2 bpm
2 bpm
2003-06-23 by smwither2002
I recorded a pattern at 2 bpm (extreme ambience) and although I
repeatedly saved it at that tempo, every time I call it up it's at 4
bpm.  Is that the slowest it will save?  Not a real impediment, just
curious about the limitations of this remarkable machine.
Re: 2 bpm
2003-06-23 by steve_the_composer
4
just
1.  To test this on my Command Station, I took a pattern and changed
it to 1 bmp.  It seemed to work.  I then powered down and the 1 bpm
setting was gone.
2.  I did it again at 274 bpm.  After powerdown, it came back as 274.
3.  I did it again at 2 bpm.  After powerdown, it came back up at 4.
I then started aftering files, saving them, and looking at them with
E-Loader's midi file listing utility.
More to follow.
Dr. Steve
Re: 2 bpm
2003-06-24 by steve_the_composer
> > at 4 bpm.  Is that the slowest it will save?  Not a real
> > impediment, just curious about the limitations of this
> > remarkable machine.
> To test this . . . I then started aftering files, saving them, and
> looking at them with  E-Loader's midi file listing utility.
> More to follow.
> Dr. Steve
I am now sorry I tried to figure out what was going on here.  I found
out much more than anyone probably needs to know.  But, since I was
checking out the problem, here are my results.
A pattern I had saved previously had track 0 data [midi meta events]
including tempo as expressed as a usecPerTick.
With E-Loader, I was trying to see what was going on with the
usecPerTick value at low bpm values.  But, unless I'm mistaken,
something is up with the way the file is stored and/or saved in
OS2.0.  I was unable to view this parameter after patterns were
resaved.
When I downloaded my previously saved pattern to the E-Mu, changed
just the name, and uploaded it to the computer, E-Loader no longer
displayed the same track 0 data. I also saved an unaltered pattern.
That, too, appeared different in E-Loader after being saved.
It may be that a change in the file structure in OS2.0 doesn't
correspond with how E-Loader1.1 parses the file. So far as I can see
the note and other channel data is still in the file.  Its just that
something about the way the midi track header is stored/viewed seems
to be different in OS2.0.
Another test I did consisted of starting a track at 4 bpm and editing
the conductor track so that at 001.01.002 the tempo would become 1
bpm.
The 1 bpm setting stayed with the pattern in memory until
powerdown/reboot.  Then the 1 bpm became 6 bpm.
Who knows why this happens.  My guess is that there some sort of
mathematical calculation going on with the tempo/usecPerTick variable
and during some operations (save/powerdown), the value gets checked
or recalculated.  This is just a guess. If someone knows, I'd be
curious to know what's going on.
Based on this, I don't think I will be using such a rate (2 bpm).
======Excerpt # 1 =================================
file name: "P.0.006-Smoover.mid"  length: 2972  last modified: Tue
Jun 24 00:06:14 EDT 2003
format: 1
numTracks: 17
ppqn: 384
msPerTick: 1.3020833333333333
track 0 start. length: 157 bytes
0: sysex type: 0 length: 72
		f0 18 0f 7f 55 01 20 01 04 06 00 02 04 2e 00 03
		04 40 00 04 04 00 00 05 04 05 00 06 04 0a 00 07
		04 0c 00 08 04 07 00 09 04 00 00 0a 04 00 00 0b
		04 00 00 0c 04 0f 00 0d 04 3c 00 0e 04 0a 00 0f
		04 05 00 10 04 0a 00 f7
0: seqname: "Smoover #5"
0: smpteoffs: 96:0:0:0.0
0: tempo: 335195 usecPerTick
0: marker: "Main Channel Dests: bbbbbbbbbbbbbbbb"
