Fairlight-CMI
Index last updated: 2026-04-29 00:03 UTC
Q133 card and lithium battery
2008-08-26 by billyrockplay
Hello Fairlight people
My QWERTY is not responding and I was wondering if replacing the battery would restore
functionality.  Ed Hughes suggests replacing battery. Have re-seated cards to no avail. Comp
boots up fine but no response from QWERTY. My question; can I replace a 3.6V 1500mAh
Lithium Wafer Cell with a 3.6V 1700mAh Lithium Wafer Cell? Radio shack says no problem
but I figured I'd ask my Fairlight mates. I have a series III running rev 5.14. My machine has
been so reliable and integral to my music making since  (man, its been awhile) - well since I
got it.
Though I don't post often I visit this forum daily, reassured that others are still making music
with this machine as well.
Peace and thanks from NY
Billyrock
Re: Q133 card and lithium battery
2008-08-27 by billyrockplay
Hi guys - my update. I was able to borrow a QWERTY keyboard from NYU (no telling what
injuries this particular kybrd has suffered while institutionalized)   - where Suzanne Vega's
old series III resides but when I got back to my studio and plugged it into my machine,
trying both ports on the music kybrd and on back of the cpu I got the same result (no
response).  There is a wild card I haven't mentioned but will now. When I opened up the
front of the machine to re-seat the q133 card there were little bits of the air filter all over
the inside of the machine (the filter having apparently disintegrated and been flown all
over the insides by the fans).  I don't know what result this might cause but I cleaned up
the insides, re-seated all the cards and am still a Fairlight junkie without a fix.
I am going to replace the battery - previous battery installed Dec 2003 - in hopes that
this will clear things up. Oh - and yes Laurent I did check the back of the CPU and all
voltages appear to be ok.  Thanks for all your responses and suggestions my Fairlight
brothers. I'll keep you posted.
Billyrock
--- In Fairlight-CMI@yahoogroups.com, Alexander Guelfenburg <vmebay@...> wrote:
> ...indeed, cabling is a real issue. Within this
> year we have had 3 (!) CMIs IIX for service with
> this problem. Each time the cable was broken
> somewhere in the middle. Check this out!
> Good luck,
> Alexander
>          Virtual Music´s Synthesizer Service
>          Phone / Fax: ++43 (0) 1 - 905 94 27
>          E-Mail: mailto:a.guelfenburg@...
>          Web Page: http://www.virtual-music.at
Re: [Fairlight-CMI] Re: Q133 card and lithium battery
2008-08-29 by Harald Feldmann
Here's a suggestion for you:
Under the machine, where those desintegrated air filters are, there is
a row of small fuses, including at least one for the keyboard. You may
check those as well. You can take off the bottom cover by unscrewing
all the screws on the white bottom plate. I recommend doing this while
the machine is resting on the small side where the cards are, not with
the machine on its top because in that case all the mess with fall
into the interior if it hasnt already.
I had the same problem with the air filter today and just finished
cleaning the unit. I now have a display issue but that is likely a
wrongly inserted card. I have a Q356 and it was in either of the Q256
slots. Probably I used the wrong slot.
>Billyrock
>> Good luck,
>> Alexander
>Yahoo! Groups Links
2008-08-29 by billyrockplay
Hi Harald - thanks for the suggestion, I will check them but wouldn't the LEDs on the back
of the machine indicate if something was amiss with fuses? Also - I should have
mentioned in description of my problem that over the past month or so the machine
would freeze (meaning QWERT would become unresponsive) while working. This seemed
to happen while tending to other matters (such as recording audio tracks or mixing, fixing
using DAW Digital Performer. in hindsight it would seem the card (or whatever is the
nature of the prob is) was on its way out.  I would re-boot Fairlight and all would be well
for a while.
As far as the battery - a new dilemma:
I have a question about the battery.  This is the battery
Radio shack initially
Shipped;
http://www.Radioshack.com/product/index.jsp?productId=2715443
As
You can see  - its not the same size as the battery on the card though the
Salesperson I insisted it would do the job. I sent these back and read the
Product # and battery info to the sales person - trying to get the exact
Same battery as on the q133 card - and to my dismay today when I checked the email
from radio
Shack it seems as though they are sending me the same battery again. Will
This battery work?
Product info radio shack sent me for attempted second
Purchase:
I am determined to keep my III functioning as long as I am able to make music.
what
Vega's
over
up
> >Billyrock
> >--- In Fairlight-CMI@yahoogroups.com, Alexander Guelfenburg <vmebay@> wrote:
> >> Good luck,
> >> Alexander
> >Yahoo! Groups Links
2008-09-07 by billyrockplay
update: borrowed QWERTY, replaced (correct) battery on Q133 card, re-seated
cards,
checked fuses- nothing has helped so far. Maybe the machine is not fully
booting up. In
the text line at top of DIR page there is a small space right after the word
"fairlight." need
some help diagnosing problem. not sure Q133 card is the source of my problems.
people
and yes - if there was a way to have modern storage devices easily incorporated
into a
series III, rev 5.14 i would be interested.
Billyrock
--- In Fairlight-CMI@yahoogroups.com, "billyrockplay" <billyrockplay@...> wrote:
restore
Comp
1500mAh
problem
has
since I
> got it.
music
> Billyrock
Re: Question - midi boards
i want to see if the midi board (MIDI/SMPTE, output boards: CMI-332, CMI-333), is the
cause of my problems. can i pull this card out and run my CMI?  anybody know?
thanks guys
> cards,
> booting up. In
> "fairlight." need
> Thanks
> people
> into a
> Billyrock
> --- In Fairlight-CMI@yahoogroups.com, "billyrockplay" <billyrockplay@> wrote:
> restore
> Comp
> 1500mAh
> problem
machine
> has
> since I
> > got it.
making
> music
> > Billyrock
i believe its the CMI-28 board in my machine
is the
thanks guys
> thanks guys
> > cards,
> > booting up. In
> > "fairlight." need
> > Thanks
> > people
> > into a
> > Billyrock
> > restore
avail.
> > Comp
> > 1500mAh
> > problem
> machine
> > has
well
> > since I
> > > got it.
> making
> > music
> > > Billyrock
