Doepfer
a-190 velocity problem
2012-08-05 by skp_pete
hello,   i've got a weird issue concerning the a-190 when used with the velocity out from CV2.   i've had the module for over 2 years and its been fine up until now
i'm using the velocity to control the volume on my vca's .
i'm essentially getting spikes in volume on some notes, or some notes dont play
the midi notes with velocity are programmed in ableton
i've tried both my a-132-4 and my a-131 vca's and i get the same response.  normally the patches consist of differing notes lengths and velocity of course but here's a very simple patch to explain :
velocity into CV of vca
osc into vca in
vca out to speakers
all midi notes set to velocity 100
basically sounds like the voltage coming from CV2 is not steady
its got me me miffed
thanks
AW: [Doepfer_a100] a-190 velocity problem
2012-08-06 by yahoo@doepfer.de
> notes dont play
> osc into vca in
> vca out to speakers
> thanks
Provided that all transmitted velocity values are indeed 100 the CV2 should
stay at a fixed voltage. If this does not apply something seems to be wrong.
Please contact our A-190-1 specialist Matthias Marass
(keyboards(at)doepfer(dot)de) to find out what's wrong.
Best wishes
Dieter Doepfer
Re: a-190 velocity problem
2012-08-08 by skp_pete
> > notes dont play
> > osc into vca in
> > vca out to speakers
> > thanks
> Best wishes
> Dieter Doepfer
thanks for that, i just sent him an email
Re: [Doepfer_a100] Re: a-190 velocity problem
2012-08-08 by Florian Anwander
Hello
one thing comes to my mind: What is the note length of the notes?
I could imagine that the interface can get difficulties with minimal
note lengthes.
Florian
Am 08.08.2012 14:35, schrieb skp_pete:
>>> notes dont play
>>> osc into vca in
>>> vca out to speakers
>>> thanks
>> Best wishes
>> Dieter Doepfer
http://fa.utfs.org/
AW: [Doepfer_a100] Re: a-190 velocity problem
2012-08-08 by yahoo@doepfer.de
> Hello
> note lengthes.
> Florian
I don't think that this could be a problem because the velocity value is an
integral part of the 3 byte note on message.
But another idea came to my mind: maybe note off messages with embedded
velocity values are sent. I don't know if the note off velocity values are
also used for the CV2 calculation. Christian Assall (software@doepfer.de)
knows details because he programmed the firmware of the A-190-1.
Best wishes
Dieter Doepfer
Am 08.08.2012 16:33, schrieb yahoo@doepfer.de:
That is what I meant. To my knowledge Ableton does send noteOff with
noteOff-velocity.
Florian
http://fa.utfs.org/
2012-08-09 by skp_pete
thanks for the thoughts guys
i'll have a play with note off velocity
i've been in contact with Matthias and i have a few things to try for trouble shooting
2012-08-13 by skp_pete
well well
another nail in the coffin for access virus ti
Thanks for your help with this, and sorry to waste your time.   The culprit is my access virus ti midi output.
i should just presume these days when i have strange events occur that the access is to blame!!
the a-190 works fine when i use my edirol midi interface, as apposed to the access ti
thanks for your help
