Epson 2200 banding w/BO - Clayton? Anyone?
2006-07-24 by sagaface
I have gone through the archives and found your suggestion, Clayton, to set the alignment to a lower number, so I set it to #2 as you had. I am finding the dither pattern different, more horizontal now, but not really any better. any other suggestions? I'm losing my mind over this (not to mention ink/paper)! Thank you, Sarah
2006-07-24 by Clayton Jones
Hello Sarah, >I have gone through the archives and found your suggestion, Clayton, >to set the alignment to a lower number, so I set it to #2 as you had. >I am finding the dither pattern different, more horizontal now, but >not really any better. >any other suggestions? I'm losing my mind over this (not to mention >ink/paper)! I understand your frustration (been there, got the t-shirt and the coffe mug). I can't find any earlier posts in this topic, so I don't know exactly what the problem is (there are two kinds of banding). Dither banding is very small banding that usually only shows up in certain zones, ususlly dark ones around II or III. I was never able to totally get rid of this, but using the low alignment number minimized it to where a glass was needed to see it. Microbanding is more noticeable and occurs everywhere regardless of zone. This is usually caused by a clogged nozzle. Does your problem fit into either of these? Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
Hi Clayton..thanks for your reply. I did a nozzle check and that doesn't appear to be the issue. What I'm seeing in the print is both a horizontal and vertical banding pattern in a large area of midtone, though I'm not seeing it in all areas. I'm just stumped. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> > Hello Sarah, > > >I have gone through the archives and found your suggestion, Clayton, > >to set the alignment to a lower number, so I set it to #2 as you had. > >I am finding the dither pattern different, more horizontal now, but > >not really any better. > >any other suggestions? I'm losing my mind over this (not to mention > >ink/paper)! > > I understand your frustration (been there, got the t-shirt and the > coffe mug). I can't find any earlier posts in this topic, so I don't > know exactly what the problem is (there are two kinds of banding). > Dither banding is very small banding that usually only shows up in > certain zones, ususlly dark ones around II or III. I was never able > to totally get rid of this, but using the low alignment number > minimized it to where a glass was needed to see it. Microbanding is > more noticeable and occurs everywhere regardless of zone. This is > usually caused by a clogged nozzle. Does your problem fit into either > of these? > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm >
2006-07-24 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > I did a nozzle check and that doesn't appear to be the issue. What I'm seeing in the print is > both a horizontal and vertical banding pattern in a large area of midtone, though I'm not > seeing it in all areas. Sounds like the screen door effect from some odd resolution. What's the resolution of the image? Test by changing the resolution to 360 or 720 with resampling on.
Hi john... ...the resolution is 240. Do I use bicubic, smoother, or sharper to up-res? --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > I did a nozzle check and that doesn't appear to be the issue. What I'm seeing in the print is > > both a horizontal and vertical banding pattern in a large area of midtone, though I'm not > > seeing it in all areas. > > Sounds like the screen door effect from some odd resolution. What's the resolution of the > image? Test by changing the resolution to 360 or 720 with resampling on. >
Sarah, >I did a nozzle check and that doesn't appear to be the issue. What >I'm seeing in the print is both a horizontal and vertical banding >pattern in a large area of midtone, though I'm not seeing it in all >areas. Hmmm...I've never seen or heard of such a thing. It might be something in the image that a res change might fix, as John suggested. Does it do it with other images? Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
> Does it do it with other images? Well, there's the rub. Sometimes it does and sometimes it doesn't. I used to think it happened when I did too much post-processing (I tend to take normally exposed images and add a lot of contrast with curves), but I did very little to this image and it doesn't make sense to me that only part of the image shows this pattern (Half of a nude woman...the other half looks fine...same tones.). A previous image was worked up much more and printed flawlessly in BO. So anyway, I'm trying the up-res right now and will let you know if it helps. Crossing my fingers. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> > Sarah, > > >I did a nozzle check and that doesn't appear to be the issue. What > >I'm seeing in the print is both a horizontal and vertical banding > >pattern in a large area of midtone, though I'm not seeing it in all > >areas. > > Hmmm...I've never seen or heard of such a thing. It might be > something in the image that a res change might fix, as John suggested. > Does it do it with other images? > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm >
and it does indeed look like a screen door! --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > >I did a nozzle check and that doesn't appear to be the issue. What > >I'm seeing in the print is both a horizontal and vertical banding > >pattern in a large area of midtone, though I'm not seeing it in all > >areas. > > Hmmm...I've never seen or heard of such a thing. It might be > something in the image that a res change might fix, as John suggested. > Does it do it with other images? > Clayton I've seen the horizontal and vertical banding with QTR but not with the Epson driver...but I have never printed Black Only so it might be a long shot. With QTR an image with a resolution of around 675+- will have that screening effect. Resample it to 720 image is fine. I think it's a bug in QTR.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > Hi john... > > ...the resolution is 240. Do I use bicubic, smoother, or sharper to up-res? Smoother!