0: timesig: 4/4 clksPerMetronome: 24 32ndsPerQuarter: 8
12288: endoftrack 0
track 1 start. length: 104 bytes
0: cntrllr ch: 0 ctl: 7 val: 127
0: cntrllr ch: 0 ctl: 10 val: 64
0: cntrllr ch: 0 ctl: 79 val: 0
0: cntrllr ch: 0 ctl: 80 val: 2
0: cntrllr ch: 0 ctl: 0 val: 17
0: cntrllr ch: 0 ctl: 32 val: 0
0: progchg ch: 0 val: 35
0: instname: "MP-7"
0: trackname: "Clav"
1410: noteon  ch: 0 key: 46 vel: 120
1522: noteoff ch: 0 key: 46 vel: 0
4482: noteon  ch: 0 key: 46 vel: 120
4602: noteoff ch: 0 key: 46 vel: 0
7554: noteon  ch: 0 key: 46 vel: 120
7673: noteoff ch: 0 key: 46 vel: 0
10626: noteon  ch: 0 key: 46 vel: 127
10738: noteoff ch: 0 key: 46 vel: 0
11265: noteon  ch: 0 key: 36 vel: 70
11393: noteon  ch: 0 key: 36 vel: 120
11416: noteoff ch: 0 key: 36 vel: 0
11524: noteon  ch: 0 key: 36 vel: 111
11712: noteoff ch: 0 key: 36 vel: 0
12288: endoftrack 1 track 2 start. length: 72 bytes
=== Excerpt # 2 ==================================
file name: "P.0.006-Smoover.mid"  length: 2956  last modified: Tue
Jun 24 00:14:04 EDT 2003
format: 1
numTracks: 17
ppqn: 384
track 0 start. length: 149 bytes
3072: noteoff ch: 7 key: 60 vel: 0
3074: noteon  ch: 7 key: 48 vel: 115
3305: noteoff ch: 7 key: 48 vel: 0
3458: noteon  ch: 7 key: 51 vel: 106
3682: noteoff ch: 7 key: 51 vel: 0
3842: noteon  ch: 7 key: 53 vel: 115
4050: noteoff ch: 7 key: 53 vel: 0
4098: noteon  ch: 7 key: 51 vel: 62
4146: noteoff ch: 7 key: 51 vel: 0
4225: noteon  ch: 7 key: 55 vel: 115
4417: noteoff ch: 7 key: 55 vel: 0
4487: ptchbnd ch: 7 val: 260
4495: ptchbnd ch: 7 val: 520
4503: ptchbnd ch: 7 val: 780
Re: [xl7] Re: 2 bpm
2003-06-24 by Aaron Eppolito
Heh, I just checked up on this since Steve went through all this
trouble.  (bonus points for Steve!)  Turns out that it is impossible to
store a whole BPM less than 4 in the Standard MIDI File format.
For those who *really* want to know more, a tempo event in a standard
MIDI file is "FF 51 03 tttttt" where "tttttt" is a 24 bit value
denoting microseconds per quarter.  The largest this number can be is
16777215 (2^24-1).  60000000/usecPerTick gives you BPM and 60000000/BPM
gives you usecPerTick.  In the runtime sequencer format, tempo is
stored as the much more logical BPM, so until you save it and have to
reload it (by selecting another pattern and coming back) it retains the
1-3 BPM.
Moral of the story?  Don't use BPMs less than 4.  Other moral of the
story?  Make sure the QA guys check saving low BPM tempos.  Real moral
of the story?  Make sure that I check the math the next time I write
SMF export code for tempo limits...  =)
-Aaron
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
RE: [xl7] Re: 2 bpm
2003-06-24 by Andre Lewis
Yes, Yes I care.  And I am in awe of the crazy ivestigation and breakdown of
superlowtempo (Someone should name an album superlowtempo) by Aaron and Steve!
Yikes!
Way to go guys!
Andre
Sent: Monday, June 23, 2003 11:31 PM
Subject: Re: [xl7] Re: 2 bpm
1-3 BPM.
-Aaron
Do you Yahoo!?
Re: [xl7] Re: 2 bpm
2003-06-24 by erik_magrini@Baxter.com
Real Moral Of The Story?  Who needs 4 BPM or less anyway?  :)
-Aaron
Do you Yahoo!?
Re: 2 bpm
2003-06-25 by steve_the_composer
> trouble.  (bonus points for Steve!)\
Thanks for the follow through (and for the bonus points!).
> standard MIDI file is "FF 51 03 tttttt" where "tttttt" is a 24 bit
> value . . . .
Now you're talkin' my language!
Any idea about what seemed to be a problem with E-Loader interpreting
OS2.0 MIDI file data properly?  Diagnosing pattern problems is a lot
harder using debug!  8-(>
Steve
