now however, and i'm satisfied with it right now. but that
won't last i guess.
The etching is much faster now.
ST
2004-12-09 by Ben H. Lanmon
> Right.
reality
> ammonia based) or
just try
> around)
> ST
On the can under Clean Up they say to use Lacquer Thinner, and for
Over Spray Clean Up to use Paint Thinner.  They make several types
of spray paint products some are Enamel and Latex also, part of the
Sherwin-Williams Company one of the largest paint Companies in the
U.S.
You can take a look at their products at www.krylon.com
Ben
Inkjet transfer
2004-12-10 by lez
An Idea just ran through my head, but....
As inkjet printing wont hold up to the etch etc, and it comes off, cant
that be used to an advantage?
ie print what you /want/ etched off on an inkjet onto the copper, then
spray with a resist agent, IE cheap car paint, then wash and hopefully
the areas that where inkjet printed will wash away leaving copper to be
etched?
(stop laughing at the back....)
Re: [Homebrew_PCBs] Inkjet transfer
2004-12-10 by pebo festus
no laughing here, i already have a printer ready to
print pcbs, i had the same idea and am going to try it
later on. was using a printer with built in print
nozzels(epson)--but will go back to the printer with
nozzels in the print cartrage.
mebo
> it comes off, cant
> wash and hopefully
> etched?
Do you Yahoo!?
Meet the all-new My Yahoo! - Try it today!
http://my.yahoo.com
2004-12-10 by lez
I dont think where the nozzle is will be an issue, lots of inkjets can
now do cd etc like the epson r200/300 etc, been out a while will be a
discount model after december, will print direct down onto pcb and can
still do photo's etc to keep friend/family happy!
Only thing is finding something that will go over the ink, but let you
wash it off, without washing it off the copper.
And finding which cheap 3rd party ink cartridge works best, as genuine
ones cost a packet.
>mebo
the nozzle isnt an issue except when the nozzel on a
printer mounted nozzel stops up,then you have to throw
away the whole printer.if the nozzel stops up on the
cartrage --just get a new cartrage.believe me--i have
been there.
mebo
> lots of inkjets can
> a while will be a
> ones cost a packet.
> it
> with
> >mebo
Do You Yahoo!?
http://mail.yahoo.com
2004-12-10 by Stefan Trethan
On Fri, 10 Dec 2004 13:46:52 -0800 (PST), pebo festus <mebo31@...>
> been there.
> mebo
Yes, but there's a BUT.
The fixed-heads are usually piezo-jet and better quality while
the on-cartridge heads are thermo/bubble jet and as cheap as humanly (or
inhumanly) possible.
Piezo-jets seem more tolerant of different inks.
ST
Re: Inkjet transfer
2004-12-11 by pebo festus
here is a pic where i printed on a pcb.
http://f4.grp.yahoofs.com/v1/oFS6QYGAwga4EupkAfzTqr_42QCuaSsybaSdp7_hi
jPUJ5LUMGOcrtJS0tSJrwdxy8qU8ezpGq60IQ8Vt74z2UO3FTU/Direct%20Inkjet%
20Resist%20Printing/reg%20ink.JPG
mebo
<mebo31@y...>
> > been there.
> > mebo
humanly (or
> ST
Re: Inkjet transfer
oops---link didnt work---but its in the file section.
mebo
--- In Homebrew_PCBs@yahoogroups.com, "pebo festus" <mebo31@y...>
> mebo
> <mebo31@y...>
> > > been there.
> > > mebo
> humanly (or
> > ST
