New here and a question.
2007-11-05 by Chris
Hello,
I just joined and have been using ferric chloride to photo etch brass
sheets to make parts for models. This is a quick rundown of how it
works:
http://picasaweb.google.com/ErieChris333/Etching
I have read about using Sodium Persulfate instead of ferric chloride. I
heard it was cheaper and worked faster.
Can anyone here give me some insight. Does it really work better
(faster)? and were can I buy it and learn how to mix it?
Chris
Re: [Homebrew_PCBs] New here and a question.
2007-11-05 by Leon
Sent: Monday, November 05, 2007 8:19 AM
Subject: [Homebrew_PCBs] New here and a question.
> Hello,
> works:
Rapid Electronics (UK) sells it. I don't think it works any better, and it
doesn't keep once it is made up with water.
Leon
2007-11-05 by Markus Zingg
Chris,
I don't think that you can much optimize your process by changeing the
etchant. You easily can optimize the etching process itself though. You
may want to optimize some other steps in your process too:
a) exposure. Use an exposure unit (self built if you want, there are
plenty of projects/plans around) That way you expose the stuff in as few
as 10 seconds. The key factor here is the light source which should be
ultra violet.
b) The resist you use seems quite odd to me (requiereing wet
application). There is dry film resist out there which should do much
better. Simply laminate that one onto the brass. Should be a matter of
~3 minutes and not fuzzing around with water etc.
c) Build a bubble etcher with a heater element in int. That way I'm sure
you bring down your etching times significantly.
You CAN use alternative etchants (and others here surely will give you
replies), but be warned that the alternatives are much more agressive to
the envireonement or cost significantly more because you can only use
the mixture for one (or very few) etch process(es). The nice thing about
Fe3Cl is that it lasts very very long when compared to the alternatives
and it's dirt cheap, and is also less dangerous. Other etchants are
extremly agressive to all your metal stuff surrouding the area where you
etch. I mean it, you would not be the first one using this stuff just to
find out that all of a sudden a lot of things around you get an instant
rust layer.... Natriumpersulfat on the other hand is compareably
expensive and does not last very long.
Just my 2\ufffd
Markus
Re: New here and a question.
2007-11-06 by Chris
Markus,
Thanks, I will just stick to Ferric Chloride.
If it's daytime I expose outside in about 1 minute.
I am interested in the resist film you mentioned. The stuff I use if
from Micro Mark and I think is what people use to sandblast images on
glass. Can you post a link to where I can buy what your talking about?
Chris
--- In Homebrew_PCBs@yahoogroups.com, Markus Zingg <homebrew-pcb@...>
wrote:
> Chris,
You
are
as few
be
> ultra violet.
much
of
sure
you
agressive to
use
about
alternatives
where you
just to
instant
> Just my 2¢
> Markus
Re: [Homebrew_PCBs] Re: New here and a question.
2007-11-06 by Markus Zingg
Chris,
I use Ordyl Alpha 900, but there are other products around. They are
used to produce PCBs. You may want to contact a board house near you to
ask for a local supplyer and what they use. The "problem" with the
resist is that you usually must buy two complete rolls. The smallest
ones tend to be 150m. But if you are a member of a forum or something
that does the stuff you do (and I get the impression that's the case),
then you may easily can motivate others to buy a set of rolls for a few
members. I did a similar thing. I bought two rolls, used one for my own
needs but sold the other to a group of people thereby cutting my costs
in half. A roll, when stored in a fridge and when you hand cut peaces of
it will last ~2 years. Depending on the product, the storeage capability
depends on the environement temperature (should be below 10 degrees
celsius) and in some cases the exposure to oxygene. The good thing about
the ordyl alpha is that it is not that much critical with regard to
oxygene that said it's sufficient to store the roll in the fridge. :-)
HTH
Markus
Chris schrieb:
> Markus,
> Thanks
> Chris
> <mailto:Homebrew_PCBs%40yahoogroups.com>, Markus Zingg <homebrew-pcb@...>
> wrote:
> > Chris,
> the
> You
> are
> as few
> be
> > ultra violet.
> much
> of
> sure
> you
> agressive to
> use
> about
> alternatives
> where you
> just to
> instant
> > Just my 2\ufffd
> > Markus
2007-11-06 by Chris
Thanks I will look for it. Google only got 10 results with only 3 of
those in English.
I have seen whole rolls of what I buy, but I haven't ordered because
I don't know if it is an exact match. I get my stuff from here:
<http://www.ares-server.com/Ares/Ares.asp?
MerchantID=RET01229&Action=Catalog&Type=Product&ID=83130>
and have been through about 25 rolls so far.
Chris
wrote:
> Chris,
are
you to
smallest
something
case),
few
own
costs
peaces of
capability
about
fridge. :-)
> HTH
> Markus
> Chris schrieb:
> > Markus,
if
images on
about?
> > Thanks
> > Chris
pcb@>
> > wrote:
> > > Chris,
changeing
> > the
though.
> > You
> > are
in
> > as few
should
> > be
> > > ultra violet.
> > much
matter
> > of
I'm
> > sure
give
> > you
> > agressive to
only
> > use
thing
> > about
> > alternatives
are
> > where you
> > just to
> > instant
> > > Just my 2¢
> > > Markus
Optically the resist looks like the one I used bevore switching to the
Ordyl, but do you really have to apply it wet??
I belive you went through 25 so small rolls :-) The nice thing about
this offer in your link is at the sime time also the bad thing about it.
I mean it's nice that you can buy in such small quantities, but with
that price ($8 something) you could have bought a whole lot more by
buying "big" rolls.
I figure you live in a totally different area of the world (US I guess)
that's why it does not make sense to give you pointers to my suppliers.
Again, my advice to you is to contact a local board shop and politely
explain what you do and ask for a pointer to their resist suppliers.
Markus
> those in English.
> <http://www.ares-server.com/Ares/Ares.asp?>
> Chris
> wrote:
> > Chris,
> are
> you to
> smallest
> something
> case),
> few
> own
> costs
> peaces of
> capability
> about
> fridge. :-)
> > HTH
> > Markus
> > Chris schrieb:
> > > Markus,
> if
> images on
> about?
> > > Thanks
> > > Chris
> pcb@>
> > > wrote:
> > > > Chris,
> changeing
> > > the
> though.
> > > You
> > > are
> in
> > > as few
> should
> > > be
> > > > ultra violet.
> > > much
> matter
> > > of
> I'm
> > > sure
> give
> > > you
> > > agressive to
> only
> > > use
> thing
> > > about
> > > alternatives
> are
> > > where you
> > > just to
> > > instant
> > > > Just my 2\ufffd
> > > > Markus