okay...kindergaarten question: I resampled to 720, and the image on my monitor took a jump. But in the print dialogue I assumed I would have to reduce the print size to fit the paper after that but nothing changed there. Am I missing something? --- In DigitalBlackandWhiteThePrint@...m, "John Vitollo" <jvlist@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@> wrote: > > > > >I did a nozzle check and that doesn't appear to be the issue. What > > >I'm seeing in the print is both a horizontal and vertical banding > > >pattern in a large area of midtone, though I'm not seeing it in all > > >areas. > > > > Hmmm...I've never seen or heard of such a thing. It might be > > something in the image that a res change might fix, as John suggested. > > Does it do it with other images? > > Clayton > > I've seen the horizontal and vertical banding with QTR but not with the Epson driver...but I > have never printed Black Only so it might be a long shot. With QTR an image with a resolution > of around 675+- will have that screening effect. Resample it to 720 image is fine. I think it's > a bug in QTR. >
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > okay...kindergaarten question: > > I resampled to 720, and the image on my monitor took a jump. But in the print dialogue I > assumed I would have to reduce the print size to fit the paper after that but nothing > changed there. Am I missing something? OK...since your image was 240 or so, go to 360...but make sure resample is on to keep same dimensions.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > okay...kindergaarten question: > > > > I resampled to 720, and the image on my monitor took a jump. But in the print dialogue I > > assumed I would have to reduce the print size to fit the paper after that but nothing > > changed there. Am I missing something? > > OK...since your image was 240 or so, go to 360...but make sure resample is on to keep same > dimensions. Sorry...getting sleepy.... OK again I see you did resample. When you resample only the resolution will change, not the physical dimension of the image.
I'm toasted. Been at this for hours. Will post tomorrow with results. Thanks so much and goodnight! Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > okay...kindergaarten question: > > > > I resampled to 720, and the image on my monitor took a jump. But in the print dialogue I > > assumed I would have to reduce the print size to fit the paper after that but nothing > > changed there. Am I missing something? > > OK...since your image was 240 or so, go to 360...but make sure resample is on to keep same > dimensions. >
side note: no banding with QTR and this image, but the blacks don't compare to BO, which is why I don't use QTR much. I ama huge BO printing fan and normally have no issues with it. Sometimes this whole process is really discouraging. ~sigh~ on that pitiful note I'm off to sleep this round away. Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > I'm toasted. Been at this for hours. Will post tomorrow with results. > > Thanks so much and goodnight! > Sarah > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@> wrote: > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > > > okay...kindergaarten question: > > > > > > I resampled to 720, and the image on my monitor took a jump. But in the print > dialogue I > > > assumed I would have to reduce the print size to fit the paper after that but nothing > > > changed there. Am I missing something? > > > > OK...since your image was 240 or so, go to 360...but make sure resample is on to keep
> same > > dimensions. > > >
Well, no success with the up-res. I still can't correct that part of the image that has the "screen door effect". It is really puzzling and frustrating. If anyone has any further suggestions I'd be much obliged. I hate to scrap this image becuase I can't print it satisfactorily. Thank again, Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > side note: no banding with QTR and this image, but the blacks don't compare to BO, which > is why I don't use QTR much. I ama huge BO printing fan and normally have no issues with > it. > > Sometimes this whole process is really discouraging. ~sigh~ > > on that pitiful note I'm off to sleep this round away. > Sarah > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > I'm toasted. Been at this for hours. Will post tomorrow with results. > > > > Thanks so much and goodnight! > > Sarah > > > > > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@> wrote: > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> > wrote: > > > > > > > > okay...kindergaarten question: > > > > > > > > I resampled to 720, and the image on my monitor took a jump. But in the print > > dialogue I > > > > assumed I would have to reduce the print size to fit the paper after that but nothing
> > > > changed there. Am I missing something? > > > > > > OK...since your image was 240 or so, go to 360...but make sure resample is on to > keep > > same > > > dimensions. > > > > > >
2006-07-24 by Stephen Petegorsky
Sarah - is the "screen door" effect something you can see in the image on the monitor if you look closely, or only something that shows up in the print?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Stephen Petegorsky <petegorsky@...> wrote: > > Sarah - is the "screen door" effect something you can see in the image on > the monitor if you look closely, or only something that shows up in the > print? I'm wondering if it could be a working space issue? What working space are you using? CONVERT to a different one to see if it helps. Sorry running out of ideas!
