Digital BW, The Print
gamma - BO vs continuous tone
2006-04-20 by Brian Chapman
I did some experimenting last night and found that in order to match
my monitor I needed to use Gamma 1.8 (maybe even 1.5) when printing BO
and Gamma 2.2 when printing full ink.  The Gamma settings are the ones
in the Advanced options on the printer properties (R220).  All the
prints were made on EEM so there isn't anything in the paper that
would have made a difference.
Is this something that is common or does it mean something that I'm
not aware of?
Thanks!!  Brian
http://www.brianchapmanphotography.com
Re: gamma - BO vs continuous tone
2006-04-20 by Clayton Jones
Hello Brian,
>not aware of?
It's not an easy answer because what printer gamma setting works best
depends on what image profile is used.  There's a sort of push-pull
relationship between them.  Obviously this is what works for whatever
workflow you're using right now.  But if you were to begin using a
different default profile in color settings (which would affect how
the grayscale file is initially created), there might a different
result on the printer side.  So you can't make a blanket statement
about it.  There are too many workflow variables.  You just need to
find the combination that you like the best.
I'm using an R200 with R2-N right now, and am finding that I can use
the same settings I use for BO.  These are described in an article at
the link below.  I'm doing some experiments and will be writing an
article about it soon.
Clayton
Thanks for the info!  My goal is to get some consistency across my
prints/workflow - and you're right on about 'too many workflow
variables'!!  Assuming that I follow your instructions/settings
exactly then there shouldn't be a significant difference between BO
and full ink when using Gamma 2.2, correct?
As for my initial issue, the one potential (and potentially
significant as you mentioned below) issue is that I may or may not
have converted the image to grayscale prior to printing - and
therefore the image could have been using Adobe 1998 instead of DG20
which may have made a difference between the two ink settings (BO &
full ink).
Thanks again for the great articles and I definately look forward to
any you publish in the future!!
Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
<cj@...> wrote:
> Hello Brian,
match
printing BO
ones
I'm
> >not aware of?
best
whatever
use
at
> Regards,
> Clayton
2006-04-21 by Clayton Jones
Hello Brian,
Well, possibly not, because that wouldn't be following the
instructions exactly.  The article recommends using DG20 for the
default gray space setting and image profile, printer profile set to
Same As Source (or No Color Management in CS2), and printer gamma 1.8.
 With those settings I can go between BO and full ink printing.
That's the combination I've found that gives me the most versatility
and good WYSIWYG.  It isn't carved in stone - you can use anything you
want and make it work, but there are trade-offs for everything.  The
above combination is just a sort of sweet spot that I find most
convenient and hassle free.
>full ink).
Quite possibly.  I do everything in grayscale.  I did lots of
experiments in the early days and found no advantage to staying in RGB
mode, with files three times as big.  With a color digicam image I
manipulate the RGB channels during conversion to BW, but once that's
done I convert to grayscale.
BTW, an important part of this workflow is having the gray space in
Color Settings set to DG20.  Having it at GG2.2 and later assigning
the image profile to DG20 won't do the job.  The gray space setting is
what determines the actual image pixel values at the time of grayscale
conversion (or importing a scanned neg).  Assigning a different
profile later merely changes how it's displayed on screen - it won't
change the image or the print.  In order to do that the profile must
be Converted.  But if you convert after you have worked on the image
it will change everything you've done (it will look the same on screen
but will change the image and the print).  So it's best to have it go
to the profile you want right at the beginning, whether scanning a neg
or using a color digicam file.
Clayton
2006-04-21 by Brian Chapman
Thanks Clayton - I think the neurons might actually be starting to
fire. :)  ...finally.
<cj@...> wrote:
> Hello Brian,
my
BO
to
1.8.
versatility
you
The
not
DG20
> >full ink).
RGB
that's
setting is
grayscale
won't
must
screen
go
neg
> Regards,
> Clayton
2006-04-24 by Brian Chapman
Hey Clayton,
As it turns out, when I configured my settings exactly as you
describe I still felt there was a difference between the BO and full
ink methods, however, when I finally printed a step wedge, it turns
out that they look almost identical!
