To get past the silence issue, you'll have to go into pattern edit
and select 'extend track data' - this copies the given bar range and
pastes it into the "blank" space after the copied pattern's bars.
i.e., you copy bars 1-4 (where your track data is), and extend it to
bar 8 - next time you play it you'll hear bars 1-4 twice, instead of
1-4 and silence for 5-8.
/.j
--- In xl7@yahoogroups.com, "Rob Blue" <djrobblue@y...> wrote:
> Ive been learning more about my XL-7 for the past two weeks and Im
> coming to the conclusion that I love the sounds but the interface
is
> confusing to me.Is there any particular setup for the XL to use it
> just as a sound source?I plan on using my yamaha RS7000 as my main
> sequencer.....Also (this is one of the things I didnt get about
XL7)
> can you have differnt length patterns play together?ex A 4 bar
drum
> loop play twice with a 8 bar synth loop..I tried it and got
silence
> for the second 4bars of the drum loop in this example.
> PS. I got the peter siedlaczk rom, great drum and string sounds
but
> corny horns, just if anyonewanted to know.
> Thanks!!