John - The reason I asked about whether or not she could see it on the monitor is because from time to time, I have found a similar pattern that looks like an larger "screen door" effect in the dark tones when using certain sensors at higher ISO ratings. Just a thought...
2006-07-24 by andy
Sarah This may be a silly suggestion but have you tried printing on different paper? I noticed this myself a little while ago.... I know it probably *shouldn't* make the slightest difference - but it's easy to try and it eliminates one variable! Good luck anyway - hope you got some rest! Andy
2006-07-24 by Steven Karafyllakis
Another silly question; I haven't seen anyone ask the most obvious one, maybe I just missed it back there: are you printing Uni or Bidirectional? Even if you've been able to print bidiretional for most images, this one may be setting up an interference type pattern because of a previously un-noticeable amount of mis-registration between the outgoing and returning headsweeps. So if you haven't done so already, turn it off and see if that helps Steven Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, andy <andy@...> wrote: > > Sarah > This may be a silly suggestion but have you tried printing on different > paper? I noticed this myself a little while ago.... I know it probably > *shouldn't* make the slightest difference - but it's easy to try and it
> eliminates one variable! > Good luck anyway - hope you got some rest! > Andy >
2006-07-25 by sagaface
Hi All...and thank you so much for your suggestions. I don't know what I would do w/o this forum. I seemed to have solved the problem, but I wish to heck I knew what did it. I did try another paper...same result. I also checked to see if there was evidence in the on-screen image...none. I did put a new Eboni cartidge in, though that was before the different paper and there was identical banding on that paper too. The other cartridge was brand new as well, so I don't know if maybe it wasn't sitting right or what. Or even if that what's did it. I also changed back to my usual wworking space, but I had been in that space when this was happening before, so not sure that had anything to do with it. I also reprocessed the raw image in a slightly different manner, but frankly, I doubt that was it. But who knows. So your guess is as good as mine. I wish there had been a clear-cut resolution, becuase I have a feeling it will happen again. It has in the past. Just not this bad. Thanks once again! Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <stevekphoto@...> wrote:
> > Another silly question; > > I haven't seen anyone ask the most obvious one, maybe I just missed it > back there: are you printing Uni or Bidirectional? Even if you've been > able to print bidiretional for most images, this one may be setting up > an interference type pattern because of a previously un-noticeable > amount of mis-registration between the outgoing and returning > headsweeps. So if you haven't done so already, turn it off and see if > that helps > > Steven Karafyllakis > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, andy <andy@> > wrote: > > > > Sarah > > This may be a silly suggestion but have you tried printing on > different > > paper? I noticed this myself a little while ago.... I know it > probably > > *shouldn't* make the slightest difference - but it's easy to try and > it > > eliminates one variable! > > Good luck anyway - hope you got some rest! > > Andy > > >
2006-07-25 by Daniel Staver
Hi! Just thought I'd let you all know that I got three images in the August issue of Black and White Photography Magazine. That's the British one, not the american photography collector magazine. The front page of the magazine and the three selected images are shown on my web-site: http://daniel.staver.no Although it's just a little entry in the reader section it's still the first time any of my work is published, so I'm really excited about this! I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's carbon curve on PremierArt Hotpress paper. After they selected three of the images I sent them grayscale TIFF files. Seems like color management worked very well as the magazine print match both what I see on my screen and on my own prints very well. -- Daniel Staver http://daniel.staver.no
2006-07-25 by Paul Roark
Congratulations. I'll definitely buy a copy. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Daniel Staver Sent: Tuesday, July 25, 2006 7:18 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Images published in Black and White Photography Magazine Hi! Just thought I'd let you all know that I got three images in the August issue of Black and White Photography Magazine. That's the British one, not the american photography collector magazine. The front page of the magazine and the three selected images are shown on my web-site: http://daniel. <http://daniel.staver.no> staver.no Although it's just a little entry in the reader section it's still the first time any of my work is published, so I'm really excited about this! I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's carbon curve on PremierArt Hotpress paper. After they selected three of the images I sent them grayscale TIFF files. Seems like color management worked very well as the magazine print match both what I see on my screen and on my own prints very well. -- Daniel Staver http://daniel. <http://daniel.staver.no> staver.no [Non-text portions of this message have been removed]
2006-07-25 by Gary W. Weaver
Great to hear about getting published!! I thought the web pages a bit slow. gar
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Daniel Staver Sent: Tuesday, July 25, 2006 8:18 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Images published in Black and White Photography Magazine Hi! Just thought I'd let you all know that I got three images in the August issue of Black and White Photography Magazine. That's the British one, not the american photography collector magazine. The front page of the magazine and the three selected images are shown on my web-site: http://daniel.staver.no Although it's just a little entry in the reader section it's still the first time any of my work is published, so I'm really excited about this! I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's carbon curve on PremierArt Hotpress paper. After they selected three of the images I sent them grayscale TIFF files. Seems like color management worked very well as the magazine print match both what I see on my screen and on my own prints very well. -- Daniel Staver http://daniel.staver.no [Non-text portions of this message have been removed]
2006-07-25 by David Neely
Daniel: Great stuff!! congrats on being published, I remember that feeling. I could not get your web site to bring up the images full, very slow so maybe you are getting a ton of hits.
