Bass drum triggers by closing the Hi Hat
2004-08-13 by b_marc
I am using a DTXpress III special kit since a month and have to get
used to the terms used in the Forums.
My problem is that when I close the Hi Hat (footCl) the bass drumm is
triggered with it. I tried to search the Forum but could not get any
satisfying answer on how to reduce this effect. I suppose this
effetct is generally mentionned as crosstalk. Which parameters have
to be changed to reduce it. I tried to feedle on all the parameters I
thought could have to do with it without success.
Could somebody help a lost newbie. many thanks
Re: Bass drum triggers by closing the Hi Hat
2004-08-13 by emf
is
any
I
Here's my first thought on the subject. I could be all wet, but let's
see. To oversimplify, crosstalk normally occurs because the pads
occupy a common ground that allows vibrations from one pad to
propagate to the others. In most cases, the rack is the offending
medium, and rejection or specific-rejection settings (for problems
between two particular pads) can address the problem. In your case,
the kick and hi hat controller don't share a direct physical
connection, since both the hi hat and the kick pad are independent of
the rack. True, you could be on a flimsy wooden riser, but since
general crosstalk doesn't seem an issue, I'll assume that you aren't
on a platform that shakes like a 50 cent stepladder.
This leads me to believe that a faulty connection, rather than
crosstalk, is your problem. Did you by any chance connect the kick
pad to input 9, intending also to connect another pad to the kick to
access input 10? If so, you might have accidentally inserted the hi
hat controller stereo cable into the kick input by mistake (and the
cymbal mistakenly into the controller?). Unless I'm badly mistaken,
that arrangement would give you a kick sound when you closed the hi
hat because the stereo cable would access it. There are some
potential holes in this theory, but I'll throw it out as a first step.
Ed
get
drumm
> is
> any
have
parameters
> I
let's
of
aren't
to
step.
> Ed
Thanks for your response,
I checked the cables again and they are inserted correctly.
I installed the kit in a room with tiles on tge floor. Due to this I
put a carpet on it, so that the kits stands firm.
It might also help too mention, that when closing the hi hat the
kdrum does not apear all the time but there seems to be no logic.
The Hi Hat is also triggered just most of the times it triggers the
kdrum.
2004-08-13 by emf
I
> kdrum.
So kick goes to input 1 and hi hat to input 8/controller, right? I
don't suppose you're using a double pedal that might cause your foot
to stir the second pedal? Let's try an experiment. Go into the
trigger parameters for the kick pedal and raise specific rejection of
the hi hat input temporarily to 8. Your kick won't register anything
but the hardest hits. Now continue to stomp on your hi hat for as
long as you would think it should take for a false trigger of the
kick to appear. If the kick stays mute, then you'll have to find some
setting less than 8 that stops the crosstalk while also allowing you
some dynamics on the kick. If the crosstalk still happens, then
something is amiss internally. Frankly, I'm skeptical of the
crosstalk angle because using the hi hat controller wouldn't seem to
create much havoc physically under any conditions.
2004-08-13 by emf
foot
of
anything
some
you
to
OGD also sends the following clever suggestion along from points
unknown:
"Move the HH65 pedal as far away from the kit as possible and place
it on a pillow to completely isolate it from the floor. This should
completely isolate it from the KP65 piezo. Now stomp on the HH65.  If
the base drum voice sounds, then verify that only one voice is
assigned to the foot close. IF it doesn't sound then because of the
hard surface of the floor, the vibration is traveling from one to the
other. Also, make sure that the two pedals are not touching the rack
itself. If the HH65 is up against the horizontal foot support and the
top of the KP65 it pressing against the bottom red crossmember that
would also allow for transmission of the vibration between the two."
2004-08-14 by b_marc
this
> I
> > kdrum.
foot
of
anything
some
you
to
Tried both solutions without success, but... realized now
that when I play bare foot it got worth. So is it possible that the
triggers and/or my kit gets bad grounding over my body??????
Marc
2004-08-14 by emf
Here's another possibility: When you're not actually playing the
kick, do you keep the pedal close to or on the pad? If you do, it
might just trigger at the slightest instigation, and you might be
more apt to twitch the kick foot when you're stomping on the hi hat.
It doesn't take much. Try consciously keeping your beater away from
the pad when not in use.
Maybe I'm just old-fashioned, but I can't buy the electrical charge
theory. Another experiment? If you unplug the kick and stomp on the
hi hat, do you still get random kicks? If so, it's out of our hands.
If not, we should be able to locate the problem, even if it takes a
while.
2004-08-16 by b_marc
hat.
hands.
> while.
OK, Here is what I did:
1- I only slightly touched the Kick's pedal with the beater loose
(far away from the trigger). This still triggers the kick when
closing the Hi Hat.
2- Ths same thing like 1 but not touching the pedal with my foot.
This time the kick was not triggered when closing the Hi Hat.
3- Unplugged the Kick's cable and naturally the kick was not
triggered anymore.
Marc
2004-08-16 by emf
--- In DTXpress@yahoogroups.com, "drumsonly2002" <dan@n...> wrote:
> Just guessing, but could a loose wire cause this by a slight
> vibration caussing it to touch the pizeo and thus trigger the
> sample?
Or do you have the sensitivity knob on the kick pad itself turned up
too high? What are the gain and minimum velocity settings in the
trigger menu for that input?
