Subject: Re: a liittle more help on the os dl
> > --- M2 <mmcquay@s...> wrote:
> > Within the E-loader program is the OS downloader
> > utility. Once your
> > Command Station is in the searching for OS mode(by holding the
home/enter button at power up), you
> > then lauch the
> > OS downloader application. Then select the .dli
> > file(OS)from the
> > folder where you saved it to, select your midi
> > device (the midi
> > interface connected from your computer to the
> > XL-both midi cables
> > need to be hooked up), and then click on the send
> > (download) prompt.
--- In xl7@yahoogroups.com, "fman19752003" <fman19752003@y...> wrote:
> How do I download the newer software version?
