Pattern Midi Channels
2003-06-11 by justinkoller
I'm trying to use the my XL-7 (with OS 2.0) for controlling both internal and external sounds. I've tried changing the MIDI channel of a particular track in a Pattern, such that I'm playing an external device on "10B". ( actually, I'd like to set several tracks to the same MIDI channel, since I'm using a drum synth but would like to pull bass drums, snares, etc in & out seperately just like the presets do to internal sounds) I save the pattern (no sequence data), but when I reload the pattern, my channel selection is gone, and the track resorts to it's usual default (ie- track 01 is set to channel 01A, instead of 10B like I had tried to save!)(btw-I know it's saving, because I can change the pattern name, and that will save & reload correctly) Is it possible to save a track's channel # in a pattern without having sequence data on that track? I'd like to save a "template" for creating new patterns using my external devices, but don't want to hand edit track channel numbers everytime I create a new track. It doesn't seem to me that this is a multisetup thing, is it? Something else I'm missing? Also, even though I set the track to "ext"ernal, the internal sounds still play! I can only get rid of them by loading a "Default" sound (ie-no sound) as the preset for that track. -jk*
