Re: [xl7] More track to channel confusion
2001-12-07 by gAb brOOk
beat_rebel wrote: > Alright, so I was able to merge tracks and achieve three identicle > drum tracks that transmit to three shared midi channels. But now when > I look at these tracks, no matter which channel I select via preset > view mode the grid record mode will show the data for all three > channels. When I try to modify the snare part(for example) for one of > the tracks, I get the wrong sample from the wrong midi > channel. Again I believe this is just a sign of my own sillyness, but > how do I work with multiple channels on a single track with out > getting confused? How do I make shure that I'm sequencing to the > correct channel in a multichannel track? > If you're working from a software sequencer, you have to select the chanel from the sequencer to get it right for multichanel. Or select a no output chanel to work on each single chanel. hope it works. cheers gab.
