Re:PRESET QUESTION
Re:PRESET QUESTION
2003-06-05 by acopolis@space380.com
It seems like every time I get a good amount of music written on this thing
I start running into problems. Like I had this song basically finished and
had my wife come and listen. I hit play and all my presets are fucked up.
Either the sound of the preset changes or the wrong preset ends up in the
wrong place when every thing was fine last time I used the machine.
Sometimes the preset sound is messed up but if I dial away and come back to
it it will be correct again until I go to some other patterns for a while
and come back. I know I had program change off on the channel with the
problem but I turned it on and that helped but things still seem to be
acting weird.
I seem to get occasional hiccups,  added sounds when patterns change,
presets sounding different from day to day. how can any one rely on this
thing live???? I hope it is just a matter of my own ignorance and not the
MP7 itself. I do name my presets to avoid messing them up.
what is everything I need to consider to make sure my MP7 remains stable
(right now it seems any thing but reliable) and to avoid messing up the wok
& presets that I have been working on. It seems lately that I can't
effectively save or even scroll through screens while playing.
acopolis
> Message: 9
>    Date: Thu, 05 Jun 2003 04:03:32 -0000
>    From: "justinkoller" <justinkoller@...>
> Subject: WinXP & USB Problem
> I've seen some people post about this, but haven't seen a solution
> or heard of one working.
> When i turn on the XL7, let it boot up, and THEN plug it into
> windows (as the directions say), windows xp will NOT correctly
> detect the device.  Via MIDI, I have already upgraded to 2.0, and
> can run eloader.  Eloader was not running while I tried to plug in
> the device to USB.
> Emu support has some canned response they used on me twice that
> includes "USB is only for sequence back up" and "please read the
> instructions and follow them exactly or you'll need to douse your PC
> in bleach and reinstall windows".  So I'm turning to you guys.
> I've tried this on several PC's (all, unfortunately, run winXP).
> Every one complains that an "unknown device" was plugged in, and may
> have malfunctioned.  Manual installs fail, because windows complains
> the drivers I try to set (tried both usb0 and usb1 first) an
> incompatible with the device..I'm guessing that's because
> it's "unknown".
> But, I'm thinking that the device has some unique ID, (since
> subsequent install attempts happen so much faster than the first)
> and that I can edit the registry settings for it, so windows can
> match up the same strings that exist in the driver vs. what's
> detected.
> A.) Anybody got another solution?
> b.) What, EXACTLY, does windows XP detect the device as?
> thanx
> -jk*
> ________________________________________________________________________
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.487 / Virus Database: 286 - Release Date: 6/1/03