-------Original Message------- From: Gary W. Weaver Date: 7/25/2006 10:25:22 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Images published in Black and White Photography Magazine Great to hear about getting published!! I thought the web pages a bit slow. gar -----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Daniel Staver Sent: Tuesday, July 25, 2006 8:18 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Images published in Black and White Photography Magazine Hi! Just thought I'd let you all know that I got three images in the August issue of Black and White Photography Magazine. That's the British one, not the american photography collector magazine. The front page of the magazine and the three selected images are shown on my web-site: http://daniel.staver.no Although it's just a little entry in the reader section it's still the first time any of my work is published, so I'm really excited about this! I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's carbon curve on PremierArt Hotpress paper. After they selected three of the images I sent them grayscale TIFF files. Seems like color management worked very well as the magazine print match both what I see on my screen and on my own prints very well. -- Daniel Staver http://daniel.staver.no [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
Thanks everyone! I just made some adjustments to the site, it should run much faster now. -- Daniel Staver http://daniel.staver.no
2006-07-25 by Clayton Jones
Congratulations Daniel, Way to go. Our local Barnes & Noble carries it so I'll have a look. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
It (your site) did run faster. But it takes the thumbs longer to load than does the main image. The clicked images do come-up on dial-up quickly. gar
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Daniel Staver Sent: Tuesday, July 25, 2006 10:55 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Images published in Black and White Photography Magazine Thanks everyone! I just made some adjustments to the site, it should run much faster now. -- Daniel Staver http://daniel.staver.no [Non-text portions of this message have been removed]
2006-07-26 by steveh0607
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Staver" <daniel@...> wrote: > Congradulations Daniel!!! The first of many I'm sure after seeing your work. I especially love the clock!!! :-)
> Hi! > > Just thought I'd let you all know that I got three images in the August > issue of Black and White Photography Magazine. That's the British one, not > the american photography collector magazine. The front page of the magazine > and the three selected images are shown on my web-site: > > http://daniel.staver.no > > Although it's just a little entry in the reader section it's still the first > time any of my work is published, so I'm really excited about this! > > I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's > carbon curve on PremierArt Hotpress paper. After they selected three of the > images I sent them grayscale TIFF files. Seems like color management worked > very well as the magazine print match both what I see on my screen and on my > own prints very well. > > -- > Daniel Staver > http://daniel.staver.no >
2006-07-26 by Mike Johnston
Congratulations! Mike J.
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Daniel Staver Sent: Tuesday, July 25, 2006 9:18 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Images published in Black and White Photography Magazine Hi! Just thought I'd let you all know that I got three images in the August issue of Black and White Photography Magazine. That's the British one, not the american photography collector magazine. The front page of the magazine and the three selected images are shown on my web-site: http://daniel.staver.no <http://daniel.staver.no> Although it's just a little entry in the reader section it's still the first time any of my work is published, so I'm really excited about this! I sent them twelve prints made with the 2100 and UT7 inkset, Paul Roark's carbon curve on PremierArt Hotpress paper. After they selected three of the images I sent them grayscale TIFF files. Seems like color management worked very well as the magazine print match both what I see on my screen and on my own prints very well. -- Daniel Staver http://daniel.staver.no <http://daniel.staver.no> [Non-text portions of this message have been removed]
2006-07-26 by Scott Jones
Congratulations Daniel!!! I still love your print that I have hanging on my wall. Keep up the good work. I am probably going to make the complete switch away from the darkroom this fall. Things are going very well with my digital printing with the R2400 and EPSG.... Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Staver" <daniel@...> wrote: > > Thanks everyone! > > I just made some adjustments to the site, it should run much faster now.