2004-08-16 by oldguydrummer
If this has already been address, ignore.
If there were a stray ground pathway being generated, then simply
picking up the hihat pedal and touching the metal frame of the KP65
could trigger the KP65. Also, can you try to simply put a piece of
rubber on the bottom and top of the HH65 to "electrically" isolate it
from everything, including you, to see if that eliminates the
problem. If it does then you may have a loose wire and surgery maybe
required.
As far as sensitivity, if you take you finger and tap the flat part
of the KP65 frame that sits on the floor with the two spurs in it,
does the Piezo trigger. If it does, reduce the sensitivity down until
it no longer triggers.
Also, another thought:
Check to see if the voice for the Footclose has only one voice
assigned and not two. If a cross-velocity setting between voice 1 and
voice 2 for the footclose were setup so that "light" pressure on the
HH65 would trigger voice 1 (hi-hat close sound) and a "heavy"
pressure would trigger voice 2, then this would make sense, that
sometimes it triggers/sometimes it does not.
If you goto the voice edit mode (and learn mode is on), press down on
the hihat pedal to select:
KIT IN= footCl V=1
=H/015 K13 Clse     [This line will vary based on what you have setup]
Tab up to select V=1 using the <-Sel-> button and then change to V=2
using the <Val +> button. The default is:
=K/000 NoAssign
If you accidentally changed this to K/001 or any other voice number,
then the bass drum sound could be triggered when pressing down on the
Hihat pedal.
Hang in there, we get through this.
OGD
> the
> hat.
from
charge
> hands.
a
> > while.
> closing the Hi Hat.
> triggered anymore.
> Marc
2004-08-17 by b_marc
Tried all and the only thing which helps is putting my best isolating
shoos on, then it stops ??!!?? The longer I play the warmer and
sweetier I get and then it comes back, even with my winter shoes.
Did anybody ever try grounding the dtxpress or the rack to avoid this?
it
maybe
> required.
until
and
on
> KIT IN= footCl V=1
setup]
V=2
> =K/000 NoAssign
number,
> Hihat pedal.
> OGD
that
> > the
it
be
> > hat.
> from
> charge
> the
> > hands.
takes
> a
> > > while.
> > closing the Hi Hat.
> > triggered anymore.
> > Marc
I just grounded my kick pedal with the ground from the plug at it
works :) I even can play barefoot again.
Thanks to all who tried to help Ilearned a lot about the sttings.
Marc
isolating
this?
KP65
of
isolate
> it
> maybe
> > required.
part
it,
> until
> and
> the
down
> on
> > KIT IN= footCl V=1
> setup]
> V=2
> > =K/000 NoAssign
> number,
> the
> > Hihat pedal.
> > OGD
> that
> > > the
> the
do,
> it
might
> be
hi
> > > hat.
away
> > from
> > charge
on
> > the
> > > hands.
> takes
> > a
> > > > while.
loose
> > > closing the Hi Hat.
foot.
> > > triggered anymore.
> > > Marc
Re: [DTXpress] Re: Bass drum triggers by closing the Hi Hat
2004-08-17 by Creighton Higgins
I, for one, would be surprised if there is a ground loop through the
frame-if this were possible- one would expect a whole bunch of stray
triggers. Sadly I would recommend a factory reset- this will "restore"
normal voice and trigger settings and eliminate the possibility of a
second voice being assigned to the hi hat pad. I have never tried to set
up my hi hat as a second bass pedal- it sounds as though this might be
what happened?
Creighton
(just back from vacation and feeling...well kinda tired and sad)
2004-08-17 by emf
Marc,
That's fantastic. You really had it pegged yourself, though OGD was
in on it, too. I must admit, in my ignorance, I didn't think that a
stray current could wreak such havoc.
Ed
2004-08-17 by emf
--- In DTXpress@yahoogroups.com, Creighton Higgins <creighton@l...>
wrote:
> Marc wrote: "I just grounded my kick pedal with the ground from the
plug
> at it
> works  :)  I even can play barefoot again."
> I am so wrong- please disregard previous post.
> I think I will slink off now...
Hey, Creighton,
If great minds can think alike, so can small ones. If you slink back
to vacation, can I come?
Ed
2004-08-18 by Creighton Higgins
>plug
>>at it
>Hey, Creighton,
>Ed
>Community email addresses:
>  Post message: DTXpress@yahoogroups.com
>  Subscribe:    DTXpress-subscribe@yahoogroups.com
>  Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>  List owner:   DTXpress-owner@yahoogroups.com
>Shortcut URL to this page:
>  http://groups.yahoo.com/group/DTXpress
>Alternate DTXpress site:
>  http://www.dtxpressions.com
>Yahoo! Groups Links
Ya know Ed?
I think I am going through the stages of grief being back from vacation:
denial, anger, bargaining- oh no here comes the rage.  I sit at my desk
and stare at my normally familiar objects and wonder what I am supposed
to do with them. The one good thing so far is the regular updates from
this quirky community. Ah well. Good to get back to my drums and my band
Geriatrica rehearses tonight.
Creighton
2004-08-18 by b_marc
You should all feel good, as you tried to help a lost drummer.
Should we meet once a beer goes on me.
stray
will "restore"
a
to set
be
> what happened?
> Creighton
