I think the suggestion to disconnect everything but power and audio may be a good one. Try this for a little while, because one possibility is that something in your midi chain is sending it controller data like volume and cutoff. Do you think that is possible?
Alex
----- Original Message ----
ac010b4919@...>
To:
AN1x-list@yahoogroups.com
Sent: Thursday, February 14, 2008 9:10:01 AM
Subject: [AN1x] Re: Sound problems with AN1x
I have tested my AN1x with just the headphones connected and the
problem seems to have disappeared. I then tested with the line
outputs connected and still there is no problem. Finally I tested
with the headphones and line outputs both connected and again no
problems.
The problem seems to have disappeared.
Could it be that...
1) I pressed the "assign" button while powering on the synth that
fixed the problem
or
2) My AN1x is temperamental?
Cheers
Arthur
--- In AN1x-list@yahoogrou ps.com, "Arthur Alexander Crichton"
<ac010b4919@ ...> wrote:
> Haha its been along time since someone has called me Alex:) Ok, I
> have removed the left and right line outputs and left the
headphones
> in. So far the problem has disappeared. I will disconnect the
> headphones and connect the line outputs and see if the problem
> returns.
> I'll report back if there is any probems.
> Cheers
> Arthur
> --- In AN1x-list@yahoogrou ps.com, Jeff <jf.serviere@ > wrote:
> > Hello Alex!
> > as you describe your problem it looks like something wrong in the
> analog output circuit: dry solder joint, bad contact or some "ill"
op
> amp or transistor that goes out when hot. The heat related failure
is
> probable because it works well for a short time and after the sound
> decreases, a contact problem would occur more irregularly. I'm not
at
> home currently, so i cannot open mine to tell you what to look and
> where. I don't think it is a fatal issue at all, but it could take
a
> long time to find the faulty part.
> > You can try 2 things without opening the synth:
> > First remove all additional devices (effects, patch bay..)
between
> the AN1x and the amp or mixer.
> > Then turn on your synth with the line out plugged only,play it,
> > and after do the same thing without line out but with headphones
> only.
> > If you're using a mixer try another input with the line out
> connected.
> > Look (or more likely hear !) if there is some difference.. ..
> > Cheers
> > J.F.
> > > Message du 14/02/08 00:42
> > > De : "Arthur Alexander Crichton"
> > > A : AN1x-list@yahoogrou ps.com
> > > Copie à :
> > > Objet : Re: [AN1x] Sound problems with AN1x
> > > > Ok, I tried a factory reset and played the affected sounds
> again and
> > > it seemed to fix the problem. Then I leave my AN1x on and 5
> minutes
> > > later the problem comes back:(
> > > What will I do? Is my AN1x ready for the synth graveyard in the
> sky?
> > > Please advise
> > > Arthur
> > > ...> wrote:
> > > > How do I reload the OS?
> > > > Is it the same as a factory reset? If so, I did a factory
reset
> but
> > > > the problem still persists.
> > > > The problem is when I keep the key pressed the sound just
> abruptly
> > > > goes dull and low in volume which it shouldn't do. Its like
> > > > cutoff has gone to "0" and the main volume has gone low.
> > > > Cheers
> > > > Arthur
> > > > --- In AN1x-list@yahoogrou ps.com, nung242 wrote:
> > > > > I would try backing up your patches, then maybe reload the
> OS. It
> > > > worked for a problem I was having on my K-Station. Good Luck!
> > > > > http://www.youtube com/tillthenmusi k See the AN1x in
> > > > action on the song " legend "
> > > > > Arthur Alexander Crichton >
> > > > wrote: Hi,
> > > > > I have a problem with my Yamaha AN1x.
> > > > > When I select some pad sounds on my AN1x the sounds are
> bright
> > > and
> > > > > after about 3 seconds the sound just cuts off to a duller
> sound
> > > > which
> > > > > is very low in volume. When I press the keys again all I
get
> is
> > > a
> > > > > faint dull sound. I try to play the keys harder but I still
> get
> > > > this
> > > > > sound. Before I had this problem, those paticular patches
> used
> > > to
> > > > > sound bright and full. Also, I have noticed some sounds
sound
> > > > thinner
> > > > > than what they used to and that sounds that rely on
arpeggio
> or
> > > > lfo
> > > > > sound muddy and strange.
> > > > > What is wrong with my beloved AN1X?
> > > > > I have tried cleaning the control knobs with switch cleaner
> but
> > > I
> > > > > still get the same problem. BTW the rom version on my AN1x
is
> > > v1.02
> > > > > Please help.
> > > > > Arthur
> > > > > Never miss a thing. Make Yahoo your homepage.
> > > > > [Non-text portions of this message have been removed]
#ygrp-mkp{
border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;}
#ygrp-mkp hr{
border:1px solid #d8d8d8;}
#ygrp-mkp #hd{
color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;}
#ygrp-mkp #ads{
margin-bottom:10px;}
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
#ygrp-sponsor #ygrp-lc{
font-family:Arial;}
#ygrp-sponsor #ygrp-lc #hd{
margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;}
#ygrp-sponsor #ygrp-lc .ad{
#ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
float:left;white-space:nowrap;}
.bld{font-weight:bold;}
#ygrp-grft{
font-family:Verdana;font-size:77%;padding:15px 0;}
#ygrp-ft{
font-family:verdana;font-size:77%;border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;}
#ygrp-vital{
background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:uppercase;}
#ygrp-vital ul{
padding:0;margin:2px 0;}
#ygrp-vital ul li{
list-style-type:none;clear:both;border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-right:.5em;}
#ygrp-vital ul li .cat{
font-weight:bold;}
#ygrp-vital a{
#ygrp-vital a:hover{
text-decoration:underline;}
#ygrp-sponsor #hd{
color:#999;font-size:77%;}
#ygrp-sponsor #ov{
padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;margin:0;}
#ygrp-sponsor #ov li{
list-style-type:square;padding:6px 0;font-size:77%;}
#ygrp-sponsor #ov li a{
text-decoration:none;font-size:130%;}
#ygrp-sponsor #nc{
background-color:#eee;margin-bottom:20px;padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
#ygrp-sponsor .ad #hd1{
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%;}
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
blockquote{margin:0 0 0 4px;}
.replbq{margin:4;}
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