This is the test image - in hindsight I probably should have used
something else without a huge dark area...
http://www.flickr.com/photos/brianechapman/132207963/
So because there really isn't a difference I must be perceiving one
for some reason.  One possibility is that because the blacks are
more intense in the BO prints that it contributes to an overall
darker feeling when a large part of the image is dark.  The other is
that the transitions are different between the dark and darker areas
using BO vs full ink - the neutral full ink method looks gray
compared to the BO method at the same density so it may
appear "darker" when it really isn't.
I'd be interested in hearing if people have found that certain types
of images don't work well with BO printing...?  Anyway, I hope this
is interesting/helpful to someone...it is to me :)
Thanks, Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Chapman"
<brianechapman@...> wrote:
>in
Jones"
> <cj@> wrote:
> > Hello Brian,
> my
between
> BO
set
> to
gamma
> 1.8.
> versatility
anything
> you
> The
> not
> DG20
(BO
> > >full ink).
in
> RGB
I
> that's
in
assigning
> setting is
> grayscale
> won't
> must
> image
> screen
it
> go
a
> neg
> > Regards,
> > Clayton
2006-04-24 by sagaface
Hi Brian,
I use BO for most of my images but that is because my palette is quite dark AND high
contrast. For images that have small-step midtone gradations between pure black and
white I find QTR handles those better. BO's "dot" pattern will be more noticable if you have
large expanses of lighter tones, which turns some people off, though it doesn't bother me.
Still, in my images which as I said are very dark, I don't really deal with that issue much.
With the MIS Eboni ink and BO I feel like I could fall into the shadows, whereas with QTR
there's just a teeny bit less depth to my eye, but still enough for me to notice.
It's all extremely individual, I think. Step wedges and all the other measurements are very
helpful, but the bottom line is whether your eye likes the results, no matter what the
method or the popularity/preference of alternate methods by others. It's great to have
choices, and it's great to have a forum where you can explore and learn from others' often
more extensive experience. I know I have. Good luck with BO printing!
Sarah
> Hey Clayton,
> Thanks, Brian
> <brianechapman@> wrote:
> >in
> Jones"
> > <cj@> wrote:
> > > Hello Brian,
> > my
> between
> > BO
> set
> > to
> gamma
> > 1.8.
> > versatility
> anything
> > you
> > The
> > not
> > DG20
> (BO
> > > >full ink).
> in
> > RGB
> I
> > that's
> in
> assigning
> > setting is
> > grayscale
> > won't
> > must
> > image
> > screen
> it
> > go
> a
> > neg
> > > Regards,
> > > Clayton
2006-04-25 by Clayton Jones
Hello Brian,
Yes, there can be differences in both contrast and density because of
the very different way the inks are laid down, and the degree of
difference varies among different images.  Sometimes it requires an
adjustment curve to make one match the other.
Absolutely.  This is a given with BO printing.  Looks great with some,
 weak with others.  And it's hard to predict by looking at it on
screen.  I've been surprised many times.
Clayton
2006-04-25 by Brian Chapman
Thanks Sarah!
I really like the look of BO - partly because of it's warmth (I am
currently using only the neutral set of R2 inks) and partly because
I like the intensity of the blacks.  For the most part I'm not
bothered by the dots either, in fact I've been most impressed with
some of the lighter images!  Like Clayton mentioned, there are
definately surprises!
Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface"
<sagaface@...> wrote:
> Hi Brian,
quite dark AND high
for me to notice.
printing!
> Sarah
Chapman"
> > Hey Clayton,
full
turns
used
one
other is
areas
types
this
> > Thanks, Brian
Chapman"
> > >in
starting to
> > Jones"
> > > <cj@> wrote:
> > > > Hello Brian,
across
> > > my
workflow
> > between
> > > BO
profile
> > set
> > > to
> > gamma
> > > 1.8.
printing.
> > > versatility
> > anything
> > > you
everything.
> > > The
most
may
> > > not
and
instead of
> > > DG20
settings
> > (BO
> > > > >full ink).
staying
> > in
> > > RGB
> > I
once
> > > that's
space
> > in
> > assigning
> > > setting is
> > > grayscale
different
it
> > > won't
profile
> > > must
> > > image
on
> > > screen
have
> > it
> > > go
scanning
> > a
> > > neg
> > > > Regards,
> > > > Clayton