2006-07-26 by elwood@wsnconsult.com
Daniel Really exciting stuff man. Most sincere congratulations Woody Spedden
----- Original Message ----
Sent: Tuesday, July 25, 2006 8:53:22 PM
Congratulations!
Mike J.
From: DigitalBlackandWhit eThePrint@ yahoogroups. com
[mailto:DigitalBlackandWhit eThePrint@ yahoogroups. com]On Behalf Of Daniel
Staver
To: DigitalBlackandWhit eThePrint@ yahoogroups. com
Magazine
Hi!
http://daniel. staver.no <http://daniel. staver.no>
Daniel Staver
[Non-text portions of this message have been removed]2006-07-26 by Michael Vendrell
Powerful and beautiful Work! Do more... Michael Vendrell __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2006-07-26 by David Meddings
Great work Daniel. Couldn't have happened to a nicer guy and nice to see that someone who gives so much to the B&W community gets something nice happening back to him. Let's try and hook up NEXT time I'm in Oslo, OK? All the best to Teo and Song. David
2006-07-29 by Daniel Staver
Thanks so much everyone! I really appreciate all the good comments, both on and off list. I'm encouraged by this and want to get my work shown in more places. I'm preparing a portfolio for Lenswork, and I noticed there was a competition in Black and White Photography that I could participate in. I'm also going to hold a small exhibition in a local coffeeshop in october, which I really look forward to. I'd like to try more magazines, but we just don't get that many here in Norway, so I don't really know any others. Any other things I could try? -- Daniel Staver http://daniel.staver.no
2006-07-29 by Kent Gibbs
You might want to try Black and White Photography in the UK. http://tinyurl.com/raxgo They have a mix of traditional and digital. Kent --- Daniel Staver <daniel@...> wrote: > Thanks so much everyone! I really appreciate all the good comments, > both on > and off list. > > I'm encouraged by this and want to get my work shown in more places. > I'm > preparing a portfolio for Lenswork, and I noticed there was a > competition in > Black and White Photography that I could participate in. I'm also > going to > hold a small exhibition in a local coffeeshop in october, which I > really > look forward to. I'd like to try more magazines, but we just don't > get that > many here in Norway, so I don't really know any others. > > Any other things I could try? > > -- > Daniel Staver > http://daniel.staver.no > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish > to unsubscribe, please edit your Membership preferences by visiting > this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to > keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group > Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the > Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE > LOSSES (EVEN IF THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE > PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE > DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT > OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) > ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2006-07-30 by Alan Berkson
Daniel, Congratulations! FYI - I was lucky[?] enough to have 2 of my pictures chosen - from 72 submitted - for a Merit Award in the B&W Special Portfolio issue. Of course, I submitted 6 portfolios each with 12 images, so imagine the thrill! To the point, the single issue submissions were over by May so the next opportunity will be in the portfolio contest. Try to keep your portfolios quite narrow in scope with very similar style and subject matter as my submissions were grouped by very general criteria. The ones that were chosen [pages 113-114] were of manequins in store windows in NYC and the rest of the portfolio was other NYC images. I was so excited by my being published that I started a website - http://www.omages.com, to try to capitalize on my newfound "success". I also submitted a portfolio to Lenswork via their bonus gallery program on Lenswork Extended [the CD version of the magazine with many extras - a fabulous vehicle for learning about and viewing content from Lenswork] and am awaiting some response. The editor of Lenswork - Brooks Jensen - waxes poetically regarding making photographic art available to the masses, and he has done that in many ways through his magazine and the Extended CD. In fact, he asked readers to participate in what he called "The Experiment", where he allowed us to download some of his images, then shake them up in Photoshop or other editing programs, and return them to the magazine. They were shown in the Extended issue for Lenswork 64, and again I was gratefully surprised to have mine included in these submissions. Next, I want to submit images to Camera Arts, and maybe Focus magazine, though I think they want you to advertise in their mags along with submissions, but I may be wrong about that. I'm sure other members of this group have more information. Anyway, good luck! I'm sure that your talent and persistence will reward you in many ways. Alan http://www.omages.com [Non-text portions of this message have been removed]
