Comparison to Akai
Comparison to Akai
2003-06-13 by Matt Picone
Hi folks
Please read this post about the PX-7 from the Elektron MachineDrum forum
and share your reactions.
> i would prever an MPC2000XL
> it uses the samples you want and akai
> [has] much more sequencer-expierience than emu.
-M@
Re: [xl7] Comparison to Akai
2003-06-13 by erik_magrini@Baxter.com
You're comparing apples to oranges IMO.  Yeah, the MPC let's you use your
own samples, but it's a sampler, the XX-7 is a synth.  In terms of sounds,
there's plenty of ROMs you can add to the XX-7's should you need more.  As
far as sequencers go, I won't lie.  The MPC is way ahead of the XX-7's in
terms of sheer features and flexible editing, but the XX-7's are far more
intuitive and faster to work with IMO.  I was debating both when I got my
XL-7, and ended up with the XL-7 because it was very fast to get my ideas
down, and you get a top of the line Emu synth to boot.
What are you looking to get the PX-7 for?
"Matt Picone" <matman@...>
06/13/2003 08:31 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Comparison to Akai
Hi folks
-M@
Why Command?
> rEalm
OK, to answer the question, I'll freeform for awhile. Please keep in
mind I DID read the FAQ but it's a lot to absorb.
I'm looking for a good sequencer to facilitate live jamming using my
many synths.
I'd like to be able to lay down a loop (say 4 measures), play multiple
layers on different outboard synths, then assign this pattern to a key
or button. Repeat the process several times and then change sections on
the fly, adjusting layers as needed to create variations. Have 3 or 4
live musicians jamming with this in realtime. Send midi clock to the
guitar rig and other arp-synths and drum machines.
The foot pedal to tap-tempo feature is very important to me.
The arp capabilities sound like a great plus. Even though they aren't
polyphonic per se, it sounds like they can be stacked, right? Will they
trigger external gear (arp out)?
Another interesting use will be to develop a control track to send CC
messages to a few older units which sync to tap but not clock. Layers of
CC messages on multiple channels.
Being able to save groups of patterns to be triggered by single notes on
a keyboard would be nice too.
-M@
Re: [xl7] Why Command?
2003-06-13 by biz
YMMV, but I found the arps sectin on the emu series to be thoroughly useless, unless you are interested in living through other people's musical ideas. They are more on the lines of melodies and solos in loop format than usable arpegiations.
Programming your own is too time consuming to make it worth it.
I have a 'synch track' on my xl-7. I use to keep pitch shifters and time shifters in key, and send out PCs to other gear.
Can't do that I'm afraid...
bIz
http://www.groovetronica.com - "The beats are ok, I suppose, but the vocals sound like the vintage jazz singers from my dad's record collection. It's not for me."
  Sent: Friday, June 13, 2003 7:41 AM
  Subject: [xl7] Why Command?
  > rEalm
  many synths.
  -M@
        Yahoo! Groups Sponsor
2003-06-13 by aeon
> arpegiations.
On the first point, it is true that if you want "regular" arps, then you
need to use something other than pattern mode.
As to the second, I agree if you are programming from the front panel.
Editing the arps on my XL-1 with SoundDiver works OK, but it is still work.
According to the SD developers, E-mu has not given them the information
needed to create a proper Command Station editor, which is a damn shame.
sigh,
aeon
2003-06-13 by biz
bIz
Could you explain? I think I'm missing your suggestion.
bIz
  Sent: Friday, June 13, 2003 1:58 PM
  Subject: Re: [xl7] Why Command?
  > arpegiations.
  sigh,
  aeon
2003-06-13 by aeon
one of the arp modes is "pattern," and this is what gives you all the
"loop-based" arps...
the arp also has other modes that are like vintage synths in that you have
up, random, etc.
that said, even with the "preset loop" arps, you can get a lot of mileage
out of them with the use of the extension modes and speed settings, not to
mention some massaging in your sequencer of choice. ;)
cheers,
aeon
2003-06-14 by Bruddah Max
>> They
>> arpegiations.
aw, poot, that's what Michael Hadyn and folks have always said about modules
that are long in coming. they still haven't done a Motif editor either - if
they can make an EX5 editor, they can make one for the Motif.
anyhoo back on subject my SoundDiver shows a rack module for the XL-7 and
will download the patches and arps, but nothing else. hmmm.
what i'm wondering is if MOTU Unisyn 2.0's XL-7 editor is up to snuff. i use
Digital Performer 3.x these days, and Unisyn now supports all of my synths,
at least on paper. the integration between DP and Unisyn is sublime,
Logic/SoundDiver can only dream of approaching it. so - anyone have any
experience using the XL-7 or similar editor in Unisyn?
Bruddah Max
Lord of the Dance
Re: Why Command?
2003-06-15 by robotchas
> many synths.
I think live performance is where the XL, er, excels (sorry).
multiple
key
> or button.
The XL-7 can drop in and out of record (grid or realtime) at any
point without interrupting playback. This is one of its best
features. As for the second part you could then assign the pattern to
one of the triggers using the Direct Pattern Access feature (see 2.0
manual addendum), which would enable you to queue the pattern from
the front panel (using an external keyboard is something I've
suggested but is currently not possible). You can erase tracks and
save patterns on the fly too.
Direct Pattern Access and muting. You can also force-switch to the
queued pattern.
Two MIDI outs should improve timing on the external synths.
aren't
they
They can be triggered by an external keyboard and/or play external
gear. You only get one arp per channel though, so to stack them you'd
have to play a note on multiple channels at the same time. There may
be a workaround but I can't think of one at the moment.
And don't forget XMIX.
CC
Layers of
Do-able, though you may find it easier to set this up on a software
sequencer and then transfer it to the XL.
notes on
Each Multisetup saves a set of 16 pattern->trigger assignments, and
these can be switched on the fly too (watch out for preset and
effects changes though). External keyboard not possible as I've
already mentioned.
You ask about the MPC in another post. The sampling is certainly
nice, at least for drums, and the sequencer is solid (Roger Linn
designed it), but there are still some areas where the XL is better,
particularly for live performance: the MPC has no TR-909-style grid
edit/record mode, no dedicated mute buttons, no arpeggiator, no RPS,
and no equivalent to XMIX. In my opinion it makes more sense as a
studio tool for people who don't like using software, and judging by
the MPC-4000, which is basically a proprietary computer, Akai agrees
with me. But then, I'm an MPC heretic, I think it's overrated and
overpriced.
2003-06-16 by biz
> > information > needed to create a proper Command Station editor, which
> > is a damn shame.
> > modules that are long in coming. they still haven't done a Motif editor
> > either - if they can make an EX5 editor, they can make one for the
> > Motif.
> > and will download the patches and arps, but nothing else. hmmm.
 What does midiquest do? Anyone tried it?
