Doepfer
Re: AW: AW: [Doepfer_a100] A-177-2 External Foot Controller II voltages?
AW: AW: AW: [Doepfer_a100] A-177-2 External Foot Controller II voltages?
2013-06-03 by yahoo@doepfer.de
> Dear Dieter,
> Many thanks for taking the time to respond personally to this.
> If I may one quick last question before I return the FP5 to the dealer;
> is it possible for me to calibrate it myself to save posting it
> back to Berlin?
> Regards,
> Neal
I do not recommend this as the FP5 warranty will be void.
Short form: you have to loose the nut that holds the potentiometer inside
the FP5 and adjust the potentiometer so that in the low position 0V are
generated by the A-177-2. Sometimes it's not sufficient to rotate the
potentiometer only and the potentiometer has to be removed and mounted again
with another angle. That's a bit tricky because of the control shaft that
operates the potentiometer. We also found that some FP5 are wired in the
wrong way from the factory. In this case the wires have to be re-wired in
the right way. I'd strictly recommend to return the FP5 and ask for a
"Doepfer approved" FP5.
Best wishes
Dieter Doepfer
