Drum Edit Tip
Drum Edit Tip
2003-06-13 by robotchas
Here's one solution to the problem of FINDING your drums in Grid Edit
mode (if you're performing you don't want to be wasting time
frantically scrolling the note field):
Make custom presets for each of your patterns (as rEalm suggests
elsewhere). If you assign your drum sounds to different tracks (T1 is
kick, T2 is snare, etc.) you're probably only using one or maybe two
notes on each track. So once you've picked the sound, go into the
Preset and transpose the layer up or down so that the sound you're
using is always on the same note. You can either put ALL drum sounds
on the same note (like Middle C), or use a different key within the
same octave for each type of drum (C is kick, D is snare, etc.) The
important thing is that you're consistent. Then when you jump into
Grid Edit mode and are looking for a particular drum you no longer
have to wonder which octave and key it's on. Voila.
Re: [xl7] Drum Edit Tip
2003-06-13 by erik_magrini@Baxter.com
Nice one!  Though for me personally that would interfere with my drum
layering ideas, since they both rely on Preset Transpose.
Re: Drum Edit Tip
How so? Can't you just shift all the layers by different amounts?
drum
> rEalm
Re: [xl7] Re: Drum Edit Tip
2003-06-19 by erik_magrini@Baxter.com
Yes, unless you only wanted to shift one layer.  I typically find the
first layer I want to use, then use the Preset Transpose on layer 2 to
find the next hit to layer.
robotchas <robotchas@...>
06/13/2003 05:42 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Drum Edit Tip
drum
> rEalm
Re: Drum Edit Tip
2003-06-19 by robotchas
Right, but why would you want to shift only one layer? There's no
advantage to not shifting the first layer if you're only using one
sound from it. If the first hit you want to use is on D2 and the
second is on F3, you can shift them both to C4 and get the exact same
sound.
to
> rEalm
2003-06-23 by erik_magrini@Baxter.com
Because I'm trying to find a second hit to layer over the first one that's
already sequenced and playing back.  By using the Preset Tune on only one
layer, I can find a drum sound that compliments the currently playing one.
Re: Drum Edit Tip
2003-06-23 by robotchas
Gaaah. I know that. You're doing this:
(a) play keys until you find kick sound you like
(b) sequence kick track on that key
(c) add second layer
(d) transpose second layer until you find complementary sound
Right? Correct me if I'm wrong.
But there's nothing that prevents you from doing the exact same thing
this way:
(a) lay down a scratch kick track on C4.
(b) transpose layer 1 until you find a sound you like
Or:
(a) play keys until you find a kick sound you like
(b) transpose layer 1 to put it on C4
(c) lay down kick track
(d) add second layer, etc.
The results sound exactly the same, but the second method keeps your
kick on C4 which makes it easier to find. There's no conflict between
what you're doing and what I was suggesting. I promise.
that's
only one
playing one.
> rEalm
Re: Drum Edit Tip
2003-06-24 by steve_the_composer
--- In xl7@yahoogroups.com, "robotchas" <robotchas@y...> wrote:
> . . . there's nothing that prevents you from doing the exact same
> thing this way:
> Or:
Its nice to have alternative like these spelled out so clearly (like
you have done) for those who want to try new techniques--espcially
ones that might help composers/performers standardize their setups.
2003-06-24 by erik_magrini@Baxter.com
Hehe, I wasn't disagreeing with your method, it's very good and a
perfectly valid way of working.  It's just easier FOR ME to lay down my
first drum sound (layer 1) using the actual sound itself, rather than
using a scratch kick and then trying to refind my original sound.  Just a
difference in working methods, nothing more :)
this way:
Or:
Re: Drum Edit Tip
2003-06-24 by robotchas
I know, but you made it sound like your method precluded using my
trick. If you don't care which note your drums are on because you
never edit them live, or because you have a very good memory, then it
doesn't matter. But if you transpose the sound you want to use to C4
before you record your track then you get the best of both worlds.
But maybe you Chicago-ites like to make things difficult for
yourselves. How else to explain the winters? ;)
down my
than
Just a
> rEalm
2003-06-25 by erik_magrini@Baxter.com
I know, but you made it sound like your method precluded using my trick.
>>>Wasn't my intention sorry about that. <<<
If you don't care which note your drums are on because you never edit them
>>>Haha, where am I again?  Good memeory, hardly... :) <<<
But if you transpose the sound you want to use to C4 before you record
>>Already got the best of both worlds, I'm smart and an ass, thus a smart
ass. ;p <<<
But maybe you Chicago-ites like to make things difficult for yourselves.
>>>Winters are easy, it's the summers that kill me. <<<
