Doepfer
Re: Analogue Solutions BD88 and BD99 into Doepfer G6
2013-05-30 by julianfincham
From memory (which may be wrong!) you will want the narrower, 10 pin cables, and you will need to twist them.
The pcbs should have the pin voltages / polarity marked, so just be sure that you line this up correctly with the doepfer bus board - the tech spec of which is on the website somwhere.
Julian
2013-05-30 by Kim Johnsson
Hi guys,
I wonder if you can help me. Some time ago I bought the AS BDxx modules
second hand, but they came without the power cable. Do you know whether the
standard Doepfer flat cables (as well as apparently the additional +5V
adapter for the BD99) work for installation into my Doepfer G6, and if not,
what cables should I get?
Kim Johnsson
I just had a look for you - its outlined in this document fairly well -
http://www.analoguesolutions.org.uk/concussor/manuals/concussor.pdf
It suggests (i think) using the 16 pin cable, and just offsetting it, but i found that was not possible on some A.Sol modules, due to component density.
YYMV : )
Julian
Re: [Doepfer_a100] Re: Analogue Solutions BD88 and BD99 into Doepfer G6
Hi Julian,
cables,
that
which
OK, thanks. This is where I get slightly nervous. There's *very* little
DIY:er in me :-)
Cheers,
Kim
Re: [Doepfer_a100] Analogue Solutions BD88 and BD99 into Doepfer G6
2013-05-30 by analogmonster@ymail.com
On 30 May 2013, at 18:36, Kim Johnsson <johnssonkim@gmail.com> wrote:
> Hi guys,
> Regards,
> Kim Johnsson
> Reply via web post	 Reply to sender	 Reply to group	Start a New Topic	Messages in this topic (1)
> RECENT ACTIVITY: New Members 1
> Visit Your Group
> Switch to: Text-Only, Daily Digest • Unsubscribe • Terms of Use • Send us Feedbac
I recently bought an as rs-95 vco. They are not directly compatible. Rs has no cv and gate bus, and the order of the power lines on the as is different.  Just changing the connector type on the end of the ribbon cable will almost certainly damage your module.
 You need to build or buy an adapter. I made my own but ive seen them about, synovatron has some on ebay right now (searched for doepfer adapter) but im pretty sure there are others available
> > Hi guys,
> > Regards,
> > Kim Johnsson
> > Visit Your Group
> Reply via web post	 Reply to sender	 Reply to group	Start a New Topic           	Messages in this topic (5)
> Visit Your Group
> Switch to: Text-Only, Daily Digest • Unsubscribe • Terms of Use • Send us Feedback
Probably an even better option for you considering the fear of diy- schneidersladen sell exactly the cables you need, no adapters or diy required
http://www.schneidersladen.de/en/analogue-systems-doepfer-adapterkabel-2
2013-06-01 by Kim Johnsson
Hi guys,
i found that
Yeah, I checked that one out as well. My interpretation of it is that it
should work for me.
That appears to me to be for using an AS case with Doepfer modules, but it
might work the other way around as well?!?
schneidersladen
I wondered about this: It's for Analogue Systems, not Solutions, but they
could of course be compatible...?
I think I'll throw an email at Schneider's...
Cheers, and thanks for your help,
Kim
> > > Hi guys,
> whether the
> not,
> > > Regards,
> > > Kim Johnsson
> > > Visit Your Group
> > > Switch to: Text-Only, Daily Digest � Unsubscribe � Terms of Use � Send
> us Feedbac
> > Visit Your Group
> us Feedback
> required
2013-06-01 by analogmonster@ymail.com
Ignore me when i read AS i thought analogue systems, should have read the post title. nothing i suggested was correct for your modules.
On 1 Jun 2013, at 12:10, Kim Johnsson <johnssonkim@gmail.com> wrote:
> Hi guys,
> i found that
> should work for me.
> schneidersladen
> Kim
>>>> Hi guys,
>> whether the
>> not,
>>>> Regards,
>>>> Kim Johnsson
>>>> Visit Your Group
>> us Feedbac
>>> Visit Your Group
>> us Feedback
>> required
2013-06-02 by Kim Johnsson
OK, will do :-)
Cheers,
Kim
